- Labornetzteil AliExpress
Ergebnis 1 bis 1 von 1
Thema: Bekomme mein Makefile (C++) nicht zum laufen
    ich programmiere Mikrocontroller mit meinem Macbook via Xcode mit Xavr template,
    leider muss ich aber jetzt auf Klassen zurück greifen .
    Dieses Makefile von Xavr kann damit aber nicht arbeiten und daher wollte ich es überarbeiten
    Leider will es nicht, es wäre nett wenn mir dabei wer helfen könnte. Ich glaube soweit fehlt es gar nicht aber dieses Originale makefile hats in meinen Augen schon insich zumindestens für einen Anfänger.
    # Hey Emacs, this is a -*- makefile -*-
    # WinAVR Makefile Template written by Eric B. Weddington, Jörg Wunsch, et al.
    # Released to the Public Domain
    # Additional material for this makefile was written by:
    # Peter Fleury
    # Tim Henigan
    # Colin O'Flynn
    # Reiner Patommel
    # Markus Pfaff
    # Sander Pool
    # Frederik Rouleau
    # On command line:
    # make all = Make software.
    # make clean = Clean out built project files.
    # make coff = Convert ELF to AVR COFF.
    # make extcoff = Convert ELF to AVR Extended COFF.
    # make program = Download the hex file to the device, using avrdude.
    #                Please customize the avrdude settings below first!
    # make debug = Start either simulavr or avarice as specified for debugging,
    #              with avr-gdb or avr-insight as the front end for debugging.
    # make filename.s = Just compile filename.c into the assembler code only.
    # make filename.i = Create a preprocessed source file for use in submitting
    #                   bug reports to the GCC project.
    # To rebuild project do "make clean" then "make all".
    #include conf.mk
    # MCU name
    MCU = atmega328p
    # Processor frequency.
    #     This will define a symbol, F_CPU, in all source code files equal to the
    #     processor frequency. You can then use this symbol in your source code to
    #     calculate timings. Do NOT tack on a 'UL' at the end, this will be done
    #     automatically to create a 32-bit value in your source code.
    F_CPU = 8000000
    AVRDUDE_PROGRAMMER = stk500
    # com1 = serial port. Use lpt1 to connect to parallel port.
    AVRDUDE_PORT = /dev/cu.usbmodem*    # Programmer connected to serial device
    # Output format. (can be srec, ihex, binary)
    FORMAT = ihex
    # Target file name (without extension).
    TARGET = main
    # List C source files here. (C dependencies are automatically generated.)
    SRC = $(wildcard *.c)
    CPPSRC = $(wildcard *.cpp)
    OBJDIR = Builds
    # List Assembler source files here.
    #     Make them always end in a capital .S.  Files ending in a lowercase .s
    #     will not be considered source files but generated files (assembler
    #     output from the compiler), and will be deleted upon "make clean"!
    #     Even though the DOS/Win* filesystem matches both .s and .S the same,
    #     it will preserve the spelling of the filenames, and GCC itself does
    #     care about how the name is spelled on its command-line.
    ASRC = $(wildcard *.S)
    # Optimization level, can be [0, 1, 2, 3, s].
    #     0 = turn off optimization. s = optimize for size.
    #     (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
    OPT = s
    # Debugging format.
    #     Native formats for AVR-GCC's -g are dwarf-2 [default] or stabs.
    #     AVR Studio 4.10 requires dwarf-2.
    #     AVR [Extended] COFF format requires stabs, plus an avr-objcopy run.
    DEBUG = stabs
    # List any extra directories to look for include files here.
    #     Each directory must be seperated by a space.
    #     Use forward slashes for directory separators.
    #     For a directory that has spaces, enclose it in quotes.
    EXTRAINCDIRS =
    # Compiler flag to set the C Standard level.
    #     c89   = "ANSI" C
    #     gnu89 = c89 plus GCC extensions
    #     c99   = ISO C99 standard (not yet fully implemented)
    #     gnu99 = c99 plus GCC extensions
    CSTANDARD = -std=gnu99
    # Place -D or -U options here for C sources
    CDEFS = -DF_CPU=$(F_CPU)UL
    # Place -D or -U options here for C++ sources
    CPPDEFS = -DF_CPU=$(F_CPU)UL
    #CPPDEFS += -D__STDC_LIMIT_MACROS
    #CPPDEFS += -D__STDC_CONSTANT_MACROS
    # Place -I options here
    CINCS =
    #---------------- Compiler Options C ----------------
    #  -g*:          generate debugging information
    #  -O*:          optimization level
    #  -f...:        tuning, see GCC manual and avr-libc documentation
    #  -Wall...:     warning level
    #  -Wa,...:      tell GCC to pass this to the assembler.
    #    -adhlns...: create assembler listing
    CFLAGS = -g$(DEBUG)
    CFLAGS += $(CDEFS) $(CINCS)
    CFLAGS += -O$(OPT)
    CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
    CFLAGS += -Wall -Wstrict-prototypes
    CFLAGS += -Wa,-adhlns=$(addprefix $(OBJDIR)/,$(<:.c=.lst))
    CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
    CFLAGS += $(CSTANDARD)
    CFLAGS += -gstabs
    CFLAGS += -gstrict-dwarf
    #---------------- Compiler Options C++ ----------------
    CPPFLAGS = -g$(DEBUG)
    CPPFLAGS += $(CPPDEFS)
    CPPFLAGS += -O$(OPT)
    #CPPFLAGS += -mint8
    #CPPFLAGS += -mshort-calls
    CPPFLAGS += -funsigned-char
    CPPFLAGS += -funsigned-bitfields
    CPPFLAGS += -fpack-struct
    CPPFLAGS += -fshort-enums
    CPPFLAGS += -fno-exceptions
    #CPPFLAGS += -fno-unit-at-a-time
    CPPFLAGS += -Wall
    #CPPFLAGS += -Wstrict-prototypes
    CFLAGS += -Wundef
    #CPPFLAGS += -Wunreachable-code
    #CPPFLAGS += -Wsign-compare
    CPPFLAGS += -Wa,-adhlns=$(<:%.cpp=$(OBJDIR)/%.lst)
    CPPFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
    #CPPFLAGS += $(CSTANDARD)
    #---------------- Assembler Options ----------------
    #  -ahlms:    create listing
    #  -gstabs:   have the assembler create line number information; note that
    #             for use in COFF files, additional information about filenames
    #             and function names needs to be present in the assembler source
    #             files -- see avr-libc docs [FIXME: not yet described there]
    #  -listing-cont-lines: Sets the maximum number of continuation lines of hex
    #       dump that will be displayed for a given single line of source input.
    ASFLAGS = -Wa,-adhlns=$(addprefix $(OBJDIR)/,$(<:.S=.lst)),-gstabs,--listing-cont-lines=100
    #---------------- Library Options ----------------
    # Minimalistic printf version
    PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
    # Floating point printf version (requires MATH_LIB = -lm below)
    PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
    # If this is left blank, then it will use the Standard printf version.
    PRINTF_LIB =
    #PRINTF_LIB = $(PRINTF_LIB_MIN)
    #PRINTF_LIB = $(PRINTF_LIB_FLOAT)
    # Minimalistic scanf version
    SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
    # Floating point + %[ scanf version (requires MATH_LIB = -lm below)
    SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
    # If this is left blank, then it will use the Standard scanf version.
    SCANF_LIB =
    #SCANF_LIB = $(SCANF_LIB_MIN)
    #SCANF_LIB = $(SCANF_LIB_FLOAT)
    MATH_LIB = -lm
    #---------------- External Memory Options ----------------
    # 64 KB of external RAM, starting after internal RAM (ATmega128!),
    # used for variables (.data/.bss) and heap (malloc()).
    #EXTMEMOPTS = -Wl,--section-start,.data=0x801100,--defsym=__heap_end=0x80ffff
    # only used for heap (malloc()).
    #EXTMEMOPTS = -Wl,--defsym=__heap_start=0x801100,--defsym=__heap_end=0x80ffff
    EXTMEMOPTS =
    #---------------- Linker Options ----------------
    #  -Wl,...:     tell GCC to pass this to linker.
    #    -Map:      create map file
    #    --cref:    add cross reference to  map file
    LDFLAGS = -Wl,-Map=$(OBJDIR)/$(TARGET).map,--cref
    LDFLAGS += $(EXTMEMOPTS)
    LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
    #---------------- Programming Options (avrdude) ----------------
    # Programming hardware: alf AVR910 avrisp Bascom bsd
    # dt006 pavr picoweb pony-stk200 sp12 stk200 stk500
    # Type: avrdude -c ?
    # to get a full listing.
    AVRDUDE_WRITE_FLASH = -U flash:w:$(OBJDIR)/$(TARGET).hex
    #AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
    # Uncomment the following if you want avrdude's erase cycle counter.
    # Note that this counter needs to be initialized first using -Yn,
    # see avrdude manual.
    #AVRDUDE_ERASE_COUNTER = -y
    # Uncomment the following if you do /not/ wish a verification to be
    # performed after programming the device.
    #AVRDUDE_NO_VERIFY = -V
    # Increase verbosity level.  Please use this when submitting bug
    # reports about avrdude. See <http://savannah.nongnu.org/projects/avrdude>
    # to submit bug reports.
    #AVRDUDE_VERBOSE = -v -v
    AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
    AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
    AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
    AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
    #---------------- Debugging Options ----------------
    # For simulavr only - target MCU frequency.
    DEBUG_MFREQ = $(F_CPU)
    # Set the DEBUG_UI to either gdb or insight.
    # DEBUG_UI = gdb
    DEBUG_UI = insight
    # Set the debugging back-end to either avarice, simulavr.
    DEBUG_BACKEND = avarice
    #DEBUG_BACKEND = simulavr
    # GDB Init Filename.
    GDBINIT_FILE = __avr_gdbinit
    # When using avarice settings for the JTAG
    JTAG_DEV = /dev/com1
    # Debugging port used to communicate between GDB / avarice / simulavr.
    DEBUG_PORT = 4242
    # Debugging host used to communicate between GDB / avarice / simulavr, normally
    #     just set to localhost unless doing some sort of crazy debugging when
    #     avarice is running on a different computer.
    DEBUG_HOST = localhost
    # Define programs and commands.
    SHELL = sh
    CC = /usr/local/CrossPack-AVR/bin/avr-gcc
    OBJCOPY = /usr/local/CrossPack-AVR/bin/avr-objcopy
    OBJDUMP = /usr/local/CrossPack-AVR/bin/avr-objdump
    SIZE = /usr/local/CrossPack-AVR/bin/avr-size
    NM = /usr/local/CrossPack-AVR/bin/avr-nm
    AVRDUDE = /usr/local/CrossPack-AVR/bin/avrdude
    REMOVE = rm -f
    COPY = cp
    WINSHELL = cmd
    # Define Messages
    # English
    MSG_ERRORS_NONE = Errors: none
    MSG_BEGIN = -------- begin --------
    MSG_END = --------  end  --------
    MSG_SIZE_BEFORE = Size before:
    MSG_SIZE_AFTER = Size after:
    MSG_COFF = Converting to AVR COFF:
    MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
    MSG_FLASH = Creating load file for Flash:
    MSG_EEPROM = Creating load file for EEPROM:
    MSG_EXTENDED_LISTING = Creating Extended Listing:
    MSG_SYMBOL_TABLE = Creating Symbol Table:
    MSG_LINKING = Linking:
    MSG_COMPILING = Compiling C:
    MSG_ASSEMBLING = Assembling:
    MSG_CLEANING = Cleaning project:
    MSG_COMPILING_CPP = Compiling C++:
    # Define all object files.
    OBJ = $(addprefix $(OBJDIR)/,$(SRC:.c=.o)) $(addprefix $(OBJDIR)/,$(CPPSRC:.cpp=.o)) $(addprefix $(OBJDIR)/,$(ASRC:.S=.o))
    # Define all listing files.
    LST = $(addprefix $(OBJDIR)/,$(SRC:.c=.lst)) $(addprefix $(OBJDIR)/,$(CPPSRC:.cpp=.lst)) $(addprefix $(OBJDIR)/,$(ASRC:.S=.lst))
    # Compiler flags to generate dependency files.
    GENDEPFLAGS = -M
    # Combine all necessary flags and optional flags.
    # Add target processor to flags.
    ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS)
    ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
    ALL_CPPFLAGS = -mmcu=$(MCU) -I. -x c++ $(CPPFLAGS)
    #ALL_CPPFLAGS = -mmcu=$(MCU) -I. -x c++ $(CPPFLAGS) $(GENDEPFLAGS)
    # Generate dependency files
    DEPSDIR   = $(OBJDIR)/.dep
    DEPS      = $(SRC:%.c=$(DEPSDIR)/%.d)
    CPPDEPS   = $(CPPSRC:%.cpp=$(DEPSDIR)/%.d)
    -include $(DEPS)
    -include $(CPPDEPS)
    $(DEPSDIR):
    	mkdir -p $(DEPSDIR)
    .DELETE_ON_ERROR:
    $(DEPSDIR)/%.d: %.c | $(DEPSDIR)
    	$(CC) $(ALL_ASFLAGS) $(GENDEPFLAGS) -MT $(patsubst %.c,$(OBJDIR)/%.o,$<) -MF $@ $<
    # Default target.
    all: begin gccversion sizebefore clean build program sizeafter end
    build: $(OBJDIR) elf hex eep lss sym
    elf: $(OBJDIR)/$(TARGET).elf
    hex: $(OBJDIR)/$(TARGET).hex
    eep: $(OBJDIR)/$(TARGET).eep
    lss: $(OBJDIR)/$(TARGET).lss
    sym: $(OBJDIR)/$(TARGET).sym
    $(OBJDIR):
    	@mkdir -p $@
    # Eye candy.
    # AVR Studio 3.x does not check make's exit code but relies on
    # the following magic strings to be generated by the compile job.
    begin:
    	@echo
    	@echo $(MSG_BEGIN)
    end:
    	@echo $(MSG_END)
    	@echo
    # Display size of file.
    HEXSIZE = $(SIZE) --target=$(FORMAT) $(OBJDIR)/$(TARGET).hex
    ELFSIZE = $(SIZE) --format=avr $(OBJDIR)/$(TARGET).elf
    sizebefore:
    	@if test -f $(OBJDIR)/$(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \
    	2>/dev/null; echo; fi
    sizeafter:
    	@if test -f $(OBJDIR)/$(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \
    # Display compiler version information.
    gccversion :
    	@$(CC) --version
    # Program the device.
    program: $(OBJDIR)/$(TARGET).hex $(OBJDIR)/$(TARGET).eep
    	$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
    # Generate avr-gdb config/init file which does the following:
    #     define the reset signal, load the target file, connect to target, and set
    #     a breakpoint at main().
    gdb-config:
    	@$(REMOVE) $(GDBINIT_FILE)
    	@echo define reset >> $(GDBINIT_FILE)
    	@echo SIGNAL SIGHUP >> $(GDBINIT_FILE)
    	@echo end >> $(GDBINIT_FILE)
    	@echo file $(OBJDIR)/$(TARGET).elf >> $(GDBINIT_FILE)
    	@echo target remote $(DEBUG_HOST):$(DEBUG_PORT)  >> $(GDBINIT_FILE)
    ifeq ($(DEBUG_BACKEND),simulavr)
    	@echo load  >> $(GDBINIT_FILE)
    endif
    	@echo break main >> $(GDBINIT_FILE)
    debug: gdb-config $(OBJDIR)/$(TARGET).elf
    ifeq ($(DEBUG_BACKEND), avarice)
    	@echo Starting AVaRICE - Press enter when "waiting to connect" message displays.
    	@$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \
    	$(OBJDIR)/$(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT)
    	@$(WINSHELL) /c pause
    else
    	@$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \
    	$(DEBUG_MFREQ) --port $(DEBUG_PORT)
    endif
    	@$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE)
    # Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
    COFFCONVERT=$(OBJCOPY) --debugging \
    --change-section-address .data-0x800000 \
    --change-section-address .bss-0x800000 \
    --change-section-address .noinit-0x800000 \
    --change-section-address .eeprom-0x810000
    coff: $(OBJDIR)/$(TARGET).elf
    	@echo
    	@echo $(MSG_COFF) $(OBJDIR)/$(TARGET).cof
    	$(COFFCONVERT) -O coff-avr $< $(OBJDIR)/$(TARGET).cof
    extcoff: $(OBJDIR)/$(TARGET).elf
    	@echo
    	@echo $(MSG_EXTENDED_COFF) $(OBJDIR)/$(TARGET).cof
    	$(COFFCONVERT) -O coff-ext-avr $< $(OBJDIR)/$(TARGET).cof
    # Create final output files (.hex, .eep) from ELF output file.
    $(OBJDIR)/%.hex: $(OBJDIR)/%.elf
    	@echo
    	@echo $(MSG_FLASH) $@
    	$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
    $(OBJDIR)/%.eep: $(OBJDIR)/%.elf
    	@echo
    	@echo $(MSG_EEPROM) $@
    	-$(OBJCOPY) -j .eeprom --set-section-flags .eeprom=alloc,load \
    	--change-section-lma .eeprom=0 -O $(FORMAT) $< $@
    # Create extended listing file from ELF output file.
    $(OBJDIR)/%.lss: $(OBJDIR)/%.elf
    	@echo
    	@echo $(MSG_EXTENDED_LISTING) $@
    	$(OBJDUMP) -h -S $< > $@
    # Create a symbol table from ELF output file.
    $(OBJDIR)/%.sym: $(OBJDIR)/%.elf
    	@echo
    	@echo $(MSG_SYMBOL_TABLE) $@
    	$(NM) -n $< > $@
    # Link: create ELF output file from object files.
    .SECONDARY : $(OBJDIR)/$(TARGET).elf
    .PRECIOUS : $(OBJ)
    $(OBJDIR)/%.elf: $(OBJ)
    	@echo
    	@echo $(MSG_LINKING) $@
    	$(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS)
    # Compile: create object files from C source files.
    $(OBJDIR)/%.o : %.c
    	@echo
    	@echo $(MSG_COMPILING) $<
    	$(CC) -c $(ALL_CFLAGS) "$(abspath $<)" -o $@
    # Compile: create object files from Cpp source files.
    $(OBJDIR)/%.o : %.cpp
    	@echo
    	@echo $(MSG_COMPILING_CPP) $<
    	$(CC) -c $(ALL_CPPFLAGS) "$(abspath $<)" -o $@
    # Compile: create assembler files from C source files.
    $(OBJDIR)/%.s : %.c
    	$(CC) -S $(ALL_CFLAGS) $< -o $@
    # Compile: create assembler files from C++ source files.
    %.s : %.cpp
    	$(CC) -S $(ALL_CPPFLAGS) $< -o $@
    # Assemble: create object files from assembler source files.
    $(OBJDIR)/%.o : %.S
    	@echo
    	@echo $(MSG_ASSEMBLING) $<
    	$(CC) -c $(ALL_ASFLAGS) $< -o $@
    # Create preprocessed source for use in sending a bug report.
    $(OBJDIR)/%.i : %.c
    	$(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@
    # Target: clean project.
    clean: begin clean_list end
    clean_list :
    	@echo
    	@echo $(MSG_CLEANING)
    	$(REMOVE) $(OBJDIR)/$(TARGET).hex
    	$(REMOVE) $(OBJDIR)/$(TARGET).eep
    	$(REMOVE) $(OBJDIR)/$(TARGET).cof
    	$(REMOVE) $(OBJDIR)/$(TARGET).elf
    	$(REMOVE) $(OBJDIR)/$(TARGET).map
    	$(REMOVE) $(OBJDIR)/$(TARGET).sym
    	$(REMOVE) $(OBJDIR)/$(TARGET).lss
    	$(REMOVE) $(OBJ)
    	$(REMOVE) $(LST)
    	$(REMOVE) $(OBJDIR)/$(SRC:.c=.s)
    	$(REMOVE) $(OBJDIR)/$(SRC:.c=.d)
    	$(REMOVE) $(OBJDIR)/.dep/*
    # Listing of phony targets.make
    .PHONY : all begin finish end sizebefore sizeafter gccversion \
    build elf hex eep lss sym coff extcoff \
    clean clean_list program debug gdb-config
    Irgendwie muss bei der C++ Implementierung ein Fehler sein.
    Miniaturansichten angehängter Grafiken Miniaturansichten angehängter Grafiken Bildschirmfoto 2016-09-05 um 23.07.59.jpg
  1. T6963 bekomme ihn nicht zum laufen
    Von Felix H. im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 11.03.2009, 19:40
  2. Bekomme ISP nicht zum laufen.
    Von FoCus im Forum AVR Hardwarethemen
    Antworten: 11
    Letzter Beitrag: 02.02.2006, 07:27
  3. bekomme in ATmega16 Schaltung I2C und ISP nicht zum laufen
    Von highbeta im Forum AVR Hardwarethemen
    Letzter Beitrag: 17.11.2005, 09:13
  4. Bekomme RP5 nicht zum laufen
    Von Mitshci im Forum Robby CCRP5
    Letzter Beitrag: 27.10.2004, 14:49
  5. Bekomme Timer1 bei 2313 nicht zum laufen
    Von im Forum Basic-Programmierung (Bascom-Compiler)
    Antworten: 4
    Letzter Beitrag: 06.08.2004, 16:38
