Ergebnis 1 bis 10 von 16
Thema: Bei make all Problem mit Msleep
    ich habe ein Problem bei make all:
    Wenn ich Msleep () benutze zeigt Programmers Notepad 2 mir folgende Meldung an:
    > "make.exe" all
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > asuro.d; \
    [ -s asuro.d ] || rm -f asuro.d
    set -e; avr-gcc -MM -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c \
    | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > test.d; \
    [ -s test.d ] || rm -f test.d
    -------- begin --------
    avr-gcc --version
    avr-gcc (WinAVR 20100110) 4.3.3
    Copyright (C) 2008 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions. There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c -o test.o
    In file included from asuro.h:34,
    from test.c:1:
    d:/asuro/programme/lib/gcc/../../avr/include/avr/signal.h:36:2: warning: #warning "This header file is obsolete. Use <avr/interrupt.h>."
    test.c: In function 'main':
    test.c:12: warning: implicit declaration of function 'Msleep'
    test.c:15: warning: control reaches end of non-void function
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=asuro.lst asuro.c -o asuro.o
    from asuro.c:29:
    avr-gcc -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.o test.o asuro.o --output test.elf -Wl,-Map=test.map,--cref -lm
    test.o: In function `main':
    D:\ASURO\Aufgaben\1m/test.c:12: undefined reference to `Msleep'
    make.exe: *** [test.elf] Error 1
    > Process Exit Code: 2
    > Time Taken: 00:02
    Dann habe ich mir eine neue asuro.h und asuro.c gedownloadet und dann kommt das:
    > "make.exe" all
    asuro.c:68:21: error: myasuro.h: No such file or directory
    avr-gcc --version
    asuro.c: In function 'IsrStandard':
    asuro.c:173: error: 'MY_SWITCH_THRESHHOLD' undeclared (first use in this function)
    asuro.c:173: error: (Each undeclared identifier is reported only once
    asuro.c:173: error: for each function it appears in.)
    asuro.c: In function 'Init':
    asuro.c:260: error: 'F_CPU' undeclared (first use in this function)
    make.exe: *** [asuro.o] Error 1
    > Time Taken: 00:01
    Mein Programm sieht so aus:
    #include "asuro.h"
    #define cm 75
    int main (void)
    Init();
    MotorDir (FWD,FWD);
    //Strecke 1m;
    MotorSpeed (125,125);
    Msleep ( 100 * cm );
    MotorSpeed (0,0);
    Wenn ich Msleep ( 100 * cm); entferne funktioniert es.
    Vielen Dank im Voraus Bild   Bild
    Karlsruhe
    Das alleine reicht nicht, du brauchst auch alles andere was dazu gehört, unter anderem das entsprechende Makefile. Näheres dazu verrät dir die Dokumentation der Bibliothek die du herunter geladen hast. Ich gehe davon aus, dass das die Roboternetz-Bibliothek ist.
    mfG
    Markus
    Tiny ASURO Library: Thread und sf.net Seite
    vielen Dank für den Hinweis!
    Welche Dateien brauche ich denn jetzt in dem Verzeichnis zum Compilieren?
    Wo ist die Dokumentation zu finden?
    Ja, ich verwende die Roboternetz Bibliothek. Bild
    Im Voraus vielen Dank für weitere Antworten!
    Karlsruhe
    Kennst du das AsuroWiki? Dort ist auch die Dokumentation zur RN-Bibliothek untergebracht. Dort wird auch erklärt, wie du die Bibliothek verwenden kannst.
    mfG
    Markus
    ich hab mir die Dokumentation mal durchgelesen!
    Für mich Anfänger ist das Chinesisch und Japanisch gemixt.
    Das mit der Makefile hab ich noch hinbekommen, also den Libpath anzugeben
    aber dann bei neue Projekte verstand ich nur noch Bahnhof.
    Ich hab immer noch mein altes Programm namens werner.c:
    #include "asuro.h"
    #define cm 75
    int main(void)
    Init();
    MotorDir (FWD,FWD);
    //Strecke 1m;
    MotorSpeed (0,0);
    So wie ich bei "Neue Projekte" gelesen hab soll ich nur die dateien benötigen die ich im anhang hab(ohne asuro.h), dann meckert er aber, dass er asuro.h nicht findet:
    > "make.exe" all
    set -e; avr-gcc -MM -mmcu=atmega8 -DF_CPU=8000000UL -I. -g -Os -I../../lib/inc -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c \
    test.c:9:19: error: asuro.h: No such file or directory
    avr-gcc --version
    make.exe: *** No rule to make target `test.hex', needed by `all'. Stop.
    > Time Taken: 00:01
    So wenn ich dann asuro.h im selben Verzeichnis habe (wie im Bild) meint er:
    > "make.exe" all
    avr-gcc --version
    > Time Taken: 00:01
    Karlsruhe
    asuro.h zu kopieren ist falsch. Wie in der Dokumentation steht, musst du im Makefile konfigurieren, wo die ASURO-Bibliothek zu finden ist. Der vorgegebene Pfad funktioniert nur wenn dein Projekt in einem eigenen Ordner unterhalb von "examples" liegt.
    Der zweite Fehler betrifft die Konfiguration der Quelltext-Dateien im Makefile. Dort ist ziemlich sicher noch test.c hinterlegt, dort müsste aber werner.c stehen.
    mfG
    Markus
    vielen Dank für die Antwort!
    So also ich hab asoro.h gelöscht!
    Es funktioniert leider immer noch nicht Bild   Bild   Bild
    Bild   Bild   Bild
    Karlsruhe
    Wenig verwunderlich, du hast ja auch nicht richtig aufgepasst was ich geschrieben habe.
    In dem Makefile steht bei TARGET "test" drin. Dein Programm hat aber einen anderen Namen. Ersetze "test" durch "werner" und dann ist der erste Fehler weg. Womit wir zum zweiten Fehler kommen. Du hast LIBPATH zweimal drin stehen, einmal als direkten (richtigen) Pfad und direkt darunter einen falschen relativen Pfad. LIBPATH ist eine Variable, wie beim Programmieren wird der richtige Pfad also durch den falschen überschrieben. Die zweite Zeile bitte ganz löschen oder auskommentieren!
    mfG
    Markus
    ok danke
    es funktioniert immer noch nicht richtig Bild
    vielen dank für die mühe!!!
    Bild   Bild   Bild
    - - - Aktualisiert - - -
    hallo
    ok danke
    ich hab werner.c in test.c umbenannt.
    den zweiten libpath gelöscht
    und es funktioniert immer noch net
    Bild   Bild   Bild
    hallo
    ok danke
    und es funktioniert immer noch net. Bild   Bild   Bild
    vielen dank für die mühen
    Bild   Bild   Bild
    oops hab eben erst bemerkt, dass es zwei seiten gibt
    Karlsruhe
    Kannst du den Ordner bitte Mal in ein ZIP-Archiv packen und irgendwo hochladen? Irgend etwas an deiner Konfiguration ist komisch. Auch, dass ganz zu Beginn "asuro.h" nicht gefunden wird. Der LIBPATH stimmt schon, oder?
    mfG
    Markus
  1. MSleep bei richtungswechsel?
    Von Fabulous84 im Forum Asuro
    Antworten: 9
    Letzter Beitrag: 21.04.2011, 16:33
  2. Problem mit Msleep
    Von Mk1.12.91 im Forum Asuro
    Letzter Beitrag: 01.02.2010, 15:07
  3. Msleep Problem
    Von blackyy im Forum Asuro
    Antworten: 7
    Letzter Beitrag: 06.02.2009, 16:05
  4. Problem bei ausführen von "make"
    Von sexymenffm im Forum Asuro
    Antworten: 9
    Letzter Beitrag: 18.06.2008, 10:38
  5. Antworten: 4
    Letzter Beitrag: 20.11.2007, 22:04
