	#include <alsa/asoundlib.h>
#include <iostream>
#include <vector>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <fcntl.h>
using namespace std;
typedef struct _FILE_head
	unsigned char	ID[4];
	unsigned int	Length;
	unsigned char	Type[4];
} FILE_head;
typedef struct _FORMAT
	short wFormatTag;
	unsigned short	wChannels;
	unsigned int	dwSamplesPerSec;
	unsigned int	dwAvgBytesPerSec;
	unsigned short	wBlockAlign;
	unsigned short	wBitsPerSample;
} FORMAT;
typedef struct _CHUNK_head
} CHUNK_head;
snd_pcm_t *soundKarte;
bool Init(string name, unsigned int channels, unsigned int actualRate, unsigned short WaveBits)
	int err;
	snd_pcm_format_t bits;
	unsigned int resample = 1;
	switch(WaveBits)
		case 8:
			bits = SND_PCM_FORMAT_U8;
			break;
		case 16:
			bits = SND_PCM_FORMAT_S16;
			break;
		case 24:
			bits = SND_PCM_FORMAT_S24;
			break;
		case 32:
			bits = SND_PCM_FORMAT_S32;
			break;
	snd_pcm_hw_params_t *hw_params;
	if(name.length() == 0)
		err = snd_pcm_open(&soundKarte, "plughw:1,0", SND_PCM_STREAM_PLAYBACK, 0);
	else
		err = snd_pcm_open(&soundKarte, name.c_str(), SND_PCM_STREAM_PLAYBACK, 0);
	if(err < 0)
		cout << "Init: Kann die Soundkarte nicht öffnen! " << name << " (" << snd_strerror (err) << ")" << endl;
		return false;
	if((err = snd_pcm_hw_params_malloc(&hw_params)) < 0)
		cout << "Init: Parameter können nicht initialisiert werden (" << snd_strerror (err) << ")" << endl;
		return false;
	if((err = snd_pcm_hw_params_any(soundKarte, hw_params)) < 0)
		cout << "Init: Parameter können nicht ermittelt werden (" << snd_strerror (err) << ")" << endl;
		return false;
	err = snd_pcm_hw_params_set_rate_resample(soundKarte, hw_params, resample);
	if(err < 0)
		cout << "Init: Resampling kann nicht eingeschaltet werden " << snd_strerror(err) << endl;
		return err;
	if((err = snd_pcm_hw_params_set_access(soundKarte, hw_params, SND_PCM_ACCESS_RW_INTERLEAVED)) < 0)
		cout << "Init: Zugriffstyp kann nicht gesetzt werden (" << snd_strerror (err) << ")" << endl;
		return false;
	if((err = snd_pcm_hw_params_set_format(soundKarte, hw_params, bits)) < 0)
		cout << "Init: Sample-Format kann nicht gesetzt werden (" << snd_strerror (err) << ")" << endl;
		return false;
	if((err = snd_pcm_hw_params_set_channels(soundKarte, hw_params, channels)) < 0)
		cout << "Init: Anzahl der Kanäle kann nicht gesetzt werden (" << snd_strerror (err) << ")" << endl;
		return false;
	if((err = snd_pcm_hw_params_set_rate_near(soundKarte, hw_params, &actualRate, 0)) < 0)
		cout << "Init: Sample-Rate kann nicht auf " << actualRate << " gesetzt werden (" << snd_strerror (err) << ")"  << endl;
		return false;
	if((err = snd_pcm_hw_params(soundKarte, hw_params)) < 0)
		cout << "Init: Parameters können nicht gesetzt werden(" << snd_strerror (err) << ")" << endl;
		return false;
	snd_pcm_hw_params_free(hw_params);
	if((err = snd_pcm_prepare(soundKarte)) < 0)
		cout << "Init: Audio kann nicht zur Nutzung vorbereitet werden (" << snd_strerror (err) << ")" << endl;
		return false;
	return true;
bool InitCapture(string name, unsigned int channels, unsigned int actualRate, unsigned short WaveBits)
	int err;
	switch(WaveBits)
		case 8:
			break;
		case 16:
			break;
		case 24:
			break;
		case 32:
			break;
		err = snd_pcm_open(&soundKarte, "plughw:1,0", SND_PCM_STREAM_CAPTURE, 0);
	else
		err = snd_pcm_open(&soundKarte, name.c_str(), SND_PCM_STREAM_CAPTURE, 0);
	if(err < 0)
		return false;
		return false;
		return false;
		return false;
		return false;
		return false;
		return false;
		return false;
		return false;
	return true;
bool UnInit()
  snd_pcm_close(soundKarte);
  return true;
int playwave(string waveDatei, string name)
	FORMAT format;
	FILE_head head;
	CHUNK_head chead;
	char *wave;
	register snd_pcm_uframes_t count, frames;
	int datei;
	unsigned int WaveSize;
	datei = open(waveDatei.c_str(), 00);
	read(datei, &head, sizeof(FILE_head));
	read(datei, &chead, sizeof(CHUNK_head));
	read(datei, &format, sizeof(FORMAT));
	wave = (char *) malloc(head.Length);
	read(datei, wave, head.Length);
	WaveSize = head.Length * 8 / ((unsigned int)format.wBitsPerSample * (unsigned int)format.wChannels);
	close(datei);
	Init(name, format.wChannels, format.dwSamplesPerSec, format.wBitsPerSample);
	count = 0;
	do
		frames = snd_pcm_writei(soundKarte, wave + count, WaveSize - count);
		if (frames < 0) frames = snd_pcm_recover(soundKarte, frames, 0);
		if (frames < 0)
			printf("Kann wav nicht abspielen: %s\n", snd_strerror(frames));
			break;
		count += frames;
	} while (count < WaveSize);
	if (count == WaveSize) snd_pcm_drain(soundKarte);
	free(wave);
	UnInit();
	return 0;
vector<int> audioCapture(int SHRT_MAX, string name, unsigned int channels, unsigned int actualRate, unsigned short WaveBits)
	int err, i=0;
	char *puffer;
	vector<int> input;
	puffer = (char *) malloc(1);
	cout << "Beginne Aufnahme" << endl;
	if(InitCapture(name, channels, actualRate, WaveBits))
		while(i < SHRT_MAX)
			err = snd_pcm_readi(soundKarte, puffer, 1);
			if(err < 0) cout << "Fehler bei der Aufnahme!" << endl;
			input.push_back(puffer[0]);
			i++;
		free(puffer);
		UnInit();
	else cout << "Bei der Initialisierung ist ein Fehler aufgetreten!" << endl;
	cout << "Aufnahme beendet!" << endl;
	return input;
void playCaptured(char *wave, unsigned int WaveSize, string name, unsigned int channels, unsigned int actualRate, unsigned short WaveBits)
	Init(name, channels, actualRate, WaveBits);
	WaveSize = WaveSize * 8 / WaveBits * channels;
	count = 0;
//	for(int i=0;i<WaveSize-2;i++) printf("%d/%d -> %d\n", i, WaveSize, wave[i]);
	do
		if(frames < 0) frames = snd_pcm_recover(soundKarte, frames, 0);
		if(frames < 0)
			break;
		count += frames;
	UnInit();
 Das ist der neue Header und hier kommt das neue main:
	#include <iostream>
#include <vector>
#include <fstream>
#include <stdio.h>
#include "diaSound.hpp"
bool debug = false;
int main()
	fstream datei;
	vector<int> input;
	unsigned int i, SHRT_MAX = 32767;
	char *wave;
	input = audioCapture(SHRT_MAX, "plughw:1,0", 1, 12000, 8);
	wave = (char *) malloc(input.size());
	if(debug) datei.open("test.csv", ios::out);
	for(i=0;i<input.size();i++)
		wave[i] = input[i];
		if(debug) datei << input[i] << endl;
	if(debug) datei.close();
	playCaptured(wave, input.size(), "plughw:1,0", 1, 12000, 8);
	free(wave);
	return 1;
 Zufrieden soweit?
