Ergebnis 1 bis 10 von 10
Thema: MPU6050 und bluetoothverbindung über HC05
    nahe Dresden
    hallo allerseits,
    ich mache jetzt für diesen roboter
Hits:	9
Größe:	81,7 KB
    die ersten notwendigen schritte mit der MPU6050. Verwende dabei diesen
    // I2C device class (I2Cdev) demonstration Arduino sketch for MPU6050 class
    // 10/7/2011 by Jeff Rowberg <jeff@rowberg.net>
    // Updates should (hopefully) always be available at https://github.com/jrowberg/i2cdevlib
    // Changelog:
    //      2013-05-08 - added multiple output formats
    //                 - added seamless Fastwire support
    //      2011-10-07 - initial release
      I2Cdev device library code is placed under the MIT license
      Copyright (c) 2011 Jeff Rowberg
      Permission is hereby granted, free of charge, to any person obtaining a copy
      of this software and associated documentation files (the "Software"), to deal
      in the Software without restriction, including without limitation the rights
      to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
      copies of the Software, and to permit persons to whom the Software is
      furnished to do so, subject to the following conditions:
      The above copyright notice and this permission notice shall be included in
      all copies or substantial portions of the Software.
      THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
      IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
      FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
      AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
      LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
      OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
      THE SOFTWARE.
    #include <Arduino.h>
    // I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
    // for both classes must be in the include path of your project
    #include "I2Cdev.h"
    #include "MPU6050.h"
    // Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
    // is used in I2Cdev.h
    #if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
    #endif
    // class default I2C address is 0x68
    // specific I2C addresses may be passed as a parameter here
    // AD0 low = 0x68 (default for InvenSense evaluation board)
    // AD0 high = 0x69
    MPU6050 accelgyro;
    //MPU6050 accelgyro(0x69); // <-- use for AD0 high
    int16_t ax, ay, az;
    int16_t gx, gy, gz;
    // uncomment "OUTPUT_READABLE_ACCELGYRO" if you want to see a tab-separated
    // list of the accel X/Y/Z and then gyro X/Y/Z values in decimal. Easy to read,
    // not so easy to parse, and slow(er) over UART.
    #define OUTPUT_READABLE_ACCELGYRO
    // uncomment "OUTPUT_BINARY_ACCELGYRO" to send all 6 axes of data as 16-bit
    // binary, one right after the other. This is very fast (as fast as possible
    // without compression or data loss), and easy to parse, but impossible to read
    // for a human.
    //#define OUTPUT_BINARY_ACCELGYRO
    #define LED_PIN 13
    bool blinkState = false;
    void setup() {
      // join I2C bus (I2Cdev library doesn't do this automatically)
      Wire.begin();
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
      Fastwire::setup(400, true);
    #endif
      // initialize serial communication
      // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
      // it's really up to you depending on your project)
      Serial.begin(115200);
      Serial1.begin(115200);
      // initialize device
      Serial.println("Initializing I2C devices...");
      //Serial1.println("Initializing I2C devices...");
      accelgyro.initialize();
      // verify connection
      Serial.println("Testing device connections...");
      //Serial1.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
      // use the code below to change accel/gyro offset values
        Serial.println("Updating internal sensor offsets...");
        // -76    -2359    1688    0    0    0
        Serial.print(accelgyro.getXAccelOffset()); Serial.print("\t"); // -76
        Serial.print(accelgyro.getYAccelOffset()); Serial.print("\t"); // -2359
        Serial.print(accelgyro.getZAccelOffset()); Serial.print("\t"); // 1688
        Serial.print(accelgyro.getXGyroOffset()); Serial.print("\t"); // 0
        Serial.print(accelgyro.getYGyroOffset()); Serial.print("\t"); // 0
        Serial.print(accelgyro.getZGyroOffset()); Serial.print("\t"); // 0
        Serial.print("\n");
        accelgyro.setXGyroOffset(220);
        accelgyro.setYGyroOffset(76);
        accelgyro.setZGyroOffset(-85);
        Serial.print("\n");
      // configure Arduino LED pin for output
      pinMode(LED_PIN, OUTPUT);
    void loop() {
      // read raw accel/gyro measurements from device
      accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
      // these methods (and a few others) are also available
      //accelgyro.getAcceleration(&ax, &ay, &az);
      //accelgyro.getRotation(&gx, &gy, &gz);
    #ifdef OUTPUT_READABLE_ACCELGYRO
      // display tab-separated accel/gyro x/y/z values
      Serial.print("a/g:\t");
      Serial.print(ax); Serial.print("\t");
      Serial.print(ay); Serial.print("\t");
      Serial.print(az); Serial.print("\t");
      Serial.print(gx); Serial.print("\t");
      Serial.print(gy); Serial.print("\t");
      Serial.println(gz);
        Serial1.print("a/g:\t");
        Serial1.print(ax); Serial1.print("\t");
        Serial1.print(ay); Serial1.print("\t");
        Serial1.print(az); Serial1.print("\t");
        Serial1.print(gx); Serial1.print("\t");
        Serial1.print(gy); Serial1.print("\t");
        Serial1.println(gz);
    #endif
    #ifdef OUTPUT_BINARY_ACCELGYRO
      Serial.write((uint8_t)(ax >> 8)); Serial.write((uint8_t)(ax & 0xFF));
      Serial.write((uint8_t)(ay >> 8)); Serial.write((uint8_t)(ay & 0xFF));
      Serial.write((uint8_t)(az >> 8)); Serial.write((uint8_t)(az & 0xFF));
      Serial.write((uint8_t)(gx >> 8)); Serial.write((uint8_t)(gx & 0xFF));
      Serial.write((uint8_t)(gy >> 8)); Serial.write((uint8_t)(gy & 0xFF));
      Serial.write((uint8_t)(gz >> 8)); Serial.write((uint8_t)(gz & 0xFF));
        Serial1.write((uint8_t)(ax >> 8)); Serial1.write((uint8_t)(ax & 0xFF));
        Serial1.write((uint8_t)(ay >> 8)); Serial1.write((uint8_t)(ay & 0xFF));
        Serial1.write((uint8_t)(az >> 8)); Serial1.write((uint8_t)(az & 0xFF));
        Serial1.write((uint8_t)(gx >> 8)); Serial1.write((uint8_t)(gx & 0xFF));
        Serial1.write((uint8_t)(gy >> 8)); Serial1.write((uint8_t)(gy & 0xFF));
        Serial1.write((uint8_t)(gz >> 8)); Serial1.write((uint8_t)(gz & 0xFF));
    #endif
      // blink LED to indicate activity
      blinkState = !blinkState;
      digitalWrite(LED_PIN, blinkState);
    der auch in der dargestellten form funktioniert und die RAW-werte der MPU über die Serialprint funktion auf dem monitor ausgibt....
    das hier, also der start der Serial und Serial1
    macht noch keine probleme. Wenn ich aber in diesen zeilen:
    die zwei slashes vor Serial1.Println entferne (der erster versuch über serial1 zu drucken), geht plötzlich nichts mehr....
    Ich habe keinen blassen schimmer warum das so ist. Hat jemand von Euch evtl. eine erklärung dafür?
    gruß inka
    HaWe
    warum übergibst du Textmeldungen zusätzlich an Serial1? Welches Device oder welche Konsole soll denn an Serial1 deinen String entgegen nehmen? Wozu soll Serial1 überhaupt benutzt werden?
    nahe Dresden
    ich übergebe die textmeldungen an Serial und Serial1. testweise. Wenn der roboter unterwegs ist, habe ich ja kein lade/datenkabel am arduino, aber bluetooth der an RX1/TX1 hängt, am PC auch ein BT modul welches die textmeldungen am seriellem monitor ausgibt...
    gruß inka
    HaWe
    aha!
    Zur Fehler-Eingrenzung:
    lass doch mal den ganzen mpu Teil weg und teste, ob nur der Serial + Serial1.print Teil funktioniert, am besten in einer Zählschleife, in denen ein Loop-Count hochgezählt und ausgegeben wird.
    (Mir fehlt zZt ein Erklärungsmodell, wie oder warum Serial1 und Wire für den mpu sich gegenseitig stören können)
    nahe Dresden
    könnte das hier etwas damit zu tun haben?
    gruß inka
    HaWe
    weß ich nicht, ich kenne Serial1 auch nur von AVR Mega2560 oder ARM Due, daher dachte ich du hast einen von diesen beiden
    nahe Dresden
    ich benutze den atmega 2560
    gruß inka
    HaWe
    dein Link meint ja doch ATmega8 .
    Ich hatte jedenfalls nie Probleme auf dem Arduino Mega mit I2C und vielen Serials gleichzeitig.
    Was sagt der test mit Serial+Serial1 ohne mpu?
    nahe Dresden
    also ohne mpu verwende ich die kombination sehr oft, hier z.b. werden an der gleichen hardware die radencoder ausgelesen und ausgegeben. Funktioniert mit serial, wie auch mit serial1. Gerade noch einmal getestet...
    #include "Arduino.h"
    #include <LCD.h>
    #include <LiquidCrystal_I2C.h>
    #include <Wire.h>
    #include <Adafruit_MotorShield.h>
    #define encoder_A 2
    #define encoder_B 3
    uint8_t i, speed, s_speed, m_speed, b_speed;
    int wert_encoder_[] = {1, 2};
    int mehrfach_enc_zaehler_[] = {1, 2};
    int summe_encoder_[] = {1, 2};
    int vorwaerts_[] = {1, 2};
    unsigned long dauer_servo, dauer_fahrt, currentMillis, previousMillis;
    Adafruit_MotorShield AFMS = Adafruit_MotorShield();
    Adafruit_DCMotor *motor_A = AFMS.getMotor(3);//
    Adafruit_DCMotor *motor_B = AFMS.getMotor(4);//
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
    void setup()
      lcd.begin(16, 2);
      lcd.clear();
      lcd.setCursor(0, 0);
      lcd.setBacklight(HIGH);
      lcd.print("alle_mot_enc_1");
      lcd.setCursor(0, 1);
      lcd.print("ausl_li_re");
      delay(2000);
      lcd.clear();
      pinMode(encoder_A, INPUT_PULLUP);
      pinMode(encoder_B, INPUT_PULLUP);
    s_speed = 100;
      m_speed = 150;
      b_speed = 200;
      speed = 150;
    for (i = 1; i < 2; i++)
        vorwaerts_[i] = 1;
        wert_encoder_[i] = 0;
        mehrfach_enc_zaehler_[i] = 0;
      AFMS.begin();
    void loop()
    if (vorwaerts_[1] == 1) rueckwaerts();
      else vorwaerts();
    void motor_stop(void)
      motor_A->setSpeed(0);
      motor_B->setSpeed(0);
      motor_A->run(BRAKE);
      motor_B->run(BRAKE);
      motor_A->run(RELEASE);
      motor_B->run(RELEASE);
      delay(250);
      summe_encoder_[1] = 0;
    void rueckwaerts(void)
      motor_A->setSpeed(speed);
      motor_B->setSpeed(speed);
      motor_A->run(BACKWARD);
      motor_B->run(BACKWARD);
      encoder_auslesen_A();
      if (summe_encoder_[1] >= 100)
        vorwaerts_[1] = 0;
        motor_stop();
    void vorwaerts(void)
      motor_A->run(FORWARD);
      motor_B->run(FORWARD);
      if (summe_encoder_[1] <= -100) //>= 100)
        vorwaerts_[1] = 1;
        motor_stop();
    void encoder_auslesen_A(void)
      wert_encoder_[1] = digitalRead(encoder_A);
        if (wert_encoder_[1] == 0 && mehrfach_enc_zaehler_[1] == 0)
          mehrfach_enc_zaehler_[1] = 1;
        else if (wert_encoder_[1] == 1 && mehrfach_enc_zaehler_[1] == 1)
          mehrfach_enc_zaehler_[1] = 0;
          summe_encoder_[1] = (summe_encoder_[1] + wert_encoder_[1]);
          Serial.print(wert_encoder_[1]);
          Serial.print("    ");
          Serial.println(summe_encoder_[1]);
          Serial1.print(wert_encoder_[1]);
          Serial1.print("    ");
          Serial1.println(summe_encoder_[1]);
      else
          summe_encoder_[1] = (summe_encoder_[1] - wert_encoder_[1]); //+
          Serial.print("    ");
          Serial1.print("    ");
    gruß inka
    HaWe
    ok, dann muss ich passen, ich kenne auch deine mpu libs nicht.
  1. Bluetoothmodul HC05 braucht manchmal ein Startsignal?
    Von fredyxx im Forum Arduino -Plattform
    Antworten: 8
    Letzter Beitrag: 30.01.2017, 09:05
  2. MPU6050 abfragen/auslesen
    Von Julian Werner im Forum Sensoren / Sensorik
    Letzter Beitrag: 17.07.2014, 17:03
  3. Gyroskop Offset Kompensation (MPU6050)
    Von malthy im Forum Sensoren / Sensorik
    Letzter Beitrag: 01.01.2014, 18:16
  4. MPU6050 mit Atmega32
    Von Kreata im Forum Sensoren / Sensorik
    Antworten: 12
    Letzter Beitrag: 21.04.2013, 23:03
  5. [ERLEDIGT] MPU6050 Initialisieren mit dem Netduino
    Von Robo-Hero im Forum Sensoren / Sensorik
    Letzter Beitrag: 05.02.2013, 12:02
