Ergebnis 1 bis 10 von 35
Thema: std::thread für ESP32 unter Arduino IDE zum Laufen zu kriegen...?
    HaWe
    update: der Code jetzt hier scheint besser zu laufen:
    > counter_loop: 0
    > blinker_loop (HIGH) counter: 0
    > main loop: 1
    > blinker_loop (LOW) counter: 0
    > counter_loop: 1
    > counter_loop: 2
    > blinker_loop (HIGH) counter: 1
    > blinker_loop (LOW) counter: 1
    > counter_loop: 3
    > counter_loop: 4
    > blinker_loop (HIGH) counter: 2
    > blinker_loop (LOW) counter: 2
    > counter_loop: 5
    > counter_loop: 6
    > blinker_loop (HIGH) counter: 3
    > blinker_loop (LOW) counter: 3
    > counter_loop: 7
    > counter_loop: 8
    > blinker_loop (HIGH) counter: 4
    > blinker_loop (LOW) counter: 4
    > counter_loop: 9
    > counter_loop: 10
    > blinker_loop (HIGH) counter: 5
    > main loop: 2
    > blinker_loop (LOW) counter: 5
    > counter_loop: 11
    > counter_loop: 12
    > blinker_loop (HIGH) counter: 6
    > blinker_loop (LOW) counter: 6
    > counter_loop: 13
    > counter_loop: 14
    > blinker_loop (HIGH) counter: 7
    > blinker_loop (LOW) counter: 7
    > counter_loop: 15
    > counter_loop: 16
    > blinker_loop (HIGH) counter: 8
    > blinker_loop (LOW) counter: 8
    > counter_loop: 17
    > counter_loop: 18
    > blinker_loop (HIGH) counter: 9
    > blinker_loop (LOW) counter: 9
    > counter_loop: 19
    > counter_loop: 20
    > blinker_loop (HIGH) counter: 10
    > main loop: 3
    > blinker_loop (LOW) counter: 10
    code:
    // std::thread for ESP32, Arduino IDE
    #include <Arduino.h>
    #include <thread>
    #include <chrono>
    #ifndef LED_BUILTIN
    #define LED_BUILTIN 13
    #endif
    const auto one_sec = std::chrono::seconds
        1
    void counter_loop() {
        thread_local uint32_t counter = 0;
        while(true) {
            Serial.print("counter_loop: ");
            Serial.println(counter);
            std::this_thread::sleep_for(one_sec);
            counter++;
    void blinker_loop() {
        while(true) {
            digitalWrite(LED_BUILTIN, HIGH);
            Serial.print("blinker_loop (HIGH) counter: ");
            digitalWrite(LED_BUILTIN, LOW);
            Serial.print("blinker_loop (LOW) counter: ");
            counter++;
    std::unique_ptr<std::thread>  counter_loop_thread;
    std::unique_ptr<std::thread>  blinker_loop_thread;
    void setup() {
      Serial.begin(115200);
      //debug
      delay(2000);
      counter_loop_thread.reset(new std::thread(counter_loop));
      blinker_loop_thread.reset(new std::thread(blinker_loop));
    uint32_t main_loop_counter = 0;
    void loop() {
        main_loop_counter++;
        Serial.print("main loop: ");
        Serial.println(main_loop_counter);
        delay(10000);
    - - - Aktualisiert - - -
    update2:
    gleich gutes Ergebnis bei dieser Code-Implementierung:
    std::thread *counter_loop_thread;
    std::thread *blinker_loop_thread;
    void setup() {
      //debug
      delay(2000);
      counter_loop_thread = new std::thread(counter_loop);
      blinker_loop_thread = new std::thread(blinker_loop);
    Geändert von HaWe (24.05.2019 um 16:18 Uhr)
    shedepe
    Was du suchst ist ein std::mutex (in der Hoffnung dass der implementiert wurde). Ein Mutex ist eine Synchronisierungsobjekt zwischen Threads.
    D.h. du brauchst in etwas sowas:
    std::mutex m_lock;
    void myWrite(std::string str)
        m_lock.lock();
        Serial.print(str);
        m_lock.unlock();
    HaWe
    std::mutex m_lock;
        m_lock.lock();
        Serial.print(str);
        m_lock.unlock();
    danke für den wertvollen Tipp, das ist sehr hilfreich!
    Für den Augenblick geht es ja auch ohne (s. Serial logs), aber wenn es mal zeitkritischer wird: auf jeden Fall dann!
    Danke!
    Ich gucke später auch mal, ob der tatsächlich implementiert wurde!
    PS:
    auch für dich fände ich es klasse, wenn du dir mal ne portable IDE installieren könntest! Bild
  1. Esp32 a2dp in arduino IDE
    Von Flos6323 im Forum Elektronik
    Letzter Beitrag: 27.06.2018, 15:28
  2. Installation des Arduino Core für ESP32 ohne GIT
    Von mischaka im Forum NodeMCU-Board und ESP8266, ESP32-Serie
    Letzter Beitrag: 26.04.2018, 07:20
  3. Arduino Cinque: RISC-V-Prozessor und ESP32 auf einem Board vereint
    Letzter Beitrag: 22.05.2017, 16:29
  4. Display für esp32?
    Von NotEvil im Forum NodeMCU-Board und ESP8266, ESP32-Serie
    Antworten: 7
    Letzter Beitrag: 04.12.2016, 16:37
  5. Kugelgelenke - woher kriegen?
    Von Gottfreak im Forum Mechanik
    Antworten: 15
    Letzter Beitrag: 04.01.2005, 17:56
