Hey there,
I have a problem: I want to change the member of a class A from class B. So I made class B to a friend of class A. There is a function in class B that changes the variable "state". And in class A there is a function that checks if the variable "state" is 1. If true it will turn on an Led. I wrote this code:
But it doesnt work. Where is the mistake? I hope somebody can help me.Code:class A { friend class B; private: int state; int Led = 13; A(){ pinMode(Led, OUTPUT); } void update(){ if (state == 1){ digitalWrite (Led, HIGH); } } }; class B{ public: void update(){ state = 1; } }; A first; B second; void setup() { // put your setup code here, to run once: } void loop() { // put your main code here, to run repeatedly: first.update(); second.update(); }
Best regards
Maurice W.
Zitieren
