Ergebnis 1 bis 10 von 33
Thema: FM-Radio mit Arduino Pro Mini und Si4703 - Programm hängt sich auf!
    Erfahrener Benutzer Fleißiges Mitglied Avatar von basteluwe
    Hallo Leute,
    ich betreibe ein SI4703 breakout an einem Pro-Mini. Gesteuert wird mit 5 Tastern.
    2x Volume +/-
    1x Wechsel zu nächster Station (10 Stationen voreingestellt)
    2x +/- Scan zu nächster auffindbarer Station
    KEINE RDS-Auswertung.
    Die Anzeige der Daten erfolgt auf OLED 128x64.
     * This code is a modification/extract of several example-codes that come *
     * with different si4703-libraries. Libraries used are fetched from:      *
     *         http://www.mathertel.de/Arduino/RadioLibrary.aspx              *
     * Not sure if other libraries work with same code.                       *
     * 5 push-buttons control the radio (see comments in code)                *
     * OLED-display shows 3 lines:                                            *
     *  1- "frequency"                                                        *
     *  2- "station name" or "scan mode"                                      *
     *  3- "volume level" + "battery voltage" or "CHARGE BATTERY"             *
     * Code for voltage monitoring is fetched from:                           *
     * https://code.google.com/archive/p/tinkerit/wikis/SecretVoltmeter.wiki  *
     * U.Galepp Jan./2018                                                     *
    #include <Arduino.h>
    #include <Wire.h>
    #include <radio.h>
    #include <si4703.h>
    #include "U8glib.h"
    U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);  // define type of display (OLED 0.96" 128x64 pix)
    #define FIX_BAND     RADIO_BAND_FM            // the band that will be tuned by this sketch is FM
    #define FIX_STATION  8760                     // station at start-up is 87.60 MHz
    #define FIX_VOLUME   1                        // volume level at start-up
    SI4703 radio;                                 // Create an instance of Class for Si4703 Chip
    int volume = FIX_VOLUME;
    int button_1 = 3;                             // button volume up at Pin 3
    int button_2 = 4;                             // button volume down at Pin 4
    int button_3 = 5;                             // button station swap at Pin 5
    int button_4 = 6;                             // button scan up at Pin 6
    int button_5 = 7;                             // button scan down at Pin 7
    int buttonState_1 = 0;
    int buttonState_2 = 0;
    int buttonState_3 = 0;
    int buttonState_4 = 0;
    int buttonState_5 = 0;
    int flag = 0;                                 // used for decission to show "Station Name" or "scan mode"
    int stationNr = 0;
    int fmFreq[10] = {8760, 8820, 9100, 9350, 9500, 10030, 10080, 10280, 10330, 10480};
    char* fmName[10] = {"   NDR 1 MV", "   NDR Kultur", "   NDR 1 MV", "   NDR 2 MV",
                       "     N-JOY", "Deutschlandfunk", "  Antenne MV", "   NDR Info",
                        "Radio Paradiso", "  Ostseewelle"};
    char vol[2];
    float volts;
    char akku[4];
    long readVcc() {
      long result;
                                                 // Read 1.1V reference against AVcc
      ADMUX = _BV(REFS0) | _BV(MUX3)
                  | _BV(MUX2) | _BV(MUX1);
      delay(2);                                  // Wait for Vref to settle
      ADCSRA |= _BV(ADSC);                       // Convert
      while (bit_is_set(ADCSRA,ADSC));
      result = ADCL;
      result |= ADCH<<8;
      result = 1126400L / result;                // Back-calculate AVcc in mV
      return result;
     *           Setup            *
    void setup() {
      radio.init();                               // initialize radio
      radio.setBandFrequency(FIX_BAND, FIX_STATION);
      radio.setVolume(volume);
      radio.setMono(false);
      radio.setMute(false);
      pinMode(button_1, INPUT);                   // define button Pins
      pinMode(button_2, INPUT);                   // -||-
      pinMode(button_3, INPUT);                   // -||-
      pinMode(button_4, INPUT);                   // -||-
      pinMode(button_5, INPUT);                   // -||-
      digitalWrite(button_1, HIGH);               // button-Pin Pull-up
      digitalWrite(button_2, HIGH);               // -||-
      digitalWrite(button_3, HIGH);               // -||-
      digitalWrite(button_4, HIGH);               // -||-
      digitalWrite(button_5, HIGH);               // -||-
     * Subroutine Display on OLED *
    void displayData()
      volts = (float)readVcc()/(float)1000;       // read Vcc and divide by 1000
      char s[12];
      radio.formatFrequency(s, sizeof(s));        // format frequency value to output like: "87,60 MHz"
        u8g.firstPage();
        do {
        u8g.drawFrame(0,0,128,64);                // display frame around screen
        u8g.setFont(u8g_font_timB14);
        u8g.drawStr(15, 22, s);
        u8g.setFont(u8g_font_unifont);
        if(flag==0)
          u8g.drawStr(4, 44, fmName[stationNr]);  // if fequency from array, take name from array too
        if(flag==1)
          u8g.drawStr(25, 44, "scan mode");       // if frequency from scan, show "scan mode"
        if(volts > 3.3)                           // if Vcc > 3.3V display "Volume" & "Volt"
            u8g.setFont(u8g_font_6x13);
            u8g.drawStr(6, 59,"Volume: ");
            sprintf (vol, "%d", volume);          // change int "volume" to char "vol"
            u8g.drawStr(50, 59, vol);
            u8g.drawStr(68, 59,"Bat:");
            dtostrf(volts, 2, 1, akku);           // change float "volts" to char "akku"
            u8g.drawStr(94, 59,akku);
            u8g.drawStr(115, 59,"V");
           else                                   // if VCC >= 3.3V display "CHARGE BATTERY"
            u8g.drawStr(6, 59,"CHARGE BATTERY");
         while( u8g.nextPage() );
     *         Main Loop          *
    void loop()
      buttonState_1 = digitalRead(button_1);
      buttonState_2 = digitalRead(button_2);
      buttonState_3 = digitalRead(button_3);
      buttonState_4 = digitalRead(button_4);
      buttonState_5 = digitalRead(button_5);
      if (buttonState_1 == LOW)
          volume ++;
          if (volume == 16) volume = 15;
          delay(100);
      else if (buttonState_2 == LOW)
          volume --;
          if (volume < 0) volume = 0;
          delay(100);
      else if (buttonState_3 == LOW)
          stationNr ++;
          if (stationNr == 10) stationNr = 0;
          radio.setFrequency(fmFreq[stationNr]);
          flag = 0;
          delay(500);
      else if (buttonState_4 == LOW)
          radio.seekUp();
          flag = 1;
          delay(500);
      else if (buttonState_5 == LOW)
          radio.seekDown();
          flag = 1;
          delay(500);
      else displayData();
    Prinzipiell funktioniert alles prima, nur leider friert das Ding immer mal wieder ein!
    Das kann schon Sekunden nach dem Start passieren, manchmal aber auch erst nach längerer Zeit.
    Ich bin nicht sicher, ob der Sketch auf dem Arduino einfriert oder ob es der SI4703 ist. Eigentlich glaube ich eher an ein Problem mit dem Sketch, weil dann auch die Anzeigewerte nicht mehr richtig reagieren, wenn ich auf Taster drücke. Andererseits habe ich manchmal den Eindruck, das das Einfrieren durch Bewegung in der Nähe der Antenne getriggert wird. Das würde für mich eher auf ein Problem mit dem SI4703 deuten. Ich habe versuchsweise die Anzeigeroutine auskommentiert. Das hat nichts gebracht.
    Hier noch die Schaltung, falls das wichtig ist:
Hits:	19
Größe:	37,6 KB
    Irgendwelche Ideen warum das Ding einfriert?
    Gruß Uwe
    Geändert von basteluwe (13.02.2018 um 09:38 Uhr)
    Dietfurt
    Ob es am Controller oder der Peripherie liegt lässt sich relativ einfach feststellen.
    Aktiviere den Watchdog Timer des Controllers und mach im Main Loop den WDR ( Watchdog Reset ) befehl rein.
    Bleibt die Peripherie hängen, wird der Controller nicht resettet und der Fehler wird wie beschrieben auftreten.
    Liegt der Fehler im Controller wird der Watchdog zuschlagen und den Controller resetten.
    Ein möglicher Fehler wäre z.B. das der Controller in einer Subroutine auf irgendwas wartet, das dann nicht kommt ( Quittung vom I²C z.B. ).
    Oder ein IC blockiert den I²C Bus.
    Das könnte man so lösen, das man da, wo eine Quittung erwartet wird einen Timer aktiviert.
    Wenn das Ganze zu lange dauert die Subroutine abgebrochen wird und an die aufrufende Routine eine negative Quittung zurück gegeben wird.
    Dort kann man dann eine Fehlerbehandlung durchführen.
    Vielen Dank für die Antwort
    Das bedeutet sicher, falls der Watchdog zuschlägt, beginnt das Programm wieder bei 0, also mit den voreingestellten Variablen aus dem Setup?
    Gruß Uwe
    Erfahrener Benutzer Roboter-Spezialist Avatar von sast
    I2C hat PullUps?
    sast
    雅思特史特芬
    开发及研究
    Dietfurt
    So ist es.
    Allerdings sollte im Programm die Peripherie dann Resettet werden.
    Über ein Register ( MCUSR ) kann man feststellen, durch was der Reset ausgelöst wurde und dementsprechend die Initialisierungen anpassen.
    Die Pullups für I²C gehören natürlich auch mit rein.
    Wenn mit den Pullups externe Widerstände an A4 und A5 (SDA & SCL) des Arduino gemeint sind, dann gibt es die bisher bei mir nicht! Die Schaltung im ersten Post zeigt die aktuelle Situation.
    Ich lese, daß bei 5V Vcc 4,7k als Pullup OK sind. Ich habe ja aber nur die 3,3V Version. Dann sollte wohl 3,3kOhm besser sein, oder?
    Gruß Uwe
    .. externe Widerstände an A4 und A5 (SDA & SCL) .. gibt es die bisher bei mir nicht .. bei 5V Vcc 4,7k .. die 3,3V Version .. 3,3kOhm besser sein, oder ..
    Wie fast immer hilft ein passendes Datenblatt. Beispielsweise dies hier, auf Seite 42. Anmerkung: ich habe bei 1,5 m (ein + einhalb Meter) Leitungslänge zu vier Slaves sogar 1,1 kΩ. Ausserdem hilft auch ein Oszilloskop und die kritische Betrachtung der Peaks - oder Nicht-Peaks *gg* bei der jeweils eingestellten Übertragungsrate (kann man die I²C-Frequenz bei arduion denn überhaupt festlegen?).
    Geändert von oberallgeier (14.02.2018 um 18:04 Uhr) Grund: Oh weh, Volt mit Kiloohm verwechselt :-/
    HaWe
    Die Arduinos funktionieren im Allgemeinen perfekt mit Pullups zwischen 1,4k bis 10kOhm.
    Der ArduinoMega (5V) hat z.B. 10k Pullups fest eingebaut, der Arduino Due (3.3V) 1,47 k; beide funktionieren für I2C clock von 100kHz bis 1MHz
    Zum Vergleich:
    Der Raspberry Pi (3.3V) hat fest eingebaute Pullups von 1.8k, ebenfalls für I2C clock von 100kHz bis 1MHz (ggf. sogar noch schneller, nicht getestet)
    2.2k bis 4.7k sind also sicher immer ein guter Mittelwert.
    Danke für eure Antworten soweit.
    Ich habe jetzt nacheinander zwei Dinge getan:
    zuerst habe ich den Watchdog aktiviert (hoffentlich richtig?):
    • #include <avr/wdt.h> (ganz oben im Code)
    • wdt_enable(WDTO_1S); (im Setup)
    • wdt_reset(); (als letztes in der Hauptschleife)
    Trotzdem ist der Fehler wieder aufgetreten, ohne das der Watchdog reagiert hätte. Es hat also keinen Reset vom Watchdog gegeben. Das Ding friert einfach ein und gut ist.
    Danach hab ich 1,8k Pullups am I2C eingelötet. Leider hat auch das den Fehler nicht beseitigt! Auch danach ist er schon wieder 1x hängen geblieben!
    Ich bin also wieder am Anfang!
    Wat nu???
    Dietfurt
    Dann würd ich mal sagen, blockiert einer der Chips den I²C bus.
    Oder ein Chip selber hängt sich auf.
    Da war mal hier ein Threat drin, bei dem das gleiche passiert ist.
    Schau mal im aufgehangenen Zustand, welche Pegel am I²C Bus anliegen.
    Die Lösung war, wenn ich richtig bin, 8 bzw. 9 Clock Impulse auf SCL zu legen, aber lies Sicherheitshalber noch mal nach.
  1. Unit 1.2 hängt sich auf
    Von Billy51 im Forum Open Source Software Projekte
    Letzter Beitrag: 06.03.2011, 12:52
  2. Timer hängt sich auf?
    Von Ineedhelp im Forum C - Programmierung (GCC u.a.)
    Antworten: 15
    Letzter Beitrag: 22.08.2008, 16:49
  3. Programm hängt sich auf
    Von martin66119 im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 07.10.2007, 21:06
  4. LCD hängt sich auf
    Von hotijack im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 30.05.2007, 16:47
  5. Lade Programm geht nicht (hängt sich auf)
    Von REX im Forum Robby CCRP5
    Letzter Beitrag: 11.09.2004, 04:19
