Thema: SDK: espconn_send liefert -12
    Erfahrener Benutzer Fleißiges Mitglied Avatar von drew
    ich verwende das SDK V2.1.0. Ich arbeite also nicht mit Arduino.
    Ich will von meinem ESP auf eine HTML-Seite im Netz zugreifen. Ich habe mir gedacht dass ich dazu TCP verwenden kann und mit espconn_send meine GET Anfrage schicken kann. Unten ist mein Code.
    Leider bekomme ich -12 (=ESPCONN_ARG) als Rückgabewert. Kann mir jemand sagen, was ich falsch mache?
    Besten Dank,
    drewle
    void init_Tcp_client(void)
       sint8 s8_err;
       os_printf("init_Tcp_client\r\n");
       // Preset t_tcp. only remote_port is needed
       gt_tcp2.local_ip[0] = 192;    // setting the local IP seams not to be really needed
       gt_tcp2.local_ip[1] = 168;
       gt_tcp2.local_ip[2] = 178;
       gt_tcp2.local_ip[3] = 20;
       gt_tcp2.local_port = 80;
       gt_tcp2.remote_ip[0] = xxx;
       gt_tcp2.remote_ip[1] = xxx;
       gt_tcp2.remote_ip[2] = xxx;
       gt_tcp2.remote_ip[3] = xxx;
       gt_tcp2.remote_port = 80;
       gt_tcp2.connect_callback = NULL;   // as the global variables are set to 0 this is not really needed
       gt_tcp2.reconnect_callback = NULL;
       gt_tcp2.disconnect_callback = NULL;
       gt_tcp2.write_finish_fn = NULL;
       gt_conn2.type = ESPCONN_TCP;
       gt_conn2.state = ESPCONN_NONE;
       gt_conn2.proto.tcp = &gt_tcp2;
       gt_conn2.recv_callback = recv_Cb;
       gt_conn2.sent_callback = NULL;   // as the global variables are set to 0 this is not really needed
       gt_conn2.link_cnt = 1;
       gt_conn2.reverse = NULL;
       // wait for the connection of a client
       s8_err = espconn_accept(&gt_conn2);
       os_printf("espconn_accept: %d\r\n",s8_err);
       os_printf("gt_conn2.state: %u\r\n",gt_conn2.state);
    void my_timer_function(void *timer_arg)
       uint16 u16_AdcVal;
       sint8 s8_err;
    //   if( gu8_GotIp==true )
          // Read the ADC value
          u16_AdcVal = system_adc_read();
          os_printf("ADC Value: %u\n", u16_AdcVal);
          os_printf("gt_conn2.type: %u\r\n",gt_conn2.type);
          os_printf("gt_conn2.proto: %llu\r\n",gt_conn2.proto);
          os_printf("gt_conn2.recv_callback: %llu\r\n",gt_conn2.recv_callback);
          os_printf("gt_conn2.sent_callback: %llu\r\n",gt_conn2.sent_callback);
          os_printf("gt_conn2.link_cnt: %u\r\n",gt_conn2.link_cnt);
          os_printf("gt_conn2.reverse: %llu\r\n",gt_conn2.reverse);
          // send request
          s8_err = espconn_send(&gt_conn2,gc_Request,strlen(gc_Request));
          os_printf("espconn_send: %d\r\n",s8_err);
    weit weg von nahe Bonn
    Da fehlt noch reichlich Kontext um Antworten zu können, z.B. sendest du in deinem Code den Inhalt von "gc_Request"... das ist aber nirgendwo deklariert oder hat irgendwelchen Inhalt ... dein Code ist leider zu unvollständig um dir helfen zu können denn die Doku sagt nur dass du ein falsches Argument beim Aufruf geliefert hast.
    "gu8_GotIp" zum Beispiel wird auch nirgendwo verändert, könnte auch Einfluss auf das Problem haben ... mit solchen Bruchstücken kann man nix anfangen sorry.
    nicht.
    Das Problem war wohl das "espconn_accept". Dadurch wird der ESP zum Server. Einfach so mal senden ist dann nicht mehr.
    Ohne dem geht es dann fehlerfrei. Bild
    Danke fürs Helfen
    Drew
  1. RS232 liefert nur 0
    Von trimoq im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 05.01.2014, 23:54
  2. DCF 77 liefert seltsame Werte
    Von Goldenflash im Forum Basic-Programmierung (Bascom-Compiler)
    Antworten: 4
    Letzter Beitrag: 08.08.2011, 08:44
  3. (s)printf mit double liefert '?'...
    Von Jaecko im Forum C - Programmierung (GCC u.a.)
    Antworten: 4
    Letzter Beitrag: 07.12.2008, 13:58
  4. SRF02 liefert 112
    Von Tenorm im Forum Sensoren / Sensorik
    Letzter Beitrag: 29.02.2008, 19:36
  5. LCD Anzeige liefert nur Müll
    Von im Forum AVR Hardwarethemen
    Antworten: 4
    Letzter Beitrag: 08.02.2004, 14:35
