Ergebnis 1 bis 10 von 35
Thema: std::thread für ESP32 unter Arduino IDE zum Laufen zu kriegen...?
    HaWe
    hahahaha, ich lach mich tot..... Bild
    JA!!!
    sogar ohne static und ohne thread_local:
    #include <Arduino.h>
    #include <thread>
    #include <chrono>
    #ifndef LED_BUILTIN
    #define LED_BUILTIN 13
    #endif
    const auto one_sec = std::chrono::seconds
        1
    void counter_loop() {
        uint32_t counter = 0;
        while(true) {
            Serial.print("counter_loop: ");
            Serial.println(counter);
            std::this_thread::sleep_for(one_sec);
            counter++;
    void blinker_loop() {
        while(true) {
            digitalWrite(LED_BUILTIN, HIGH);
            Serial.print("blinker_loop (HIGH) counter: ");
            digitalWrite(LED_BUILTIN, LOW);
            Serial.print("blinker_loop (LOW) counter: ");
            counter++;
    std::thread counter_loop_thread(counter_loop);
    std::thread blinker_loop_thread(blinker_loop);
    void setup() {
        Serial.begin(115200);
        pinMode(LED_BUILTIN, OUTPUT);
    uint32_t main_loop_counter = 0;
    void loop() {
        main_loop_counter++;
        Serial.print("main loop: ");
        Serial.println(main_loop_counter);
        delay(10000);
    main loop: 1
    counter_loop: 1
    blinker_loop (LOW) counter: 0
    blinker_loop (HIGH) counter: 1
    counter_loop: 2
    counter_loop: 3
    blinker_loop (LOW) counter: 1
    blinker_loop (HIGH) counter: 2
    counter_loop: 4
    counter_loop: 5
    blinker_loop (LOW) counter: 2
    blinker_loop (HIGH) counter: 3
    counter_loop: 6
    counter_loop: 7
    blinker_loop (LOW) counter: 3
    blinker_loop (HIGH) counter: 4
    counter_loop: 8
    counter_loop: 9
    blinker_loop (LOW) counter: 4
    blinker_loop (HIGH) counter: 5
    counter_loop: 10
    main loop: 2
    counter_loop: 11
    blinker_loop (LOW) counter: 5
    blinker_loop (HIGH) counter: 6
    counter_loop: 12
    counter_loop: 13
    blinker_loop (LOW) counter: 6
    blinker_loop (HIGH) counter: 7
    counter_loop: 14
    counter_loop: 15
    blinker_loop (LOW) counter: 7
    blinker_loop (HIGH) counter: 8
    counter_loop: 16
    counter_loop: 17
    blinker_loop (LOW) counter: 8
    blinker_loop (HIGH) counter: 9
    counter_loop: 18
    counter_loop: 19
    blinker_loop (LOW) counter: 9
    blinker_loop (HIGH) counter: 10
    counter_loop: 20
    main loop: 3
    counter_loop: 21
    vielen Dank an euch beide, das ist jetzt echt ne super Basis um weiterzumachen!
    Ein Riesen-Schritt für die Menschheit!
    großartig, danke!
    weit weg von nahe Bonn
    wie gesagt, thread_local ist garnicht falsch, erspart dir später womöglich kuriose bugs ... ich würde es immer drin lassen!
    nicht.
    HaWe
    okidoki, danke!
    - - - Aktualisiert - - -
    PS,
    interessanter Effekt, gerade bemerkt:
    in der blinker_loop zählt der counter zwischen den sleeps und dem LED ON/OFF-Paar weiter, obwohl ich hier denselben counterwert für ON und OFF erwartet hätte, bis zum nächsten loop-Durchlauf für das nächste ON/OFF-Paar
    hast du dazu einen aktualisierten code ?
    nicht.
    HaWe
    ist immer noch der von #7 !
    gerade getestet:
    thread_local uint32_t counter = 0;
    macht hier auch keinen Unterschied
    ja ... sorry ... hab ich nicht gesehen
    interessante ausgabe, gebe ich zu ... es wäre mal interessant zu erfahren wie der zeitliche ablauf bei der ausgabe aussieht! ich vermute hier das problem!
    benutze mal irgend einen timer mit einer auflösung im wenigstens 100tel Sekunden bereich und speichere vor und nach jedem sleep jeweils einmal die zeit und gib die zeiten plus die aktuelle zeit auch als print aus
    also quasi print("Jetzt: %d Vorher: %d Nachher %d",timer.now(), beforesleep, aftersleep)
    so kann man erstmal prüfen ob der sleep vernünftig funktioniert und dann ob der print hier irgendwelche delays verursacht
    ich denke dass die ausgaben bei dir nicht chronologisch korrekt ausgegeben werden
    nicht.
    HaWe
    hmmm... könnte vlt...
    andererseits wird in den blinker_thread zwischen dem ON/OFF-Paar gar nicht inkrementiert, also egal, wann das ausgegeben wird, es müsste 1 ON/OFF-Paar IMO erwartungsgemäß IMMER mit demselben gemeinsamen counter-Wert erscheinen...
    ...oder?
    HaWe
    update:
    mutex ist doch drin, braucht nur zusätzlich
    #include <mutex>
    was ich nicht wusste,
    dann klappt jetzt auch
    std::mutex print_mutex;
    void myPrint(String str) // String: Arduino API  // C++: std::string
        print_mutex.lock();
        Serial.println(str);
        print_mutex.unlock();
    HaWe
    es gibt hier noch einen Bug oder Issue, wie man thread prios richtig setzt - bisher brachten alle Vorschläge noch keine Lösung.
    Man muss nämlich die thread prios der main loop prio angleichen, wenn beide ohne delays parallel laufen sollen
    (std::threads laufen nämlich per prio=5 per default, main loop nur bei default prio=1!!):
    esp_pthread_cfg_t cfg;
      esp_pthread_get_cfg(&cfg);
      cfg.prio=1;
      esp_pthread_set_cfg(&cfg);
    funktioniert nicht, weil anfangs cfg noch keine Werte enthält und daher einen Fehler zurückgibt,
    und
      if (esp_pthread_get_cfg(&cfg) != ESP_OK) {
          cfg = esp_pthread_get_default_config();
      cfg.prio=1;
      if (esp_pthread_set_cfg(&cfg) != ESP_OK) {
          printf("esp_pthread_set_cfg failed\n");
          abort();
    funktioniert auch nicht, weil die hier verwendete Funktion
    nicht gefunden wird.
    siehe Topic-Posts u.a.
    https://github.com/espressif/ESP8266...SDK/issues/609
    https://github.com/espressif/esp-idf...ment-496157019
    und folgende...
    betroffene libs am ehesten wohl
    https://github.com/espressif/ESP8266...ts/pthread/src
    Hat jemand eine idee, wie es richtig geht?
    Geändert von HaWe (29.05.2019 um 08:02 Uhr)
    HaWe
    update:
    der ESP32 scheduler arbeitet tatsächlich nur eingeschränkt preemptiv, u.a. da er vom FreeRTOS und seinem Watchdog abhängig ist, der nur begrenzt ausgeblendet/resetted werden kann,sobad ein Thread "stalled", und dann das gesamte System sich aufhängt.
    Außerdem scheint es dann auch Probleme mit threads zu geben, die auf den 2 cores laufen und dann (IIUC) ebenfalls zu Konflikten führen.
    update:
    trotz hoffnungsvoller Nachrichten in ESP32 github repo: noch immer nicht gelöst
    Geändert von HaWe (30.07.2019 um 10:17 Uhr)
  1. Esp32 a2dp in arduino IDE
    Von Flos6323 im Forum Elektronik
    Letzter Beitrag: 27.06.2018, 15:28
  2. Installation des Arduino Core für ESP32 ohne GIT
    Von mischaka im Forum NodeMCU-Board und ESP8266, ESP32-Serie
    Letzter Beitrag: 26.04.2018, 07:20
  3. Arduino Cinque: RISC-V-Prozessor und ESP32 auf einem Board vereint
    Letzter Beitrag: 22.05.2017, 16:29
  4. Display für esp32?
    Von NotEvil im Forum NodeMCU-Board und ESP8266, ESP32-Serie
    Antworten: 7
    Letzter Beitrag: 04.12.2016, 16:37
  5. Kugelgelenke - woher kriegen?
    Von Gottfreak im Forum Mechanik
    Antworten: 15
    Letzter Beitrag: 04.01.2005, 17:56
