Hallo Zusammen,
verwendet von Euch jemand den ADS1115 in Verbindung mit dem ALARM/RDY Signal ?
Ich verwende folgende Init Routine und sofort habe ich Impuls auf dem RDY Signal,
obwohl ich nur eine einize Messung haben will (Single Shoot).
    ret = i2c_start(ADS1115_I2C_BUS_ADRESS+I2C_WRITE);   // set device address and write mode
    if ( ret )
      i2c_stop();        /* failed to issue start condition, possibly no device found */
    else
      i2c_write(ADS1115_RA_LO_THRESH);                            // Select the Pointer register with Low thread hold
      i2c_write(0x00);                                            // write value zero into the high Byte
      i2c_write(0x00);                                            // write value zero into the low Byte
      i2c_stop();                                                // set stop condition = release bus
   if ( ret )
   else
        i2c_write(ADS1115_RA_HI_THRESH);                        // Select the Pointer register with High thread hold
        i2c_write(0x80);                                        // write value max. value into the high Byte
        i2c_write(0x00);                                        // write value max. value into the low Byte
    iActualAnalogInput=4;                                        // read the last once for init function of the Ready pin
    if ( ret )
    else
      i2c_write(ADS1115_RA_CONFIG);                                // Select the Pointer register with Configuration
      iRegisterValue = 0xC1;                                     // OS Mode / 6.111v Full range / Single shot
      i2c_write(iRegisterValue);                                // write value into the High Byte of Config. Register
      iRegisterValue = 0x8C;                                     // 128 SPS / Trans. Comp mode/High pole/Latched /After one conv.
      i2c_write(iRegisterValue);                                // write value into the low Byte of Config. Register
Wo mache ich den Fehler ? Bild
Viele Grüße
R.
