Hello there,
I'm working on a new project. One important topic is to save power in standalone Atmega 328PU. The microcontroller is into a deep sleep mode and should only wake up after the button was pressed for over 3 seconds. I wrote the following two codes.
Code:#define LED_PIN 13 void setup() { // put your setup code here, to run once: pinMode(LED_PIN, OUTPUT); //Save Power by writing all Digital I0 LOW for(int i=0; i<20; i++){ if(i != 2)//just because the button is hooked up to digital pin 2 pinMode(i, OUTPUT); } attachInterrupt(0, digitalInterrupt, FALLING); //interrupt for waking up } void loop() { // put your main code here, to run repeatedly: digitalWrite(LED_PIN, HIGH); delay(1000); digitalWrite(LED_PIN, LOW); //DISABLE ADC ADCSRA &= ~(1<<7); //ENABLE SLEEP SMCR |= (1<<2); //power down mode SMCR |= 1; //enable sleep //BOD DISABLE MCUCR |=(3 << 5); //set both BODS and BODSE at the same time MCUCR = (MCUCR & ~(1 << 5)) | (1<< 6); //then set the BODS bit and clear the BODS bit at the same time __asm__ __volatile__("sleep"); } void digitalInterrupt(){ //needed for the digital input interrupt }
Code:int inPin = 2; // the pin number for input (for me a push button) int ledPin = 13; int current; // Current state of the button // (LOW is pressed b/c i'm using the pullup resistors) long millis_held; // How long the button was held (milliseconds) long secs_held; // How long the button was held (seconds) byte previous = HIGH; unsigned long firstTime; // how long since the button was first pressed void setup() { pinMode(ledPin, OUTPUT); digitalWrite(inPin, HIGH); // Turn on 20k pullup resistors to simplify switch input } void loop() { current = digitalRead(inPin); // if the button state changes to pressed, remember the start time if (current == LOW && previous == HIGH) { firstTime = millis(); } millis_held = (millis() - firstTime); secs_held = millis_held / 1000; if (current == LOW && previous == LOW) { // If the button was held for more then 3 seconds blink LED 1 time if (secs_held >= 3) { ledblink(1,4000,ledPin); } } previous = current; } // Just a simple helper function to blink an led in various patterns void ledblink(int times, int lengthms, int pinnum){ for (int x=0; x<times;x++) { digitalWrite(pinnum, HIGH); delay (lengthms); digitalWrite(pinnum, LOW); delay(lengthms); } }
The first code is for the deep sleep mode and wakes the Atmega 328PU up after an external interrupt.
The second code is a normal code (without any power saving option) and reads the digital input and sets a timer if the button was pressed. If the timer is over 3 seconds and the button is still pressed something will happen (for example a LED will flash).
So now my question is how to combine them? Is there any way to do that?
I hope somebody can help meI'm looking forward to your replies.
Best regards
Maurice W.
Zitieren
