Ergebnis 11 bis 15 von 15
Thema: Positions Berechnung mit VB6
    sorry, wenn ich den alten beitrag nochmal hochhole...
    ich benutze folgendes modul um die gps-daten (512X.2722=51° 2X.2722min x 121X.0787=12° 1X.0787min) in grad umzuwandeln (51,33787° x 12,234645°)
    ' quelle: http://www.planet-source-code.com/vb...63143&lngWId=1
    Option Explicit
    Option Base 1
    'The RMC-Datasentence (RMC=recommended minimum sentence C)
    'is a recommendation for the minimum, that a GPS-Receiver should give back.
    'It looks like this: "$GPRMC,191410,A,4735.5634,N,00739.3538,E,0.0,0.0,181102,0.4,E,A*19"
    Public Sub decodeRMC(ByVal inp As String, _
                Optional ByRef UtcTime As String, _
                Optional ByRef ReceiverWarning As Boolean, _
                Optional ByRef Latitude As Double, _
                Optional ByRef LatitudeDir As String, _
                Optional ByRef Longitude As Double, _
                Optional ByRef LongitudeDir As String, _
                Optional ByRef SpeedKMH As Double, _
                Optional ByRef Course As Double, _
                Optional ByRef DateStamp As String, _
                Optional ByRef MagneticDeclination As Double, _
                Optional ByRef Checksum As Boolean)
        On Error Resume Next
        inp = UCase(Trim(inp))
        'Checking initstring. Must be the same for all RMC sentences.
        If Left(inp, 1) <> "$" Or Mid(inp, 4, 3) <> "RMC" Then Checksum = False: Exit Sub
        'Extracting that part of the sentence that is needed to calculate the checksum
        Dim ChkDat As String
        ChkDat = Mid(inp, 2, InStr(2, inp, "*") - 2)
        'For compatibility with split function
        inp = Replace(inp, ",,", ", ,")
        'Splitting sentence
        Dim Dat As Variant
        Dat = Split(inp, ",")
        'Calculating checksum and comparing it
        Dim ChkSum As String
        ChkSum = Dat(UBound(Dat))
        ChkSum = Right(ChkSum, Len(ChkSum) - InStr(1, ChkSum, "*"))
        If calcChecksum(ChkDat) = Hex2Dec(ChkSum) Then Checksum = True Else Checksum = False: Exit Sub
        'UtcTime
        UtcTime = Left(Dat(2), 6)
        If UtcTime <> " " Then UtcTime = Left(UtcTime, 2) & ":" & Mid(UtcTime, 3, 2) & ":" & Right(UtcTime, 2) Else UtcTime = ""
        'ReceiverWarning
        If Dat(3) = "A" Or Dat(3) = "" Then ReceiverWarning = False Else ReceiverWarning = True
        'Length
        Dim sp As Integer
        sp = InStr(1, Dat(4), ".")
        Latitude = CDbl(Left(Dat(4), sp - 3)) + CDbl(CDbl(Replace(Mid(Dat(4), sp - 2), ".", ",")) / 60)
        Latitude = Round(Latitude, 8)
        'LengthDir
        LatitudeDir = Dat(5)
        'Width
        sp = InStr(1, Dat(6), ".")
        Longitude = CDbl(Left(Dat(6), sp - 3)) + CDbl(CDbl(Replace(Mid(Dat(6), sp - 2), ".", ",")) / 60)
        Longitude = Round(Longitude, 8)
        'WidthDir
        LongitudeDir = Dat(7)
        'SpeedKMH (needs to be converted from knots)
        SpeedKMH = Replace(CStr((Dat(8) * 0.54)), ".", ",")
        'Course without movement
        Course = Replace(CStr(Dat(9)), ".", ",")
        'DateStamp
        DateStamp = Left(Dat(10), 6)
        If DateStamp <> " " Then DateStamp = Left(DateStamp, 2) & "." & Mid(DateStamp, 3, 2) & "." & Mid(DateStamp, 5) Else DateStamp = ""
        'MagneticDeclination
        MagneticDeclination = Replace(CStr(Dat(11)), ".", ",")
    End Sub
    'The GGA-Datasentence contains the most important information about GPS-position and accuracy.
    'it looks like: "$GPGGA,191410,4735.5634,N,00739.3538,E,1,04,4.4,351.5,M,48.0,M,,*45"
    Public Sub decodeGGA(ByVal inp As String, _
                Optional ByRef Quality As String, _
                Optional ByRef SatellitesIV As Integer, _
                Optional ByRef HDOP As Double, _
                Optional ByRef AltitudeSea As Double, _
                Optional ByRef AltitudeSeaUnit As String, _
                Optional ByRef AltitudeEllipsoid As Double, _
                Optional ByRef AltitudeEllipsoidUnit As String, _
        'Checking initstring. Must be the same for all GGA sentences.
        If Left(inp, 1) <> "$" Or Mid(inp, 4, 3) <> "GGA" Then Checksum = False: Exit Sub
        'Splitting sentence
        Dim Dat As Variant
        'UtcTime
        'Length
        Dim sp As Integer
        sp = InStr(1, Dat(3), ".")
        Latitude = CDbl(Left(Dat(3), sp - 3)) + CDbl(CDbl(Replace(Mid(Dat(3), sp - 2), ".", ",")) / 60)
        'LengthDir
        LatitudeDir = Dat(4)
        'Width
        sp = InStr(1, Dat(5), ".")
        Longitude = CDbl(Left(Dat(5), sp - 3)) + CDbl(CDbl(Replace(Mid(Dat(5), sp - 2), ".", ",")) / 60)
        'WidthDir
        LongitudeDir = Dat(6)
        'Quality: 0-invalid, 1-gps, 2-dgps, 6-guessed
        Quality = "unknown"
        If Dat(7) = 0 Then Quality = "no fix"
        If Dat(7) = 1 Then Quality = "GPS fix"
        If Dat(7) = 2 Then Quality = "DGPS fix"
        If Dat(7) = 6 Then Quality = "guessed"
        'Satellites in view
        SatellitesIV = Dat(8)
        'HDOP: horizontal dilution of precision (accuracy)
        HDOP = Replace(CStr(Dat(9)), ".", ",")
        'Altitude over sea
        AltitudeSea = Replace(CStr(Dat(10)), ".", ",")
        'Altitude over sea unit
        AltitudeSeaUnit = Dat(11)
        'Altitude over ellipsoid
        AltitudeEllipsoid = Replace(CStr(Dat(12)), ".", ",")
        'Altitude over ellipsoid unit
        AltitudeEllipsoidUnit = Dat(13)
    End Sub
    'The GSA-Datasentence contains information about the PRN-Numbers of the satellites that are used
    'for calculating the actual position and some more detailed info about the accuracy.
    'it looks like: "$GPGSA,A,3,,,,15,17,18,23,,,,,,4.7,4.4,1.5*3F"
    Public Sub decodeGSA(ByVal inp As String, _
                Optional ByRef AutoSel As Boolean, _
                Optional ByRef mode As String, _
                Optional ByRef prn As Variant, _
                Optional ByRef PDOP As Double, _
                Optional ByRef VDOP As Double, _
        'Checking initstring. Must be the same for all GSA sentences.
        If Left(inp, 1) <> "$" Or Mid(inp, 4, 3) <> "GSA" Then Checksum = False: Exit Sub
        'Splitting sentence
        Dim Dat As Variant
        'Auto Selection Mode
        If Dat(2) = "A" Then AutoSel = True Else AutoSel = False
        'Mode
        mode = "unknown"
        If Dat(3) = "3" Then mode = "3D-Fix"
        If Dat(3) = "2" Then mode = "2D-Fix"
        If Dat(3) = "1" Then mode = "No-Fix"
        'PRN-Numbers
        ReDim prn(12)
        Dim i As Integer
        For i = 4 To 15
            If IsNumeric(Dat(i)) Then prn(i - 3) = CInt(Dat(i)) Else prn(i - 3) = ""
        Next
        'PDOP in meters
        PDOP = Replace(CStr(Dat(16)), ".", ",")
        'HDOP horizontal dilution of precision in meters
        HDOP = Replace(CStr(Dat(17)), ".", ",")
        'VDOP vertical dilution of precision in meters
        VDOP = Replace(Left(CStr(Dat(18)), InStr(1, Dat(18), "*") - 1), ".", ",")
    End Sub
    '              sn ed azi dB ------------ ------------ ------------
    '$GPGSV,3,1,12,22,89,000,00,14,59,000,00,15,53,000,00,18,51,000,00*7F
    '$GPGSV,3,2,12,09,47,000,00,19,15,000,00,21,13,000,,31,13,000,*7C
    '$GPGSV,3,3,12,03,06,000,00,11,04,000,,28,02,000,00,05,01,000,00*77
    'GSV - Satellites in view
    '        1 2 3 4 5 6 7     n
    ' $--GSV,x,x,x,x,x,x,x,...*hh<CR><LF>
    '  1) total number of messages
    '  2) message number
    '  3) satellites in view
    '  4) satellite number
    '  5) elevation in degrees
    '  6) azimuth in degrees to true
    '  7) SNR in dB
    '  more satellite infos like 4)-7)
    '  n) checksum
    Public Sub decodeGSV(ByVal inp As String, _
                Optional ByRef tnm As Integer, _
                Optional ByRef mn As Integer, _
                Optional ByRef SatsInView As Integer, _
                Optional ByRef SatNr As Variant, _
                Optional ByRef Elevation As Variant, _
                Optional ByRef Azimuth As Variant, _
                Optional ByRef SNRdB As Variant, _
        'Checking initstring. Must be the same for all GSV sentences.
        If Left(inp, 1) <> "$" Or Mid(inp, 4, 3) <> "GSV" Then Checksum = False: Exit Sub
        ChkDat = ChkDat
        'Splitting sentence
        Dim Dat As Variant
        'Cutting what we won't need
        inp = Right(inp, Len(inp) - 7)
        inp = Left(inp, InStr(1, inp, "*") - 1)
        Dim ccs As Integer, dcs As Long
        ccs = calcChecksum(ChkDat)
        dcs = Hex2Dec(ChkSum)
        If ccs = dcs Then Checksum = True Else Checksum = False: Exit Sub
        'total number of messages
        tnm = CInt(Dat(1))
        'message number
        mn = CInt(Dat(2))
        'Satellites in View
        SatsInView = Dat(3)
        Dim i As Integer
        Dim sp As Integer
        'Satellite-Numbers
        ReDim SatNr(4)
        For i = 1 To 4
            sp = InStr(1, Dat(3 + i), "*")
            If sp > 0 Then Dat(3 + i) = Left(Dat(3 + i), sp - 1)
            SatNr(i) = Dat(3 + i)
        Next
        'Elevations
        ReDim Elevation(4)
        For i = 1 To 4
            sp = InStr(1, Dat(7 + i), "*")
            If sp > 0 Then Dat(7 + i) = Left(Dat(7 + i), sp - 1)
            Elevation(i) = Dat(7 + i)
        Next
        'Azimuth's
        ReDim Azimuth(4)
        For i = 1 To 4
            sp = InStr(1, Dat(11 + i), "*")
            If sp > 0 Then Dat(11 + i) = Left(Dat(11 + i), sp - 1)
            Azimuth(i) = Dat(11 + i)
        Next
        'SNRdB's
        ReDim SNRdB(4)
        For i = 1 To 4
            sp = InStr(1, Dat(15 + i), "*")
            If sp > 0 Then Dat(15 + i) = Left(Dat(15 + i), sp - 1)
            SNRdB(i) = Dat(15 + i)
        Next
    End Sub
    'Helper functions:
    Function calcChecksum(inp As String) As Integer
        Dim i As Integer, s As Integer
        s = 0
        For i = 1 To Len(inp)
            s = s Xor Asc(Mid(inp, i, 1))
        Next
        calcChecksum = s
    End Function
    Function Hex2Dec(HexNum As Variant) As Long
        Hex2Dec = "&h" & HexNum
    End Function
    'Compatibility functions:
    Function Split(sIn As String, sDel As String) As Variant
        Dim i As Integer, x As Integer, s As Integer, t As Integer
        i = 1: s = 1: t = 1: x = 1
        ReDim tArr(1 To x) As Variant
        If InStr(1, sIn, sDel) <> 0 Then
                ReDim Preserve tArr(1 To x) As Variant
                tArr(i) = Mid(sIn, t, InStr(s, sIn, sDel) - t)
                t = InStr(s, sIn, sDel) + Len(sDel)
                s = t
                If tArr(i) <> "" Then i = i + 1
                x = x + 1
            Loop Until InStr(s, sIn, sDel) = 0
            tArr(i) = Mid(sIn, t, Len(sIn) - t + 1)
        Else
            tArr(1) = sIn
        End If
        Split = tArr
    End Function
    Function Round(ByVal Value As Variant, Optional ByVal digits As Integer = 0) As Variant
      Dim i As Long
      Dim Pot10(-28 To 28) As Variant
      If i = 0 Then
        For i = LBound(Pot10) To UBound(Pot10)
          Pot10(i) = CDec(10 ^ i)
        Next i
      End If
        If Value > 0 Then
          Round = Int(Value * Pot10(digits) + 0.5) * Pot10(-digits)
        Else
          Round = -Int(-Value * Pot10(digits) + 0.5) * Pot10(-digits)
        End If
        If Err.Number Then Round = Value
      On Error GoTo 0
    End Function
    Function Replace(strString As String, Find As String, strReplace As String) As String
        Dim ss As Long
        ss = InStr(1, strString, Find)
        If ss > 0 Then
            strString = Left(strString, ss - 1) & strReplace & Right(strString, Len(strString) - (ss + (Len(Find) - 1)))
            Replace = Replace(strString, Find, strReplace)
        Else
            Replace = strString
        End If
    End Function
    wenn ich nun L1, L2, G1, G2 durch die errechneten koordinaten ersetze, dann müßte ich doch ebenfalls die entfernung ermittelt bekommen, kann das einer bestätigen? oder gibt es vielleicht andere gps-projekte die sich näher mit der entfernungsberechnung beschäftigen? hat vielleicht schon einer ein fertiges beispielprojekt, da ich mir nicht sicher bin ob ich mit der oben genannten methode ein korrektes ergebniss erhalte oder ob da irgendwo doch ein fehler drin ist.
    vielleicht kann einer weiterhelfen.
    mfg.
    ok, ich komme immer auf falsche ergebnisse, im deut. raum muß man wohl folgende konstante benutzen: distance = dist * 111.12 '<- den wert hab ich aus einer exel-koordinaten-umrechnungstabelle
    weiß vielleicht einer warum gerade "111.12"? woraus/wie errechnet sich dieser wert bzw. woher kommen die "60" aus dem obigen code?
    mfg.
    Der Wert kommt mir irgendwie bekannt vor. Der Abstand zwischen zwei Breitengraden beträgt 111Km ( oder vielleicht auch: 111.12 Km ?).
    Das kann doch kein Zufall sein?
    Klaus
    ich habe den Code von SOMMER am PDA unter Verwendung von "eVB" ausprobiert. Zum Testen wurden allerdings nur fixe Eingangsdaten verwendet.
    Wenn man den Entfernungsparameter "dist" mit 1.852 multipliziert, erhält man Entfernungsangaben in Km. Von einem Breitengrad zum nächsten ergibt das exakt 111.12KM. Der Abstand zwischen zwei Längengraden variiert dagegen in Abhängigkeit vom Breitengrad. Im mittleren Teil von Deutschland sind es etwa 70Km. Soweit scheint der Code also zu funktionieren. Nicht klargekommen bin ich dagegen mit der verwendeten Richtungsberechnung. Deshalb habe ich hierfür stattdessen eine vorhandene Routine eingebaut. Sie ist auch im beigefügten Code zu finden.
    Klaus
    Option Explicit
    Dim Lat1
    Dim Lon1
    Dim Lat2
    Dim Lon2
    Dim L1
    Dim L2
    Dim G1
    Dim G2
    Const pi = 3.14159265358979
    Const radian = 0.017453292  'pi/180
    Private Sub Command2_Click()
    'Lat1 = (Text1.Text + (Text2.Text / 60) + (Text3.Text / 3600))
    'Lon1 = -(Text4.Text + (Text5.Text / 60) + (Text6.Text / 3600))
    'Lat2 = (Text7.Text + (Text8.Text / 60) + (Text9.Text / 3600))
    'Lon2 = -(Text10.Text + (Text11.Text / 60) + (Text12.Text / 3600))
    Lat1 = 50.96
    Lon1 = 8.2
    Lat2 = 49.96
    Lon2 = 8.2
    L1 = Lat1
    L2 = Lon1
    G1 = Lat2
    G2 = Lon2
    Text1.Text = L1
    Text2.Text = L2
    Text3.Text = G1
    Text4.Text = G2
    'Distanzberechnung
    Dim theta, dist, Deg
    theta = Lon1 - Lon2
    dist = Sin(deg2rad(Lat1)) * Sin(deg2rad(Lat2)) + Cos(deg2rad(Lat1)) * Cos(deg2rad(Lat2)) * Cos(deg2rad(theta))
    dist = acos(dist)
    dist = rad2deg(dist)
    Text5.Text = (Int(dist * 6000 + 0.5) / 100) * 1.852
    'Richtungsbrechnung
    Dim ga, zw, bear
    If dist > 0 Then
    Lon1 = Lon1 * radian
    Lat1 = Lat1 * radian
    Lon2 = Lon2 * radian
    Lat2 = Lat2 * radian
    ga = Lon1 - Lon2
    zw = Cos(Lat1) * Cos(Lon1 - Lon2) * Cos(Lat2) + Sin(Lat1) * Sin(Lat2)
    zw = Atn(zw / Sqr(1 - zw * zw))
    zw = pi / 2 - zw
    bear = ((Sin(Lat2) - Sin(Lat1) * Cos(zw)) / (Cos(Lat1) * Sin(zw)))
    bear = Atn(bear / Sqr(1 - bear * bear))
    bear = (pi / 2 - bear) / radian
        If Sin(ga) >= 0 Then
            bear = 360 - bear
        End If
    End If
    bear = Int(bear * 10 + 0.5) / 10
    If bear = 0 Then bear = 360
    Text6.Text = bear
    End Sub
    Function acos(rad)
      If Abs(rad) <> 1 Then
        acos = pi / 2 - Atn(rad / Sqr(1 - rad * rad))
      ElseIf rad = -1 Then
        acos = pi
      End If
    End Function
    Function deg2rad(Deg)
        deg2rad = CDbl(Deg * pi / 180)
    End Function
    Function rad2deg(rad)
        rad2deg = CDbl(rad * 180 / pi)
    End Function
    Private Sub Form_OKClick()
        App.End
    End Sub
    Weilburg
    Zitat Zitat von gpsklaus
    ...Wenn man den Entfernungsparameter "dist" mit 1.852 multipliziert, erhält man Entfernungsangaben in Km...
    Bild   Wer wissen möchte warum das so ist: http://de.wikipedia.org/wiki/Nautische_Meile
    Prostetnic Vogon Jeltz
    The Answer is FF!
