Ah, ok - now i know how to do it:
- Copy your sourcecode into the rp6-folder (for example RP6Base_Move_05.c)
- Rename it to "test.c"
- In a terminal navigate to this folder and run "cmake CMakeLists.txt"
- Now run "make all"
- Open the simulator, File - New Projecet, select name and directory, then at "Plugin" chose the "rp6simul-plugin"-folder -> rp6 -> libplugin.so
- Thada :-D when you click at the "map"-tab you can draw your map where RP6 drives
Now i have another question:
Is it possible to simulate the rp6 as fast as the pc can calculate? (like time lapse)
( https://www.roboternetz.de/community...Wand-zu-fahren![]()
greetings
schumi
Zitieren
