hmm, scheint richtig zu sein.![]()
Aber ich habe hier einproblem
und bis vor kurzem hatte ich eigentlich auch kein avr-gcc und ich habe das eigentlich auch nicht wirklich installiert. evtl per klick auf das rpm, aber mei...Code:lamer FirstTry # emerge =dev-embedded/avr-libc-1.2.3 Calculating dependencies ...done! >>> emerge (1 of 1) dev-embedded/avr-libc-1.2.3 to / >>> md5 files ;-) ChangeLog >>> md5 files ;-) metadata.xml >>> md5 files ;-) avr-libc-1.2.3.ebuild >>> md5 files ;-) files/digest-avr-libc-1.2.3 >>> md5 src_uri ;-) avr-libc-1.2.3.tar.bz2 >>> Unpacking source... >>> Unpacking avr-libc-1.2.3.tar.bz2 to /var/tmp/portage/avr-libc-1.2.3/work >>> Source unpacked. creating cache ./config.cache checking host system type... avr-unknown-none checking target system type... avr-unknown-none checking build system type... i686-pc-linux-gnuaout checking for a BSD compatible install... /bin/install -c checking whether build environment is sane... yes checking whether make sets ${MAKE}... yes checking for working aclocal-1.4... found checking for working autoconf... found checking for working automake-1.4... found checking for working autoheader... found checking for working makeinfo... found checking for avr-as... no checking for as... as checking for avr-ar... no checking for ar... ar checking for avr-ranlib... no checking for ranlib... ranlib checking for avr-gcc... avr-gcc configure: error: Wrong assembler found; check the PATH! !!! ERROR: dev-embedded/avr-libc-1.2.3 failed. !!! Function src_compile, Line 30, Exitcode 1 !!! ./configure failed !!! If you need support, post the topmost build error, NOT this status message
-->wie bringe ich das jetzt zum laufen?
EDIT: zum portage:
Code:lamer FirstTry # esearch -S AVR [ Results for search key : AVR ] [ Applications found : 3 ] * dev-embedded/avr-libc [ Masked ] Latest version available: 1.2.3 Latest version installed: [ Not Installed ] Size of downloaded files: 309 kB Homepage: http://www.nongnu.org/avr-libc/ Description: Libc for the AVR microcontroller architecture License: GPL-2 * dev-embedded/avrdude Latest version available: 4.4.0 Latest version installed: [ Not Installed ] Size of downloaded files: 339 kB Homepage: http://www.nongnu.org/avrdude/ Description: AVR Downloader/UploaDEr License: GPL-2 * dev-embedded/uisp Latest version available: 20040311 Latest version installed: 20040311 Size of downloaded files: 139 kB Homepage: http://savannah.nongnu.org/projects/uisp Description: tool for AVR microcontrollers which can interface to many hardware in-system programmers License: GPL-2
Zitieren
