Ergebnis 1 bis 10 von 49
Thema: Wii Nunchuck an Arduino
Baum-Darstellung
  1. #3
    HaWe
    leider auch nicht, gibt auch nur:
    2 joy:255,255 acc:258,258,258 but:1,1
    3 joy:255,255 acc:258,258,258 but:1,1
    4 joy:255,255 acc:258,258,258 but:1,1
    5 joy:255,255 acc:258,258,258 but:1,1
    6 joy:255,255 acc:258,258,258 but:1,1
    7 joy:255,255 acc:258,258,258 but:1,1
    8 joy:255,255 acc:258,258,258 but:1,1
    9 joy:255,255 acc:258,258,258 but:1,1
    10 joy:255,255 acc:258,258,258 but:1,1
    11 joy:255,255 acc:258,258,258 but:1,1
    12 joy:255,255 acc:258,258,258 but:1,1
    13 joy:255,255 acc:258,258,258 but:1,1
    14 joy:255,255 acc:258,258,258 but:1,1
    15 joy:255,255 acc:258,258,258 but:1,1
    und zwischendurch mal völlig unmotoviert, ohne mein Zutun:
    113 joy:255,255 acc:255,255,170 but:0,0
    114 joy:0,0 acc:0,0,0 but:0,0
    115 joy:0,0 acc:0,1,164 but:0,0
    116 joy:0,0 acc:0,0,0 but:0,0
    117 joy:0,3 acc:0,0,0 but:0,0
    118 joy:0,0 acc:0,0,0 but:0,0
    119 joy:0,0 acc:3,258,258 but:1,1
    120 joy:255,255 acc:258,258,258 but:1,1
    #include <Wire.h>;
    void setup(){
       Serial.begin(115200);
       //nunchuck_setpowerpins();
       nunchuck_init();
       Serial.print("Nunchuck ready\n");
    void loop(){
       nunchuck_get_data();
       nunchuck_print_data();
       delay(1000);
    //Do not modify!!!!!!!!
    // Nunchuck functions
    static uint8_t nunchuck_buf[6]; // array to store nunchuck data,
    // Uses port C (analog in) pins as power & ground for Nunchuck
    static void nunchuck_setpowerpins() {
       #define pwrpin PC3
       #define gndpin PC2
       DDRC |= _BV(pwrpin) | _BV(gndpin);
       PORTC &=~ _BV(gndpin);
       PORTC |= _BV(pwrpin);
       delay(100); // wait for things to stabilize
    // initialize the I2C system, join the I2C bus,
    // and tell the nunchuck we're talking to it
    void nunchuck_init()
       Wire.begin(); // join I2C bus as master
       Wire.beginTransmission(0x52); // transmit to device 0x52
       Wire.write(0x40); // sends memory address
       Wire.write(0x00); // sends sent a zero.
       Wire.endTransmission(); // stop transmitting
       byte cnt;
       uint8_t ctrlr_type[6];
       Wire.begin();
    // init controller
    delay(1);
    Wire.beginTransmission(0x52);      // device address
    Wire.write(0xF0);                    // 1st initialisation register
    Wire.write(0x55);                    // 1st initialisation value
    delay(1);
    Wire.write(0xFB);                    // 2nd initialisation register
    Wire.write(0x00);                    // 2nd initialisation value
    delay(1);
    // read the extension type from the register block
    Wire.write(0xFA);                    // extension type register
    Wire.requestFrom(0x52, 6);               // request data from controller
    for (cnt = 0; cnt < 6; cnt++) {
       if (Wire.available()) {
           ctrlr_type[cnt] = Wire.read(); // Should be 0x0000 A420 0101 for Classic Controller, 0x0000 A420 0000 for nunchuck
    delay(1);
    // send the crypto key (zeros), in 3 blocks of 6, 6 & 4.
    Wire.write(0xF0);                    // crypto key command register
    Wire.write(0xAA);                    // sends crypto enable notice
    delay(1);
    Wire.write(0x40);                    // crypto key data address
       Wire.write(0x00);                    // sends 1st key block (zeros)
    for (cnt = 6; cnt < 12; cnt++) {
       Wire.write(0x00);                    // sends 2nd key block (zeros)
    for (cnt = 12; cnt < 16; cnt++) {
       Wire.write(0x00);                    // sends 3rd key block (zeros)
    delay(1);
    // end device init
    // Send a request for data to the nunchuck
    // was "send_zero()"
    void nunchuck_send_request() {
       Wire.write(0x00); // sends one byte
    // Receive data back from the nunchuck,
    // returns 1 on successful read. returns 0 on failure
    int nunchuck_get_data() {
       int cnt=0;
       Wire.requestFrom (0x52, 6); // request data from nunchuck
       while (Wire.available ()) {
       // receive byte as an integer
       nunchuck_buf[cnt] = nunchuk_decode_byte(Wire.read());
       cnt++;
    nunchuck_send_request(); // send request for next data payload
    // If we recieved the 6 bytes, then go print them
       if (cnt >= 5) {
         return 1; // success
       return 0; //failure
    // Print the input data we have recieved
    // accel data is 10 bits long
    // so we read 8 bits, then we have to add
    // on the last 2 bits. That is why I
    // multiply them by 2 * 2
    void nunchuck_print_data() {
       static int i=0;
       int joy_x_axis = nunchuck_buf[0];
       int joy_y_axis = nunchuck_buf[1];
       int accel_x_axis = nunchuck_buf[2]; // * 2 * 2;
       int accel_y_axis = nunchuck_buf[3]; // * 2 * 2;
       int accel_z_axis = nunchuck_buf[4]; // * 2 * 2;
       int z_button = 0;
       int c_button = 0;
       // byte nunchuck_buf[5] contains bits for z and c buttons
       // it also contains the least significant bits for the accelerometer data
       // so we have to check each bit of byte outbuf[5]
       if ((nunchuck_buf[5] >> 0) & 1)
       z_button = 1;
       if ((nunchuck_buf[5] >> 1) & 1)
       c_button = 1;
       if ((nunchuck_buf[5] >> 2) & 1)
       accel_x_axis += 2;
       if ((nunchuck_buf[5] >> 3) & 1)
       accel_x_axis += 1;
       if ((nunchuck_buf[5] >> 4) & 1)
       accel_y_axis += 2;
       if ((nunchuck_buf[5] >> 5) & 1)
       accel_y_axis += 1;
       if ((nunchuck_buf[5] >> 6) & 1)
       accel_z_axis += 2;
       if ((nunchuck_buf[5] >> 7) & 1)
       accel_z_axis += 1;
       Serial.print(i,DEC);
       Serial.print("\t");
       Serial.print("joy:");
       Serial.print(joy_x_axis,DEC);
       Serial.print(",");
       Serial.print(joy_y_axis, DEC);
       Serial.print(" \t");
       Serial.print("acc:");
       Serial.print(accel_x_axis, DEC);
       Serial.print(",");
       Serial.print(accel_y_axis, DEC);
       Serial.print(",");
       Serial.print(accel_z_axis, DEC);
       Serial.print("\t");
       Serial.print("but:");
       Serial.print(z_button, DEC);
       Serial.print(",");
       Serial.print(c_button, DEC);
       Serial.print("\r\n"); // newline
       i++;
    // Encode data to format that most wiimote drivers except
    // only needed if you use one of the regular wiimote drivers
    char nunchuk_decode_byte (char x) {
       x = (x ^ 0x17) + 0x17;
       return x;
    // returns zbutton state: 1=pressed, 0=notpressed
    int nunchuck_zbutton() {
       return ((nunchuck_buf[5] >> 0) & 1) ? 0 : 1; // voodoo
    int nunchuck_cbutton()  {
       return ((nunchuck_buf[5] >> 1) & 1) ? 0 : 1; // voodoo
    // returns value of x-axis joystick
    int nunchuck_joyx()  {
       return nunchuck_buf[0];
    // returns value of y-axis joystick
    int nunchuck_joyy()  {
       return nunchuck_buf[1];
    // returns value of x-axis accelerometer
    int nunchuck_accelx()  {
       return nunchuck_buf[2]; // FIXME: this leaves out 2-bits of the data
    // returns value of y-axis accelerometer
    int nunchuck_accely()  {
       return nunchuck_buf[3]; // FIXME: this leaves out 2-bits of the data
    // returns value of z-axis accelerometer
    int nunchuck_accelz()  {
       return nunchuck_buf[4]; // FIXME: this leaves out 2-bits of the data
    Geändert von HaWe (29.03.2019 um 13:04 Uhr)
  1. Wii Nunchuck I2C an Raspberry Pi
    Von wassy92x im Forum Allgemeines zum Thema Roboter / Modellbau
    Letzter Beitrag: 27.01.2015, 15:24
  2. Nunchuck auslesen
    Von Snaper im Forum Sensoren / Sensorik
    Antworten: 12
    Letzter Beitrag: 28.02.2012, 09:45
  3. Wii Motion Plus - Nunchuck Passthrough Mode
    Von Che Guevara im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 19.10.2011, 19:36
  4. Nunchuck mit Gyroskopen
    Von RobertM im Forum Microcontroller allgemeine Fragen/Andere Microcontroller
    Letzter Beitrag: 21.12.2008, 16:40
  5. Nunchuck über i2c Ausleseprobleme (wohl Nunchukseitig)
    Von ustech im Forum AVR Hardwarethemen
    Letzter Beitrag: 05.10.2008, 23:56
