Ergebnis 11 bis 12 von 12
Thema: Zeitschrift ELEKTOR
    Das sieht wirklich gut aus, 300 Seiten für ca. 15€ jeden Monat.
    Ich habe mal die Präsentation der Ausgabe über Transistoren durch einen Übersetzungsprogramm laufen lassen. Alles ist vielleicht nicht lesbar aber wenn man foundation mit fundamentals übersetzt...
    http://www.cqpub.co.jp/hanbai/books/37/37491.htm
    Transistor technology SPECIAL No.88< To series summary >
    From foundation of discrete semiconductor device everything of application
    Revision new edition diode/transistor /FET application introduction
    Transistor technical SPECIAL editorial staff compilation
    B5 format page 296
    Price 2,310 Yen (including tax)
    ISBN4-7898-3749-1
    2004 October 1st issue
    (With CQ publication Web member service subscription)
    The present electronic equipment is formed the semiconductor device where everything was almost accumulated high-level to the center. Whether in that device some kind of processing is done concretely, if only just a little you saw, estimate it has, it does not come. But, though call the semiconductor device which is how high function, inside is formed the transistor and the diode, by FET and the like. Therefore, operational principle of transistor and diode and FET and understanding circuit technology even presently have become very important.
    This book, structure and operational principle of the element, collected the concrete applied circuit and the point of caution etc. in regard to use to one volume the diode which even representation of discrete semiconductor it should call, concerning bipolar transistor and FET.
    Furthermore, this book does 企 being something which is worked out, as a revised edition "of everything of the transistor technology SPECIAL No.1 special edition individual semiconductor device application method which" is issued in 1987. Basic contents followed the introduction, adjusted to the change of age and included new topic many. From the beginner that, it probably will learn the foundation of electronics, it has become the contents where is useful to the engineer of all levels to the veteran engineer who needs the applied circuit of the discrete element.
    Table of contents
    Foundation and application of part diode
    Operational principle of 1st chapter diode
    1.1 Diode
    1.2 Basic quality of diode
    How to use the 2nd chapter small signal general-purpose diode
    2.1 Input/output protection of CMOS logic IC
    2.2 Protection of OP amplifier
    2.3 Protection of induction load drive circuit
    2.4 Bias circuit for linear amplifier
    2.5 The circuit which slight increase it can point output voltage of 3 terminal regulator
    2.6 Time voltage commutation circuit where you can obtain the rectification voltage of 2 times
    2.7 Application to limiter
    2.8 Ideal diode
    2.9 Absolute value circuit
    How to use the 3rd chapter power diode
    3.1 Power diode
    3.2 Viewpoint of data seat
    3.3 Application of power diode to general rectification circuit
    3.4 How to choose the diode
    3.5 How to request the output voltage and the ripple voltage
    3.6 Application to switching power supply circuit
    How to use the 4th chapter reference diode
    4.1 Basic quality of reference diode
    4.2 temperature compensating type reference diodes
    4.3 For reference voltage IC
    4.4 Other reference diodes
    4.5 Application to voltage stabilizer
    4.6 Application to other than voltage stabilizer
    How to use the 5th chapter fixed electric current diode
    5.1 Basic quality of fixed electric current diode
    5.2 Application of fixed electric current diode
    5.3 The fixed current circuit which does not use CRD
    How to use the 6th chapter light-emitting diode
    6.1 Basic quality of light-emitting diode
    6.2 How to use the LED display
    6.3 How to use the white LED
    6.4 Drive circuit of white LED
    6.5 How the to use infrared LED
    How to use the 7th chapter high frequency diode
    7.1 How to use the PIN diode
    7.2 How to use the variable capacitance diode
    7.3 How to use the Schottky barrier diode
    Foundation and application of second section transistor
    How to use the 8th chapter small signal transistor
    8.1 Basic operation of bipolar transistor
    8.2 Application to switching circuit
    8.3 Application to interchange amplifier
    8.4 The minimum the quality parameter which would like to remember
    How to use the 9th chapter power transistor
    9.1 Maximum rating of transistor
    9.2 Safe operational territory (ASO)
    9.3 Basis of heat dissipation design
    9.4 Concrete power design
    How to use the 10th chapter high frequency transistor
    10.1 Elementary knowledge of high frequency transistor
    10.2 With high frequency important quality parameter
    10.3 Wide band amplifier for television receiver
    10.4 High frequency switcher
    10.5 AGC amplifier
    10.6 MIX circuit
    10.7 Design of oscillating circuit
    10.8 SiGe heterojunction transistor
    Foundation and application of third section FET
    How to use the 11th chapter small signal FET
    11.1 The basic operation of FET
    11.2 The electric quality of FET
    11.3 The amplifier which used FET
    11.4 Application to other than amplifier
    How to use the 12th chapter power MOS FET
    12.1 Foundation of power MOS FET
    12.2 Rating of power MOS FET electric quality
    12.3 Elementary knowledge in order to use power MOS FET safely
    12.4 The basic circuit which drives the gate
    12.5 Foundation of switching of power MOS FET
    12.6 Variety of power switching circuit
    12.7 Applied circuit of power MOS FET
    How to use the 13th chapter high frequency FET
    13.1 Basis of high frequency FET
    13.2 Design of high frequency FET circuit
    13.3 Micro sideband the design of the low-noise amplifier
    Hallo Manf
    Ja die haben eindeutig die besten Zeitschriften die Japaner.
    Ein Grund endlich die Sprache zu lernen Bild
    LG
    Michael
