Seite 5 von 5 ErsteErste ... 345
Ergebnis 41 bis 47 von 47
Thema: Welche Soundkarte für den Raspi
  1. #41
    HaWe
    dann spiel doch mal nen wav Sound ab, z.B. mit omxplayer
    - kannst du was hören?
    Test sounds:
    http://sounds.stoutman.com/sounds.ph...ory=HAL%209000
    (zu anderen Themen mach besser immer nen neuen Thread auf, sonst wirds unübersichtlich)
  2. #42
    NRW
    Moin,
    also hier meine Infos zu dem CSL Dingens:
    pi@raspi-bplus:~ $ lsusbBus 001 Device 006: ID 413c:2107 Dell Computer Corp.
    Bus 001 Device 005: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
    Bus 001 Device 004: ID 046d:c526 Logitech, Inc. Nano Receiver
    Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
    Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    [    3.364790] USB 1-1.4: new full-speed USB device number 5 using dwc_otg
    [    3.483051] USB 1-1.4: New USB device found, idVendor=0d8c, idProduct=013c
    [    3.496746] USB 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [    3.510781] USB 1-1.4: Product: USB PnP Sound Device
    [    3.522376] USB 1-1.4: Manufacturer: C-Media Electronics Inc.
    [    3.541162] input: C-Media Electronics Inc.       USB PnP Sound Device as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.3/0003:0D8C:013C.0003/input/input2
    [    3.615076] hid-generic 0003:0D8C:013C.0003: input,hidraw2: USB HID v1.00 Device [C-Media Electronics Inc.       USB PnP Sound Device] on usb-3f980000.usb-1.4/input3
    pi@raspi-bplus:~ $ lsmod
    Module                  Size  Used by
    cfg80211              407580  0
    rfkill                 16036  1 cfg80211
    snd_usb_audio         114378  2
    snd_usbmidi_lib        19597  1 snd_usb_audio
    snd_hwdep               5595  1 snd_usb_audio
    snd_rawmidi            18300  1 snd_usbmidi_lib
    snd_seq_device          3445  1 snd_rawmidi
    joydev                  9024  0
    evdev                  10278  8
    snd_bcm2835            19802  3
    bcm2835_gpiomem         2860  0
    bcm2835_rng             1763  0
    snd_pcm                73474  2 snd_bcm2835,snd_usb_audio
    snd_timer              18848  1 snd_pcm
    snd                    50779  18 snd_bcm2835,snd_usb_audio,snd_hwdep,snd_timer,snd_pcm,snd_rawmidi,snd_usbmidi_lib,snd_seq_device
    uio_pdrv_genirq         2944  0
    uio                     7753  1 uio_pdrv_genirq
    cuse                    4971  1
    i2c_dev                 5671  0
    fuse                   80694  4 cuse
    ipv6                  338660  32
    pi@raspi-bplus:~ $ cat /proc/asound/cards 0 [ALSA           ]: bcm2835 - bcm2835 ALSA
                          bcm2835 ALSA
     1 [Device         ]: USB-Audio - USB PnP Sound Device
                          C-Media Electronics Inc. USB PnP Sound Device at usb-3f980000.usb-1.4, full spe
    nun muss ich dem Dingens nur noch ein Ton entlocken
    Geändert von piggituX (22.05.2016 um 08:11 Uhr)
  3. #43
    HaWe
    was soll man mit dem CSL Dingens anfangen?
  4. #44
    NRW
    nun ja hirnfrei suchte ja ein USB Soundkarte mit Microphone Eingang und ich habe nur noch nachgeliefert das es OOTB am RPI funktionieren kann.
    Und ja es tut es ... somit hab ich fertig.
    cYa
  5. #45
    Saarbrücken
    Also ich musste nur die Karte rein stecken und mit audacious konnte ich sofort Sound so abspielen. Okay ich musste in den Einstellungen die Karte angeben. Aber ansonsten ging es auf anhieb. Wie ich das nun mit dem omxplayer mache weiss ich noch nicht. aber das ist letzten Endes auch kein Hexenwerk denke ich.
    Dann kann es ja bald los gehen!
  6. #46
    Saarbrücken
    So. Nur noch ein Warnsignal von Arduino zu Raspi einbauen, die meldet sobald eine Zelle zu schwach geworden ist, dann gehts los mit der Sprache.
    Was macht mehr Sinn? Neues Thema oder hier weiter schreiben?
  7. #47
    HaWe
    IMO: Neues Thema
  1. Antworten: 63
    Letzter Beitrag: 18.02.2016, 07:43
  2. Soundkarte
    Von oratus sum im Forum PC-, Pocket PC, Tablet PC, Smartphone oder Notebook
    Letzter Beitrag: 16.04.2008, 14:30
  3. Soundkarte Eingänge
    Von harry3 im Forum Elektronik
    Letzter Beitrag: 23.02.2008, 10:57
  4. Oszillograph für die Soundkarte
    Von Malte0815 im Forum Elektronik
    Antworten: 26
    Letzter Beitrag: 22.02.2008, 19:23
  5. Impedanzmessgerät - Soundkarte?
    Von Rage_Empire im Forum Elektronik
    Letzter Beitrag: 19.08.2006, 17:30
