So gehts mit Wlan und Http Client:
Die platformio Ini ist wie oben angegeben.Code:#include <iostream> #include "mbed.h" #include "wifi.h" /*------------------------------------------------------------------------------ Hyperterminal settings: 115200 bauds, 8-bit data, no parity This example - connects to a wifi network (SSID & PWD) - displays the IP address and get webpage html code This example uses SPI3 ( PE_0 PC_10 PC_12 PC_11), wifi_wakeup pin (PB_13), wifi_dataready pin (PE_1), wifi reset pin (PE_8) ------------------------------------------------------------------------------*/ #define MBED_CONF_APP_WIFI_SSID "xyz" #define MBED_CONF_APP_WIFI_PASSWORD "geheim" Serial pc (SERIAL_TX, SERIAL_RX); DigitalOut led(LED2); AnalogIn adc_temp(ADC_TEMP); // // WLAN mit dem Hotspot verbinden. // int wifi_sample_run(void) { uint8_t IP_Addr[4]; uint8_t MAC_Addr[6]; // WLAN initialisieren if (WIFI_Init() == WIFI_STATUS_OK) { std::cout << "WiFi initialisieren." << std::endl; if (WIFI_GetMAC_Address(MAC_Addr) == WIFI_STATUS_OK) { std::cout << "Wifi Modul MAC Address: "; std::cout << unsigned (MAC_Addr[0]) << ":"; std::cout << unsigned (MAC_Addr[1]) << ":"; std::cout << unsigned (MAC_Addr[2]) << ":"; std::cout << unsigned (MAC_Addr[3]) << ":"; std::cout << unsigned (MAC_Addr[4]) << ":"; std::cout << unsigned (MAC_Addr[5]) << std::endl; } else { std::cout << "ERROR: MAC-Adresse konnte nicht gelesen werden." << std::endl; } if (WIFI_Connect (MBED_CONF_APP_WIFI_SSID, MBED_CONF_APP_WIFI_PASSWORD, WIFI_ECN_WPA2_PSK) == WIFI_STATUS_OK) { std::cout << "WiFi Modul mit Hotspot verbunden." << std::endl; if(WIFI_GetIP_Address(IP_Addr) == WIFI_STATUS_OK) { std::cout << "WiFi Modul IP-Adresse: "; std::cout << unsigned (IP_Addr[0]) << "."; std::cout << unsigned (IP_Addr[1]) << "."; std::cout << unsigned (IP_Addr[2]) << "."; std::cout << unsigned (IP_Addr[3]) << std::endl; } else { std::cout << "ERROR: WiFi Modul IP-Adresse konnte nicht gelesen werden." << std::endl; return -1; } } else { std::cout << "ERROR: WiFi Modul konnte nicht verbunden werden." << std::endl; return -1; } } else { std::cout << "ERROR: WiFi Modul konnte nicht initialisiert werden" << std::endl; return -1; } return 0; } // // Sende einen HTTP Get an den Server und lese die Server Antwort. // void WebClient (void) { // Parameter zu welchem Server verbunden werden soll. uint16_t iPort = 80; uint16_t iLocalPort = 3000; uint8_t ipAddr[4] = { 10, 0, 0, 3 }; // Muss man mit der Server IP ersetzen. // Mit dem Serve verbinden. WIFI_Status_t wifiRc; int32_t Socket = 0; wifiRc = WIFI_OpenClientConnection (Socket, WIFI_TCP_PROTOCOL, "Name", ipAddr, iPort, iLocalPort); if (wifiRc != WIFI_STATUS_OK) { if (wifiRc == ES_WIFI_STATUS_ERROR) std::cout << "Connect zum HTTP-Server Fehler: ES_WIFI_STATUS_ERROR" << std::endl; std::cout << "Conntect zum HTTP-Server fehlgeschlagen" << std::endl; exit (0); } else std::cout << "HTTP-Client Connect erfolgreich ..." << std::endl; // Sende HTTP Request static uint8_t http[1024]; strcpy ((char *) http, (char *) "GET / HTTP/1.1\r\n"); strcat ((char *) http, (char *) "Host: domain.de\r\n"); strcat ((char *) http, (char *) "\r\n"); uint16_t SentDataLength; const int wifiWriteTimeout = 10000; wifiRc = WIFI_SendData(0, (uint8_t *)http, strlen((char *)http), &SentDataLength, wifiWriteTimeout); if ((wifiRc == WIFI_STATUS_OK) && (SentDataLength != strlen((char *)http))) { std::cout << "HTTP Request senden fehlgeschlagen" << std::endl; wifiRc = WIFI_STATUS_ERROR; exit (0); } else std::cout << "HTTP Request '" << http << "' gesendet: " << SentDataLength << std::endl; // Empfange Server Antwort static uint8_t resp[1024]; uint16_t respLen; const int wifiReadTimeout = 10000; WIFI_ReceiveData (Socket, resp, 1200, &respLen, wifiReadTimeout); if( respLen > 0) { std::cout << "HTTP-Client Server Antwort: " << resp << std::endl; } else { std::cout << "HTTP-Client: Server Antwort konnte nicht Empfangen werden." << std::endl; } } int main() { int ret = 0; led = 0; pc.baud(115200); std::cout << "Programm gestartet ..." << std::endl; // Verbindung zum WLAN Hotspot herstellem std::cout << "WLAN: connect" << std::endl; ret = wifi_sample_run(); if (ret != 0) { std::cout << "WLAN: connect fehlgeschlagen" << std::endl; return -1; } WebClient (); }
Ich habe dazu das Paket benutzt:
Code:# Lib: DISCO_L475VG_IOT01A_wifi installieren # ID : 3438 pio lib install 3438
Zitieren
