Und hier ist der Code
main.cpp
CMakeLists.txtCode:#include <QApplication> #include <QPushButton> #include <QWidget> #include <QFileDialog> #include <iostream> class Window : public QWidget { Q_OBJECT public: explicit Window(QWidget *parent = 0); private slots: void slotButtonClicked(); private: QPushButton *m_button; }; Window::Window(QWidget *parent) : QWidget(parent) { // Set size of the window setFixedSize(100, 50); // Create and position the button m_button = new QPushButton("Hello World", this); m_button->setGeometry(10, 10, 80, 30); connect(m_button, SIGNAL (clicked()), this, SLOT (slotButtonClicked())); } void Window::slotButtonClicked() { QString fname = QFileDialog::getOpenFileName( this, tr("Open File"), "/home", ""); std::cout << fname.toUtf8().constData() << std::endl; } #include "main.moc" int main(int argc, char **argv) { QApplication app (argc, argv); Window wnd; wnd.show(); return app.exec(); }
Code:cmake_minimum_required(VERSION 2.8.11) PROJECT(test C CXX) set(CMAKE_AUTOMOC ON) set(CMAKE_INCLUDE_CURRENT_DIR ON) find_package(Qt5Widgets REQUIRED) include_directories(${Qt5Widgets_INCLUDE_DIRS}) SET(SRCS main.cpp ) SET(LIBS ${Qt5Widgets_LIBRARIES} ) # Executable ADD_EXECUTABLE(qt-test ${SRCS} ) # Linking TARGET_LINK_LIBRARIES(qt-test ${LIBS})
Dateisystem schaut so aus:
BauenCode:georg@xps:/tmp$ tree qttest/ qttest/ ├── CMakeLists.txt └── main.cpp 0 directories, 2 files
AUsführen:Code:georg@xps:/tmp$ cd qttest georg@xps:/tmp/qttest$ mkdir build georg@xps:/tmp/qttest$ cd build/ georg@xps:/tmp/qttest/build$ cmake .. -- The C compiler identification is GNU 5.3.1 -- The CXX compiler identification is GNU 5.3.1 -- Check for working C compiler: /usr/bin/cc -- Check for working C compiler: /usr/bin/cc -- works -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Detecting C compile features -- Detecting C compile features - done -- Check for working CXX compiler: /usr/bin/c++ -- Check for working CXX compiler: /usr/bin/c++ -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Detecting CXX compile features -- Detecting CXX compile features - done -- Configuring done -- Generating done -- Build files have been written to: /tmp/qttest/build georg@xps:/tmp/qttest/build$ make Scanning dependencies of target qt-test_automoc [ 25%] Automatic moc for target qt-test Generating main.moc [ 25%] Built target qt-test_automoc Scanning dependencies of target qt-test [ 50%] Building CXX object CMakeFiles/qt-test.dir/main.cpp.o [ 75%] Building CXX object CMakeFiles/qt-test.dir/qt-test_automoc.cpp.o [100%] Linking CXX executable qt-test [100%] Built target qt-test georg@xps:/tmp/qttest/build$
- - - Aktualisiert - - -Code:georg@xps:/tmp/qttest/build$ ./qt-test
Du must auch nicht die IDE nutzen. Ich nutze Emacs und cmake. cmake weil diese makefiles leicht zu schreiben sind und die Makros die Libs und Includes leicht finden.
Zitieren
