Ich meine diese File. Da seht nichts von Motor oder Schritten usw. Nur von Memorycells und sram. Ich denke da liegt eine Verwechslung vor. Wenn noch an anderer Stelle im Forum darüber geschrieben ist, dann bitte mal einen Link setzen.
#include"lcd_i2c.h"
#include"i2cmaster.h"
#include "define.h"
#include <avr/io.h>
#include <stdio.h>
#define OFFSET 0x1100
#define SET_SRAM1 {PORTF |= (1<<PF1); PORTF &= ~(1<<PF0);}
#define SET_SRAM2 {PORTF |= (1<<PF0); PORTF &= ~(1<<PF1);}
#define BANK_0 {PORTF &= ~(1<<PF4); PORTF &= ~(1<<PF3); PORTF &= ~(1<<PF2);}
#define BANK_1 {PORTF &= ~(1<<PF4); PORTF &= ~(1<<PF3); PORTF |= (1<<PF2);}
#define BANK_2 {PORTF &= ~(1<<PF4); PORTF |= (1<<PF3); PORTF &= ~(1<<PF2);}
#define BANK_3 {PORTF &= ~(1<<PF4); PORTF |= (1<<PF3); PORTF |= (1<<PF2);}
#define BANK_4 {PORTF |= (1<<PF4); PORTF &= ~(1<<PF3); PORTF &= ~(1<<PF2);}
#define BANK_5 {PORTF |= (1<<PF4); PORTF &= ~(1<<PF3); PORTF |= (1<<PF2);}
#define BANK_6 {PORTF |= (1<<PF4); PORTF |= (1<<PF3); PORTF &= ~(1<<PF2);}
#define BANK_7 {PORTF |= (1<<PF4); PORTF |= (1<<PF3); PORTF |= (1<<PF2);}
void xram(void) __attribute__ ((naked)) __attribute__ ((section (".init1")));
void xram(void)
MCUCR |= (1<<SRE)|(1<<SRW10); // The SRE Bit will activate the memory interface of the ATmega128
// The SRW11 and SRW10 bits control
XMCRA |= (1<<SRW11); // the number of wait-states
XMCRB |= (1<<XMBK); // Enable the buskeeper, witch ensure a definied logic level
// on the lines AD7:0, otherwise they will be tri-stated
// Remember: if you disable the memory Interface, don´t forget
// to disable the buskeeper too.
//The function memwrite fills up a memorybank of the selected SRAM
//alternate with 0x55 and 0xaa
void memwrite(void)
unsigned char *pwrite = (unsigned char *) (OFFSET + 0); // Pointer to a unsigned char with the adress 0x1100
unsigned int count = 0;
for(count=0; count<= (0xFFFF-OFFSET); count++) // until the end of the memory
if(count%2) // odd memorycells
pwrite[count]=0x55;
else // even memorycells
pwrite[count]=0xaa;
//The function memread checks a memorybank of the selected SRAM
//if the cells has alternate values of 0x55 and 0xaa
unsigned int memread(void)
unsigned char *pread = (unsigned char *) (OFFSET + 0); // Pointer to a unsigned char with the adress 0x1100
unsigned char error = 0;
do
if(pread[count]!=0x55) // Memorycell dosen´t contain the desired value
error = 1;
if(pread[count]!=0xaa) // Memorycell dosen´t contain the desired value
error = 1;
count++;
}while((count<=(0xFFFF-OFFSET))&&(error == 0)); // Ends with error or the last memorycell
if(error)
return(count); // Memorycell "count" has a wrong value
// 1 <= count <= 0xef00
else
return(0); // no problems at all
//The function memtest uses the functions memwrite and memread.
//If the cells has a wrong value, it returns the number of the cell
//If there is no problem it returns a Zero
unsigned int memtest(void)
unsigned int i = 0;
memwrite();
i = memread();
return(i);
//The function error_diplay only shows the memorycell with the wrong value inside
void error_display(unsigned char SRAM, unsigned char BANK, unsigned int MEMORYCELL)
lcdi2c_ausgabexy("SRAM -> Bank ",0,0);
lcdi2c_ausgabenummer(SRAM, 5, 0);
lcdi2c_ausgabenummer(BANK, 15, 0);
lcdi2c_ausgabexy("Fehler beim Auslesen",0,1);
lcdi2c_ausgabexy("Speicherzelle: ",0,2);
lcdi2c_ausgabenummer(MEMORYCELL, 20, 2);
int main(void)
UCHAR x = 0;
unsigned int MEMORYCELL = 0;
i2c_init(); // initialitze the I2C-Bus
x = lcdi2c_init(); // checks the display
PORTF |= (0<<PF7)|(0<<PF6)|(0<<PF5)|(0<<PF4)|(0<<PF3)|(0<<P F2)|(1<<PF1)|(1<<PF0);
DDRF |= (0<<PF7)|(0<<PF6)|(0<<PF5)|(1<<PF4)|(1<<PF3)|(1<<P F2)|(1<<PF1)|(1<<PF0);
// Belegung PORTF
// PF0: /CE SRAM 1
// PF1: /CE SRAM 2
// PF2: Adressleitung 16
// PF3: Adressleitung 17
// PF4: Adressleitung 18
// PF5: Frei
// PF6: Frei
// PF7: Frei
SET_SRAM1
BANK_0
MEMORYCELL = memtest();
if(MEMORYCELL)
error_display( 1,0 , MEMORYCELL);
else
BANK_1
if(MEMORYCELL)
error_display( 1,1 , MEMORYCELL);
else
BANK_2
if(MEMORYCELL)
error_display( 1,2 , MEMORYCELL);
else
BANK_3
if(MEMORYCELL)
error_display( 1,3 , MEMORYCELL);
else
BANK_4
if(MEMORYCELL)
error_display( 1,4 , MEMORYCELL);
else
BANK_5
if(MEMORYCELL)
error_display( 1,5 , MEMORYCELL);
else
BANK_6
if(MEMORYCELL)
error_display( 1,6 , MEMORYCELL);
else
BANK_7
if(MEMORYCELL)
error_display( 1,7 , MEMORYCELL);
else
SET_SRAM2
BANK_0
if(MEMORYCELL)
error_display( 2,0 , MEMORYCELL);
else
BANK_1
if(MEMORYCELL)
error_display( 2,1 , MEMORYCELL);
else
BANK_2
if(MEMORYCELL)
error_display( 2,2 , MEMORYCELL);
else
BANK_3
if(MEMORYCELL)
error_display( 2,3 , MEMORYCELL);
else
BANK_4
if(MEMORYCELL)
error_display( 2,4 , MEMORYCELL);
else
BANK_5
if(MEMORYCELL)
error_display( 2,5 , MEMORYCELL);
else
BANK_6
if(MEMORYCELL)
error_display( 2,6 , MEMORYCELL);
else
BANK_7
if(MEMORYCELL)
error_display( 2,7 , MEMORYCELL);
else
lcdi2c_ausgabexy("Speicherzellen OK!",0,0); //Output on display
while(1)
Erfahrener Benutzer
Robotik Visionär
Sorry, dachte das das der gleiche Quellcode wie darüber ist (konnte es am smartphone nicht öffnen) .
1) das hat nichts mit Schrittmotoren zu tun
2) das ist nicht für einen Atmega 32 (der Atmega 32 hat keinen Port F)
MfG Hannes
- Neue Themen erstellen: Nein
- Themen beantworten: Nein
- Anhänge hochladen: Nein
- Beiträge bearbeiten: Nein
Foren-Regeln
