Seite 2 von 10 ErsteErste 1234 ... LetzteLetzte
Ergebnis 11 bis 20 von 97
Thema: esp8266, Arduino IDE: neuer Versuch: warum wird website sofort beendet?
    HaWe
    bool authorized=false;
    void handleNotAuthorized() {
      String readString = "";
      char   strinput[MAXLEN], strupwd[TOKLEN], struname[TOKLEN] ;
      WiFiClient client = wifiserver.available();
      // debug
      // authorized=true;
      strcpy(strinput, "");
      strcpy(strupwd, "");
      strcpy(struname, "");
      while ( client.connected() ) {
        if (authorized) return;
        if ( client.available() ) {
          char c = client.read();
          //read char by request
          readString = "";
          while ( (readString.length() < TOKLEN) && (c != '\n') ) {
              readString += c;
              c = client.read();
          readString.toCharArray(strinput, MAXLEN);
          // cstringarg(strinput, "uname", struname); // uname
          // cstringarg(strinput, "upwd", strupwd);  // upwd
          if(strstr(website_upwd,strupwd)!=NULL & strstr(website_uname,struname)!=NULL)
            authorized = true;
            readString = "";
            return;
            // return;  // <<< selbes Ergebnis, egal ob kommentiert oder auskommentiert
          //if HTTP request has ended
          if (c == '\n') {
            //now output html data header
            String script = "";
            script += ("HTTP/1.1 200 OK \n");
            script += ("Content-Type: text/html \n");
            script += ("\n");  //  do not forget this one //????
            script += ("<!DOCTYPE html> \n");
            script += ("<html> \n");
            script += ("<head> \n");
            // utf-8 für "°" Zeichen
            script +=  "<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\"> \n" ;
            script +=  "<title>" ;
            script +=  "</title> \n" ;
            script +=  "</head> \n" ;
            script +=  "<body> \n" ;
            script += ("<h2><p style=\"color:rgb(255,0,191);\"> log in to proceed: </p> </h2> \n");
            script += ("<FORM ACTION='/' method=GET > \n");
            script += ("<h2>user name:  <INPUT TYPE=text NAME='uname' VALUE=''  MAXLENGTH='50'> </h2> \n");
            script += ("<h2>password :  <INPUT TYPE=PASSWORD NAME='upwd' VALUE='' MAXLENGTH='50'> </h2> \n");
            script += ("<h2><INPUT TYPE=SUBMIT></h2> \n");
            script += ("</FORM> \n");
            script += ("<BR> \n");
            script += ("</body> \n");
            script += ("</html> \n");
            client.print(script);
            while(client.connected()) {
               delay(10);
               while(client.available()) {
                  Serial.write(client.read());
            delay(100);
            client.stop();   // edited
            //clearing string for next read
            //readString = "";
        delay(1);
    jaaa...!
    das hat jetzt zum ersten Mal gefunzt! Bild
    Das werde ich jetzt ausgiebig testen und dann berichten!
    Tausend Dank auf jeden Fall schon einmal an euch beide!
    Geändert von HaWe (21.10.2019 um 16:16 Uhr)
    weit weg von nahe Bonn
    JETZT hast du dein client.close() allerdings auch entfernt, was zu "socketverstopfung" führen kann.
    nicht.
    HaWe
    ach so, ich dachte, der soll auch mit weg?
    soll der auch direkt dahinter?
           delay(100);
           client.stop();
    - - - Aktualisiert - - -
    PS,
    habe es mal so gemacht,
    einziger "Schönheitsfehler" jetzt noch: ich muss immer 2x hintereinander auf den "Daten absenden"-Button klicken (oder ENTER-Taste), damit usrname+pwd übertragen werden, aber nach dem 2. mal klappt es jetzt (ohne client.stop() war es auch schon so).
    auch wenn ich die while-Schleife ersetze durch
              delay(10);
              /* while(client.available()) {
    ändert sich das nicht.
    (Serial ist ja stand-allone nicht mehr verfügbar!)
    Geändert von HaWe (21.10.2019 um 12:42 Uhr)
    Ich denke:
    Du müsstest Dich entscheiden, ob die Connection zum Client bestehen bleibt oder geschlossen wird.
    Jetzt kannst Du mittels client mit dem Browser kommunizieren, der eine Verbindung hergestellt hat.
    Die Verbindung sollte jetzt bestehen.
    Da Du das jedesmal machst, wenn ein Datenaustausch mit dem Client statt gefunden hat, müsstest Du die Verbindung beenden, s. client.stop().
    Der Client, also der Browser soll aber wohl wissen müssen, was passieren wird. Dazu sendest Du einen Header:
    In diesem steht aber nicht, dass die Connection geschlossen werden soll.
    Vielleicht mal mit einem korrekten Header anfangen:
            script += ("HTTP/1.1 200 OK\r\n");
            script += ("Content-Type: text/html\r\n");
            script += ("Connection: close\r\n");
    Von vorne:
    Zuerst mit WiFiClient client = wifiserver.available(); ein Objekt holen, dass Kommunikation mit dem Browser erlaubt (Browser hat Connection hergestellt). Das kannst Du zur Not mit if(client)... überprüfen.
    Dann prüfen, ob der Browser Daten gesendet hat und diese alle einlesen und verarbeiten.
    Wenn fest steht, was er gesendet hat und die Daten (User und Passwort) richtig waren, dann die Seitendaten senden (inkl. dem Header wie oben).
    Nach dem Datentransfer dem Browser mit delay(x) etwas Zeit geben, die Daten zu empfangen.
    Dann, am Schluss, zum Schließen der Connection client.stop() verwenden.
    Geändert von Moppi (21.10.2019 um 10:58 Uhr)
    HaWe
    Zitat Zitat von Moppi Beitrag anzeigen
    Ich denke:
    Von vorne:
    habe ich ja schon ganz oben im Code stehen.
    Ich habe nun die alten 3 Codezeilen durch die 3 neuen ersetzt, allerdings baut er jetzt gar keine website mehr auf - was habe ich übersehen? (ggf: wie lautet der komplette neue Code, falls nicht nur 1 Zeile betroffen ist?)
    ich habs mal etwas umgestellt - versuch das mal:
      if (client) {
              // debug
              // authorized=true;
                  readString = "";
                      readString += c;
                      c = client.read();
                    authorized = true;
                    readString = "";
                    return;
                  if (c == '\n') {
                     //client.flush();
                    String script = "";
                    client.println(script);
                    delay(100);
                    //stopping client
                    client.stop();
                    //readString = "";
                //delay(1);
    HaWe
    leider springt er jetzt sofort wieder raus, wie ganz am Anfang,
    und wenn ich einsetze vor client.stop();
              //stopping client
                 delay(10);
              client.stop();
    dann baut er sie auf, beibt aber ewig drin hängen, auch nach korrektem login+pwd Bild
    strupwd und struname werden doch überhaupt nicht aus dem gelesenen String readString extrahiert, aber anschließend verglichen und dann davon abhängig gemacht, ob authorized = true;
    Das haut irgendwie hinten und vorne noch nicht hin.
    HaWe
    dieser Teil mit der Extrahierung von strupwd und struname ist hier nur verkürzt wiedergegeben, um die Lesbarkeit zu erhöhen, meine eigene Methode ist recht kompliziert.
    Wie würdest DU diese Extrahierung samt Vergleich machen, und, wo wir gerade dabei sind, ggf. mit POST anstelle von GET?
    Vieleicht liegt ja tatsächlich hier der Hase im Pfeffer...?
    ich habs nochmals geändert und ein Schnipsel eingefügt:
      if (client) {
              // debug
              // authorized=true;
                  readString = "";
                      readString += c;
                      c = client.read();
                    authorized = true;
                    readString = "";
                    return;
                  while ( c != '\n') {
                      c = client.read();
                  if (c == '\n') {
                     //client.flush();
                    String script = "";
                    delay(100);
                    //stopping client
                    client.stop();
                    //readString = "";
                //delay(1);
    entscheidend ist, dass die Seite jedesmal angezeigt wird, wenn der Browser eine Anfrage an den Server stellt. Denn erst dann kann man das Passwort eingeben und den Namen, was dann ausgewertet werden muss.
    Ob das Passwort stimmt oder ob der Vergleich dazu hinhaut wissen wir nicht, weil der Teil fehlt. Man kann das umschreiben, ich habe aber nicht die Möglichkeit, das mit 2.5.x zu probieren - glaub ich.
    Muss mal sehen. Das kann so schwer nicht sein.
  1. arduino ide mit esp8266
    Von NotEvil im Forum NodeMCU-Board und ESP8266, ESP32-Serie
    Letzter Beitrag: 12.01.2017, 14:17
  2. Raspberry Pi 3: Neuer Bastelrechner ist ab sofort verfügbar
    Letzter Beitrag: 29.02.2016, 20:56
  3. [ERLEDIGT] Google wird am Lenovo-Tablet ohne Zutun beendet
    Von oberallgeier im Forum Offtopic und Community Tratsch
    Letzter Beitrag: 24.11.2015, 08:02
  4. Funktion wird nicht richtig beendet
    Von kowolfgang im Forum C - Programmierung (GCC u.a.)
    Antworten: 16
    Letzter Beitrag: 31.12.2008, 16:37
  5. schieberegister neuer versuch...
    Von Bluesmash im Forum Basic-Programmierung (Bascom-Compiler)
    Antworten: 12
    Letzter Beitrag: 11.07.2005, 21:10
