Ergebnis 1 bis 3 von 3
Thema: test Programm T/C2-wake up funktionieren nicht richtig
    test Programm Timer /Counter2-wake up funktionieren nicht richtig
    das programm ist einfach:Timer/Counter1 zaehlen 5 Sekunden dann das
    controller geht zu sleep Mode, mit Timer/Counter2 soll er wieder aufgewacht wird.
    Timer/Counter2 läuft asynchronous
    When Timer/Counter2 operates asynchronously, some considerations must be taken.
    • Warning: When switching between asynchronous and synchronous clocking of
    Timer/Counter2, the timer registers TCNT2, OCR2 and TCCR2 might get corrupted.
    A safe procedure for switching clock source is:
    1. Disable the Timer/Counter2 interrupts OCIE2 and TOIE2.
    2. Select clock source by setting AS2 as appropriate.
    3. Write new values to TCNT2, OCR2 and TCCR2.
    4. To switch to asynchronous operation: Wait for TCN2UB, OCR2UB and
    TCR2UB.
    5. Clear the Timer/Counter2 interrupt flags.
    6. Clear the TOV2 and OCF2 flags in TIFR.
    7. Enable interrupts, if needed.
    • When writing to one of the registers TCNT2, OCR2 or TCCR2, the value is
    transferred to a temporary register and latched after two positive edges on TOSC1.
    The user should not write a new value before the contents of the temporary register
    have been transferred to their destination. Each of the three mentioned registers
    have their individual temporary register. For example, writing to TCNT2 does not
    disturb an OCR2 write in progress. To detect that a transfer to the destination
    register has taken place, an Asynchronous Status Register (ASSR) has been
    implemented.
    • When entering a Power Save Mode after having written to TCNT2, OCR2 or
    TCCR2, the user must wait until the written register has been updated if
    Timer/Counter2 is used to wake up the device. Otherwise, the MCU will go to sleep
    before the changes have had any effect. This is extremely important if the Output
    Compare2 interrupt is used to wake up the device; Output Compare is disabled
    during write to OCR2 or TCNT2. If the write cycle is not finished (i.e., the user goes
    to sleep before the OCR2UB bit returns to zero), the device will never get a compare
    match and the MCU will not wake up.
    hier ist das Code:
    .include"8535def.inc"
    .def temp=r16
    .def temp2=r17
    .def crc8=r24
    .org 0X000
        rjmp reset           ;reset handler
    .org 0X008
        rjmp TIM1_OVF        ;time1 overflow handler
    .org 0X004
        rjmp TIM2_OVF        ; Timer2 Overflow Handler
    .equ quartz=7372800   ;Seite 60,64,XTAL->Baudrategenerator
    .equ baud=9600
    .equ start=65536-39060
    .equ highvalue=high(start)
    .equ lowvalue=low(start)
    reset:
      ldi temp,low(RAMEND)
      out spl,temp             ;Seite 21
      ldi temp,high(RAMEND)    ;Stackpoint initialisieren
      out sph,temp
      ldi temp,1<<TOIE1
      out TIMSK,temp      ;time1 interrupt ein , Seite 27
      ldi temp,0b00000101 ;Seite 38
      out TCCR1B,temp     ;bit2-0 define the Prescaling
      sei
    loop:
        ldi temp,0b11111100
        out portb,temp
        rjmp loop
    sleepe:
        ldi temp,1<<SE
        out mcucr,temp
        ldi temp,(1<<sm0)+(1<<sm1)
        out mcucr,temp      ;set bit Nr 5 und 4 in mcucr register
        sleep
        ret
    TIM2_OVF:
        ldi temp,(0<<OCIE2)+(0<<TOIE2)
        out TIMSK,temp
          ;cbi TIMSK,OCIE2
          ;cbi TIMSK,TOIE2
        ldi temp,1<<as2
        out assr,temp
        ldi temp,50
        out TCNT2,temp
        ldi temp,0b11111111
        out OCR2,temp          ;Timer/Counter2 Output Compare Register
        ldi temp,0b00000001
        out TCCR2,temp
        wait1:
            in temp,ASSR
            SBRC temp,2        ;tcn2ub
            ;sbic ASSR,TCN2UB
            rjmp wait1
        wait2:
            in temp,ASSR
            SBRC temp,1        ;OCR2UB
            ;sbic ASSR,OCR2UB
            rjmp wait2
        wait3:
            in temp,ASSR
            SBRC temp,0        ;TCR2UB
            ;sbic ASSR,TCR2UB
            rjmp wait3
            in temp,TIFR
            ldi temp,(1<<OCF2)+(1<<TOV2)
            out TIFR,temp
            ;sbi TIFR,OCF2       OCF2 is cleared by writing a logical “1” to the flag
            ;sbi TIFR,TOV2       TOV2 is cleared by writing a logical “1” to the flag.
        sei
     reti
    TIM1_OVF:
           ldi temp,highvalue
           out TCNT1H,temp    ;Datenblaette Seite 38
           ldi temp,lowvalue  ;Startwert des Timers einstellen
           out TCNT1L,temp    ;39060 Takt ist 5 Sekunde
                              ;nach 5 sekunde ist interrupt ausgeloest
           rcall sleepe        ;aufrufen Sleep Funktion
           reti
    Bitter, könnte jemand mir helfen, ich dank euch voraus
    .def temp=r16
    .def temp2=r17
    .def crc8=r24
    .org 0X000
    .org 0X004
        rjmp TIM2_OVF
    .org 0X008
        rjmp TIM1_OVF
    .equ baud=9600
    reset:
      out sph,temp
      ldi temp,highvalue
      out TCNT1L,temp
      ldi temp,1<<TOIE1
        ldi temp,1<<SE
        out mcucr,temp
        ori temp,0b00110000    ;sleep enable
        out mcucr,temp
        sei
    loop:
        ldi temp,0b11111100
        out portb,temp
        ldi temp,0b11111111
        out DDRB,temp
       rjmp loop
    initial:
        in temp,timsk
        andi temp,0b00111111
           ;ldi temp,(0<<OCIE2)+(0<<TOIE2)
        out TIMSK,temp
        ldi temp,1<<as2
        out assr,temp
        ldi temp,200
        out TCNT2,temp
        ldi temp,0b00000011
        out TCCR2,temp
        ldi temp,0b11111111
        wait1:
            in temp,ASSR
            sbrs temp,2        ;tcn2ub
            rjmp wait1
        wait2:
            in temp,ASSR
            sbrs temp,0        ;TCR2UB
            rjmp wait2
        wait3:
            in temp,ASSR
            sbrs temp,0        ;TCR2UB
            rjmp wait3
        ldi temp,(1<<TOIE2)
        out TIMSK,temp
        sei
        ldi temp2,0b11111111
        out portb,temp2
        sleep
        rcall reset
       ret
    TIM1_OVF:
           ldi temp,highvalue
           rcall initial      ;aufrufen Sleep Funktion
    reti
    TIM2_OVF:
        ldi temp,200
        out TCNT2,temp
        rcall reset
      reti
    das war verbessert Code ,aber wirkt trotzdem nicht, das controlle wacht nicht auf, trotz Asynchronous mode ist doch eingestellt
