Ergebnis 31 bis 36 von 36
Thema: html code für User Login + password (esp8266 + Arduino IDE)
Baum-Darstellung
  1. #35
    Ich glaub ja:
    void handleNotAuthorized() {
      String readString = "";
      char   strinput[MAXLEN], strupwd[TOKLEN], struname[TOKLEN] ;
      WiFiClient client = wifiserver.available();
      // debug
      // authorized=true;
      strcpy(strinput, "");
      strcpy(strupwd, "");
      strcpy(struname, "");
      while ( client.connected() ) {
        if (authorized) return;
        if ( client.available() ) {
          char c = client.read();
          //read char by request
          readString = "";
          while ( (readString.length() < TOKLEN) && (c != '\n') ) {
              readString += c;
              c = client.read();
        readString.toCharArray(strinput, MAXLEN);
        // cstringarg( char* haystack, char* vname, char* sarg )
        // haystack pattern: &varname=1234abc,  delimiters &, \n, \0, SPACE, EOF
        cstringarg(strinput, "uname", struname);  // uname
        cstringarg(strinput, "upwd", strupwd);   // upwd
        // debug
        Serial.print("strupwd     >>>"); Serial.print(strupwd); Serial.println("<<<");
        Serial.print("website_upwd>>>"); Serial.print(website_upwd); Serial.println("<<<");
        Serial.print("readString>>>");Serial.println(readString);
        if ( (strlen(strupwd) == strlen(website_upwd)) && (strcmp(website_upwd, strupwd) == 0) )
          authorized = true;
          //debug
          //Serial.print("check: authorized="); Serial.println(authorized);
          readString = "";
          return;
          //if HTTP request has ended
          if (c == '\n') {
             client.flush();
            //now output html data header
            String script = "";
            script += ("HTTP/1.1 401 Log-In Required");
            script += ("Content-Type: text/html \n");
            script += ("\n");  //  do not forget this one //????
            script += ("<!DOCTYPE html> \n");
            script += ("<html> \n");
            script += ("<head> \n");
            // utf-8 für "°" Zeichen
            script +=  "<meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\"> \n" ;
            script +=  "<title>" ;
            script +=  website_title ;
            script +=  "</title> \n" ;
            script +=  "</head> \n" ;
            script +=  "<body> \n" ;
            script += "<h1><p style=\"color:rgb(255,0,191);\"> " + (String)website_url ;
            script += (String)": &nbsp; <wbr> <wbr> " + "Not authorized !</p> </h1> \n" ;
            script += ("<h2><p style=\"color:rgb(255,0,191);\"> log in to proceed: </p> </h2> \n");
            script += ("<FORM ACTION='/' method=GET > \n");
            script += ("<h2>user name:  <INPUT TYPE=text NAME='uname' VALUE=''  MAXLENGTH='50'> </h2> \n");
            script += ("<h2>password :  <INPUT TYPE=PASSWORD NAME='upwd' VALUE='' MAXLENGTH='50'> </h2> \n");
            script += ("<h2><INPUT TYPE=SUBMIT></h2> \n");
            script += ("</FORM> \n");
            script += ("<BR> \n");
            script += ("</body> \n");
            script += ("</html> \n");
            client.print(script);
            //stopping client
            client.stop();
            delay(1);
            //clearing string for next read
            //readString = "";
        delay(1);
    Ersetzen tust Du bitte nur die Funktion handleNotAuthorized().
    Zuerst muss der gesamte String vom Browser gelesen werden oder bis TOKLEN erreicht ist. Danach kann man die Parameter mit cstringarg rausfischen und das dann prüfen.
    Vorher war es anders herum: Erst wurde der Parameter für Passwort geprüft und dann ein Zeichen von den gesendeten Browserdaten gelesen, das eine Zeichen wurde angehängt und dann begann der Spaß von vorn.
    Geändert von Moppi (19.08.2018 um 18:49 Uhr)
  1. html-Code für nodeMCU mit Arduino IDE + Wifi libs
    Von HaWe im Forum Arduino -Plattform
    Antworten: 7
    Letzter Beitrag: 14.08.2018, 18:30
  2. Pegelwandler RX/TX Arduino ESP8266
    Von Cysign im Forum Elektronik
    Letzter Beitrag: 05.02.2018, 23:29
  3. ESP8266 boards per per Arduino-IDE programmieren?
    Antworten: 27
    Letzter Beitrag: 10.06.2017, 15:19
  4. arduino ide mit esp8266
    Von NotEvil im Forum NodeMCU-Board und ESP8266, ESP32-Serie
    Letzter Beitrag: 12.01.2017, 14:17
  5. HTML-Code (scripts)
    Von Technik =) im Forum Umfragen
    Letzter Beitrag: 10.10.2008, 09:21
