Hallo zusammen,
man findet ja leider nicht viel in AVR8ASM zu diesem Thema.
Muss TSM wirklich einmal seperat gesetzt werden ?
Würde es beim ATtiny13A nicht auch so reichen ?Code:Neustart2: ldi rmp,1<<TSM ; Prescaler Sync Mode out GTCCR,rmp ldi rmp,(1<<TSM)|(1<<PSR10) ; Reset Presc1 out GTCCR,rmp clr rmp out GTCCR,rmp ; Prescaler Count Mode out TCNT1H,rmp ; 16-Bit-Zaehler ruecksetzen out TCNT1L,rmp ldi rmp,1<<OCIE1A out TIMSK1,rmp ; in Timer-Int-Maske ret
oder gar so :Code:ldi rmp,1<<TSM|1<<PSR10 out GTCCR,rmp clr rmp out GTCCR,rmp out TCNT0,rmp
Raffe dass Englische nämlich nicht, trotz Google-Übersetzers, wegen demCode:ldi rmp,1<<TSM out GTCCR,rmp clr rmp out GTCCR,rmp out TCNT0,rmp
letzten Satz :
• Bit 7 – TSM: Timer/Counter Synchronization Mode
Writing the TSM bit to one activates the Timer/Counter Synchronization
mode. In this mode, the value that is written to the PSR10 bit is kept,
hence keeping the Prescaler Reset signal asserted. This ensures that the
Timer/Counter is halted and can be configured without the risk of
advancing during configuration. When the TSM bit is written to zero, the
PSR10 bit is cleared by hardware, and the Timer/Counter start counting.
• Bit 0 – PSR10: Prescaler Reset Timer/Counter0
When this bit is one, the Timer/Counter0 prescaler will be Reset.
*This bit is normally cleared immediately by hardware, except if the TSM
bit is set.*
Bernd_Stein
Zitieren
