hallo, bei ausgabe des wertes "wert_1 = 34000" kommt im terminal "-31536"
zur anzeige. warum kommen die zahlen über "32000" als negative zahl
zur ausgabe.
mfg pebisoft
Code:#include <inttypes.h> #include <avr/io.h> #include <avr/interrupt.h> #include <avr/signal.h> #include <string.h> #include <delay_1.c> #include <stdint.h> #define READ 1 #define WRITE 2 #define USART_BAUD_RATE 19200 #define USART_BAUD_SELECT (F_CPU/(USART_BAUD_RATE*16l)-1) void usart_init(int Enable, int Interupts) { if (Enable & READ) UCSRB = (1<<RXEN); if (Enable & WRITE) UCSRB |= (1<<TXEN); if (Interupts & READ) UCSRB |= (1<<RXCIE); if (Interupts & WRITE) UCSRB |= (1<<TXCIE); UBRRL = (unsigned char) USART_BAUD_SELECT; } void usart_writeChar(unsigned char c) { while (!(UCSRA & (1<<UDRE))) {} UDR = c; while(!(UCSRA & (1<<TXC))) {} } void usart_writeString(unsigned char *string) { while (!(UCSRA & (1<<UDRE))) {} while ( *string) usart_writeChar(*string++); } int main (void) { char s[10]; uint16_t wert_1; usart_init( (READ + WRITE) , READ); wert_1=34000; itoa( wert_1, s, 10); while(1) { usart_writeString(s); usart_writeString("\r"); warte(20000); } }
Zitieren
