Ergebnis 1 bis 10 von 49
Thema: Wii Nunchuck an Arduino
    HaWe
    die Zeile finde ich nicht...
     *  Nunchuk auslesen
     *  funktioniert mit original Nunchuck
     *  UND mit Wirelesse Nunchuck
     *  Pinbelegung:
     *      3.3V  (Kabel rot)
     *      GND   (Kabel weiß)
     *      A4    (Kabel grün)
     *      A5    (Kabel gelb)
    #include <Wire.h>
    const int dataLength = 6;             //  numer ob bytes to request
    static byte rawData[dataLength];      //  array to store nunchuck data
    //  construct to create an enumerated list of the sonsor values returned from the nunchuck
    enum nunchuckItems  {  joyX, joyY, accelX, accelY, accelZ, btnZ, btnC };
    void setup()
        Serial.begin(57600);
        delay(500);
        Serial.println("Labels,Xjoy,Yjoy,Xaccel,Yaccel,Zaccel,Z-btn,C-btn,");
        delay(500);
        nunchuckInit();
    void loop()
      if (nunchuckRead() == true)
        Serial.print("Data,");          // Data-Header
        Serial.print(getValue(joyX), DEC);
        Serial.write(",");
        Serial.print(getValue(joyY), DEC);
        Serial.write(",");
        Serial.print(getValue(accelX), DEC);
        Serial.write(",");
        Serial.print(getValue(accelY), DEC);
        Serial.write(",");
        Serial.print(getValue(accelZ), DEC);
        Serial.write(",");
        Serial.print(getValue(btnZ), DEC);
        Serial.write(",");
        Serial.print(getValue(btnC), DEC);
        // Serial.write(",0");
        // Serial.write("\n");
        Serial.println();
        delay(20);     // time between redraws
    void nunchuckInit()
        Wire.begin();                  //  join I2C bus as master
        Wire.beginTransmission(0x52);  //  transmit to device 0x52
        Wire.write((byte)0xF0);        //  send memory adress
        Wire.write((byte)0x55);        //  send a zero
        if (Wire.endTransmission() == 0)  {
             Wire.write((byte)0xA5);        //  send memory adress
             Wire.write((byte)0x00);
        }     //  stop transmission
    //  send a request for data to the nunchuck
    static void nunchuckRequest()
        Wire.write((byte)0x00);          //  send one byte
        Wire.endTransmission();          //  stop transmission
    //  receive data back from the nunchuck,
    //  returns true if read successful, else false
    boolean nunchuckRead()
        int cnt=0;
        Wire.requestFrom (0x52, dataLength);    //  request data from nunchuck
        while (Wire.available ())  {
            rawData[cnt] = Wire.read();
            cnt++;
        nunchuckRequest();      //  send request for next dat payload
        if (cnt >= dataLength)
            return true;        //  success if all 6 bytes received
        else
            return false;       //  failure
    //  encode data to format that most wiimote drivers accept
    // static char nunchuckDecode (byte x)  {
        // return (x ^ 0x17) + 0x17;
    //    return x;
    int getValue(int item)   {
        if (item <= accelZ)
            return (int)rawData[item];
        else if (item == btnZ)
            return bitRead(rawData[5], 0) ? 0: 100;
        else if (item == btnC)
            return bitRead(rawData[5], 1) ? 0: 100;
    Achso, sorry, das war der Code von Klebwax
  1. Wii Nunchuck I2C an Raspberry Pi
    Von wassy92x im Forum Allgemeines zum Thema Roboter / Modellbau
    Letzter Beitrag: 27.01.2015, 16:24
  2. Nunchuck auslesen
    Von Snaper im Forum Sensoren / Sensorik
    Antworten: 12
    Letzter Beitrag: 28.02.2012, 10:45
  3. Wii Motion Plus - Nunchuck Passthrough Mode
    Von Che Guevara im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 19.10.2011, 20:36
  4. Nunchuck mit Gyroskopen
    Von RobertM im Forum Microcontroller allgemeine Fragen/Andere Microcontroller
    Letzter Beitrag: 21.12.2008, 17:40
  5. Nunchuck über i2c Ausleseprobleme (wohl Nunchukseitig)
    Von ustech im Forum AVR Hardwarethemen
    Letzter Beitrag: 06.10.2008, 00:56
