Thema: Change member of a class from another class
    Beitrag Change member of a class from another class
    Hey there,
    I have a problem: I want to change the member of a class A from class B. So I made class B to a friend of class A. There is a function in class B that changes the variable "state". And in class A there is a function that checks if the variable "state" is 1. If true it will turn on an Led. I wrote this code:
    class A {
      friend class B;
      private:
      int state;
      int Led = 13;
      A(){
      pinMode(Led, OUTPUT);
      void update(){
      if (state == 1){
      digitalWrite (Led, HIGH);
    class B{
      public:
      void update(){
        state = 1;
    A first;
    B second;
    void setup() {
      // put your setup code here, to run once:
    void loop() {
      // put your main code here, to run repeatedly:
      first.update();
      second.update();
    But it doesnt work. Where is the mistake? I hope somebody can help me.
    Best regards
    Maurice W.
    Hessen
    the friend declaration does only say that B has access to A's private and protected elements.
    But an instance of B does not know in which instance of A it should change the value of state. You could have something like this
    A a, b, c;
    there are three objects of type A, which one do you want to change ?
    One possible solution would be giving B's update a parameter
    class B{
      public:
      void update(A& a){
        a.state = 1;
    and using it this way
    void loop() {
      first.update();
      second.update(first);
    Much better C++ would be giving A a changeState method, instead of using friend.
    Geändert von Mxt (27.08.2016 um 10:01 Uhr) Grund: removed const
  1. Probleme mit Class-D-Audioverstärker / Digitalendstufe
    Von altekischt im Forum Elektronik
    Antworten: 0
    Letzter Beitrag: 27.11.2012, 18:44
  2. EAGLE Forward Backward Net Class
    Von magic33 im Forum Konstruktion/CAD/3D-Druck/Sketchup und Platinenlayout Eagle & Fritzing u.a.
    Letzter Beitrag: 19.11.2007, 12:06
  3. Class AB Verstärker
    Von Johannes G. im Forum Elektronik
    Antworten: 25
    Letzter Beitrag: 03.02.2007, 12:44
  4. Class Wizard
    Von blizzard im Forum PC-, Pocket PC, Tablet PC, Smartphone oder Notebook
    Letzter Beitrag: 21.08.2005, 09:54
Stichworte
