Hi dopez,
maybe it can be done by an #ifdef #else construct and a preprocessor define.
If the US Module is in use, the old code is included, else the new code.
The old Asuro Lib:
The new Asuro Lib sources:Code:/* uses timer2 (36kHz for IR communication */ /* counts falling and rising edge => 36kHz*2 = 72kHz */ SIGNAL (SIG_OUTPUT_COMPARE2) { count72kHz ++; } /* Init function Processor will be initalized to work correctly */ void Init (void) { //-------- seriell interface programmed in boot routine and already running ------- // prepare 36kHz for IR - Communication TCCR2 = (1 << WGM21) | (1 << COM20) | (1 << CS20); OCR2 = 0x6E; // 36kHz @8MHz TIMSK |= (1 << OCIE2); // 36kHz counter for sleep
Best reagrds m.a.r.v.i.nCode:/* uses timer2 (36kHz for IR communication */ SIGNAL (SIG_OVERFLOW2) { TCNT2 += 0x25; count36kHz ++; if (!count36kHz) timebase ++; } /* Init function Processor will be initalized to work correctly */ void Init (void) { //-------- seriell interface programmed in boot routine and already running ------- // prepare 36kHz for IR - Communication TCCR2 = (1 << WGM20) | (1 << WGM21) | (1 << COM20) | (1 << COM21) | (1 << CS20); OCR2 = 0x91; // duty cycle for 36kHz TIMSK |= (1 << TOIE2); // 36kHz counter for sleep
Zitieren
