Ergebnis 1 bis 10 von 18
Thema: qt5 creator + designer: super simple graphic examples
Baum-Darstellung
  1. #14
    mainwindow.ui
    <?xml version="1.0" encoding="UTF-8"?>
    <ui version="4.0">
     <class>MainWindow</class>
     <widget class="QMainWindow" name="MainWindow">
      <property name="geometry">
       <rect>
        <x>0</x>
        <y>0</y>
        <width>474</width>
        <height>411</height>
       </rect>
      </property>
      <property name="windowTitle">
       <string>MainWindow</string>
      </property>
      <widget class="QWidget" name="centralWidget">
       <widget class="QPushButton" name="pushButton">
         <rect>
          <x>180</x>
          <y>300</y>
          <width>101</width>
          <height>31</height>
         </rect>
        </property>
        <property name="text">
         <string>Quit</string>
        </property>
       </widget>
       <widget class="MyWidget" name="widget" native="true">
         <rect>
          <x>10</x>
          <y>10</y>
          <width>451</width>
          <height>271</height>
         </rect>
        </property>
       </widget>
      </widget>
      <widget class="QMenuBar" name="menuBar">
        <rect>
         <x>0</x>
         <y>0</y>
         <width>474</width>
         <height>21</height>
        </rect>
       </property>
      </widget>
      <widget class="QToolBar" name="mainToolBar">
       <attribute name="toolBarArea">
        <enum>TopToolBarArea</enum>
       </attribute>
       <attribute name="toolBarBreak">
        <bool>false</bool>
       </attribute>
      </widget>
      <widget class="QStatusBar" name="statusBar"/>
      <widget class="QToolBar" name="toolBar">
        <string>toolBar</string>
       </property>
       </attribute>
        <bool>false</bool>
       </attribute>
      </widget>
      <action name="action">
        <string/>
       </property>
      </action>
     </widget>
     <layoutdefault spacing="6" margin="11"/>
     <customwidgets>
      <customwidget>
       <class>MyWidget</class>
       <extends>QWidget</extends>
       <header>mywidget.h</header>
       <container>1</container>
      </customwidget>
     </customwidgets>
     <resources/>
     <connections>
      <connection>
       <sender>pushButton</sender>
       <signal>clicked()</signal>
       <receiver>MainWindow</receiver>
       <slot>close()</slot>
       <hints>
        <hint type="sourcelabel">
         <x>234</x>
         <y>171</y>
        </hint>
        <hint type="destinationlabel">
         <x>260</x>
         <y>229</y>
        </hint>
       </hints>
      </connection>
     </connections>
    </ui>
    qt_btn_paint.pro
    # Project created by QtCreator 2019-09-16T12:09:00
    QT       += core gui
    greaterThan(QT_MAJOR_VERSION, 4): QT += widgets
    TARGET = GUI_app
    TEMPLATE = app
    # The following define makes your compiler emit warnings if you use
    # any feature of Qt which as been marked as deprecated (the exact warnings
    # depend on your compiler). Please consult the documentation of the
    # deprecated API in order to know how to port your code away from it.
    DEFINES += QT_DEPRECATED_WARNINGS
    # You can also make your code fail to compile if you use deprecated APIs.
    # In order to do so, uncomment the following line.
    # You can also select to disable deprecated APIs only up to a certain version of Qt.
    #DEFINES += QT_DISABLE_DEPRECATED_BEFORE=0x060000    # disables all the APIs deprecated before Qt 6.0.0
    SOURCES += main.cpp\
            mainwindow.cpp \
            mywidget.cpp
    HEADERS  += mainwindow.h \
        mywidget.h
    FORMS    += mainwindow.ui
    - - - Aktualisiert - - -
  1. Tipps Meine Software: LCD-Charakter-Creator
    Von pro-bot128 im Forum Offtopic und Community Tratsch
    Letzter Beitrag: 20.06.2011, 11:55
  2. Ks108 und Graphic Converter
    Von carfan im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 10.08.2008, 20:00
  3. Menü Creator
    Von guenter1604 im Forum Basic-Programmierung (Bascom-Compiler)
    Antworten: 15
    Letzter Beitrag: 02.08.2008, 09:12
  4. Antworten: 6
    Letzter Beitrag: 30.07.2007, 14:30
  5. PIC mit Graphic LCD
    Von chosn im Forum PIC Controller
    Letzter Beitrag: 02.06.2005, 11:20
