Ergebnis 21 bis 30 von 42
Thema: Asuro folgt der Linie
    Esslingen
    jetzt kommt der fehler
    -------- begin --------
    avr-gcc --version
    avr-gcc (GCC) 3.3.1
    Copyright (C) 2003 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions. There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    avr-gcc -c -mmcu=atmega8 -I. -g -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-ahlms=test.lst test.c -o test.o
    test.c: In function `main':
    test.c:12: error: parse error before '{' token
    test.c:6: warning: unused variable `lineData'
    test.c: At top level:
    test.c:19: error: parse error before '}' token
    make: *** [test.o] Error 1
    > Process Exit Code: 2
    #include "asuro.h"
    #define SPEED  0x8F
    int speedLeft,speedRight;
    unsigned int lineData[2];
    int ADOffset;
    void LineLeft (void)
       speedLeft  += 1;
       if (speedLeft > 0xFE) speedLeft = 0xFF;
    void LineRight (void)
       speedRight  += 1;
       if (speedRight > 0xFE) speedRight = 0xFF;
    int main(void)
    int i;
    unsigned char j;
       Init();
       FrontLED(ON);
       (;;while(1) (j = 0; j < 0xFF; j++) {
       LineData(lineData);}
       LineData(lineData);
       ADOffset = lineData[0] - lineData[1];
       speedLeft = speedRight = SPEED;
       (;;while(1) {
          LineData(lineData);
          i = (lineData[0] - lineData[1]) - ADOffset;
          if ( i > 4) {
             StatusLED(GREEN);
             LineLeft();
          else if ( i < -4) {
             StatusLED(RED);
             LineRight();
          else {
             StatusLED(OFF);
          MotorSpeed(speedLeft,speedRight);
       return(0);
    kompilier mal den code hier:
    #include "asuro.h"
    #define SPEED  0x8F
    int ADOffset;
    	speedLeft  += 1;
    	speedRight  += 1;
    int main(void)
    	int i;
    	unsigned char j;
    	Init();
    	FrontLED(ON);
    		LineData(lineData);
    		(;;while(1) {
    			LineData(lineData);
    			if ( i > 4) {
    				StatusLED(GREEN);
    				LineLeft();
    			else if ( i < -4) {
    				StatusLED(RED);
    				LineRight();
    			else {
    				StatusLED(OFF);
    		return 0;
    Hameln
    mal so ne kleine frage zum linienverfolger......
    wofür benutzt ihr folgenden code und was bedeutet er?
    hier der code:
    for (j = 0; j < 0xFF; j++) LineData(lineData);
    was haben die hexadezizahlen zu bedeuten? thx im voraus!
    MfG The-BooN-
    statt 0xFF kann man auch einfach 255 schreiben.
    manche leute machen sich das leben halt künstlich schwer
    Esslingen
    Danke für die Antwort
    Aber jetzt kommt ein Ar*** voll fehler:
    test.c -o test.o
    test.c:30: error: parse error before ';' token
    test.c:24: warning: unused variable `i'
    test.c:32: warning: type defaults to `int' in declaration of `LineData'
    test.c:32: warning: parameter names (without types) in function declaration
    test.c:32: error: conflicting types for `LineData'
    asuro.h:79: error: previous declaration of `LineData'
    test.c:32: warning: data definition has no type or storage class
    test.c:33: warning: type defaults to `int' in declaration of `ADOffset'
    test.c:33: error: initializer element is not constant
    test.c:33: warning: data definition has no type or storage class
    test.c:34: warning: type defaults to `int' in declaration of `speedLeft'
    test.c:34: error: initializer element is not constant
    test.c:34: warning: data definition has no type or storage class
    test.c:35: error: parse error before ';' token
    test.c:37: warning: type defaults to `int' in declaration of `i'
    test.c:37: error: initializer element is not constant
    test.c:37: warning: data definition has no type or storage class
    test.c:38: error: parse error before "if"
    test.c:40: warning: type defaults to `int' in declaration of `LineLeft'
    test.c:40: warning: function declaration isn't a prototype
    test.c:40: error: conflicting types for `LineLeft'
    test.c:11: error: previous declaration of `LineLeft'
    test.c:40: warning: data definition has no type or storage class
    test.c:41: error: parse error before '}' token
    test.c:44: warning: type defaults to `int' in declaration of `LineRight'
    test.c:44: warning: function declaration isn't a prototype
    test.c:44: error: conflicting types for `LineRight'
    test.c:17: error: previous declaration of `LineRight'
    test.c:44: warning: data definition has no type or storage class
    test.c:45: error: parse error before '}' token
    test.c:48: warning: type defaults to `int' in declaration of `speedLeft'
    test.c:48: error: redefinition of `speedLeft'
    test.c:34: error: `speedLeft' previously defined here
    test.c:48: error: initializer element is not constant
    test.c:48: warning: data definition has no type or storage class
    test.c:49: error: parse error before '}' token
    test.c:50: warning: type defaults to `int' in declaration of `MotorSpeed'
    test.c:50: warning: parameter names (without types) in function declaration
    test.c:50: error: conflicting types for `MotorSpeed'
    asuro.h:71: error: previous declaration of `MotorSpeed'
    test.c:50: warning: data definition has no type or storage class
    test.c:51: error: parse error before '}' token
    test.c:53:2: warning: no newline at end of file
    tja äh, manchmal zieht ein kleiner fehler einen gnazen rattenschnanz hinterher ich schu mal woran das liegt
    Esslingen
    Ok Danke LOL
    MfG MarkusH91
    der code hier müsste eigentlcih funktioniern (zumindest gibts keine fehlermeldungen)
    #include "asuro.h"
    #define SPEED  0x8F
    int ADOffset;
       speedLeft  += 1;
       speedRight  += 1;
    int main(void)
    int i;
    unsigned char j;
       Init();
       FrontLED(ON);
       for (j = 0; j < 0xFF; j++) {
       LineData(lineData);
       while (1) {
          LineData(lineData);
          if ( i > 4) {
             StatusLED(GREEN);
             LineLeft();
          else if ( i < -4) {
             StatusLED(RED);
             LineRight();
          else {
             StatusLED(OFF);
       return 0;
    keine garantie
  9. #29
    hier der code:
    MfG The-BooN-
    LineData(data) wird 255 (0FF) mal aufgerufen bzw. die FotoLEDs da vorne am Asuro ausgelesen.
  10. #30
    Mainz
    so wie ich das Programm verstehe, macht es keinen Sinn, 255 ( 0xFF = 255 dezimal) mal die Linedatas auszulesen. Für was, wenn es dann nicht verwendet wird?
    Die Anmerkung, daß mit dem Offset eine Kalibrierung stattfindet, war schon richtig. Besser wäre es, für jeden Sensor einen eigenen Offset zu ermitteln.
