Ergebnis 1 bis 10 von 19
Thema: First release of rp6simul, a simulator for the RP6 and m32
    Niederlande
    Hello all,
    Although AREXX has an official forum, I figured posting this here as well made sense because the majority of the RP6 community seem to hang out in this place. Although I live next to Germany, my German is not in a very good shape, so I hope everyone excuses my use of English on this forum...
    The past few months I have been busy with creating a simulator for the RP6 robot. The simulator is open source (GPL), cross-plaftorm (Windows and Linux binaries are provided) and both the RP6 and its m32 extension board can be simulated either independently or simultaneously. The simulator is especially useful if you want to debug or test your robot code, but also presents a nice 'soft' alternative when for instance your batteries ran out again, or you want to test-drive before acquiring the robot.
    Although this is the first release, it is already contains many features. Most importantly, all the peripherals found on the RP6 and m32 (sensors, ADC devices, timers, motors, TWI, etc) are supported. The simulator itself is written in C++ and uses Qt extensively to provide a nice cross-platform interface with a system native look. Besides easy access to the robot state (sensor data, IO registers, etc), the simulator interface also provides a simple two-dimensional environment in which the robot can move and interact with obstacles and lighting.
    So if you are interested, please visit the project homepage: http://sourceforge.net/p/rp6simul/
    A more detailed description can be found on the about page: http://sourceforge.net/p/rp6simul/wiki/About/
    And, finally some screenshots Bild
    Robot status overview
    Two-dimensional simulation environment
    m32 simulation
    AN ALLE DIE HIER MITLESEN: -Rick- spricht besser englisch als deutsch. Trotzdem könnt ihr auf deutsch antworten, -Rick- wird sein bestes geben eure Antworten zu verstehen und wird dann auf englisch versuchen, euch zu helfen.
    damaltor, 13.01.2012
    Geändert von damaltor (13.01.2012 um 00:38 Uhr)
    Kempten
    Der Next Button im fenster "Projekt erstellen" ist inaktiv. Bug oder was anderes?
    Niederlande
    Hmm .. do you have write access to the selected directory? Can you try another one? I noticed that on Windows sometimes your 'home' directory doesn't work, but for instance "My Documents" does.
    Erfahrener Benutzer Roboter-Spezialist Avatar von -schumi-
    Wasserburg am Inn / Bayern
    Hi Rick,
    installing worked perfekt on Arch Linux x86_64 Bild
    Now i want to create a new project, but what the hell is this Plugin!? Is it the program running on the RP6 while simulation?
    I downloadet "rp6simul-plugin", and as i understood i have to put the sourcecode of the program into the rp6-folder (I only want to simulate the Base, without M32).
    But what next? In this folder i compiled the sourcecode and got a .hex-file, but i can't select it as plugin-file...
    greetings
    schumi
    Ah, ok - now i know how to do it:
    1. Copy your sourcecode into the rp6-folder (for example RP6Base_Move_05.c)
    2. Rename it to "test.c"
    3. In a terminal navigate to this folder and run "cmake CMakeLists.txt"
    4. Now run "make all"
    5. Open the simulator, File - New Projecet, select name and directory, then at "Plugin" chose the "rp6simul-plugin"-folder -> rp6 -> libplugin.so
    6. Thada :-D when you click at the "map"-tab you can draw your map where RP6 drives
    Now i have another question:
    Is it possible to simulate the rp6 as fast as the pc can calculate? (like time lapse)
    ( https://www.roboternetz.de/community...Wand-zu-fahren Bild   )
    greetings
    schumi
    Niederlande
    Okay, glad you found it out by yourself Bild
    The manual (which you can access via the menu or online also provides a nice guide using the GUI of cmake.
    greetings
    schumi
    Actually, everything running outside any timer interrupts already runs at 'full speed'. Only the the timers run at 8 (or 16) MHz to provide realistic timing. If you would like to change the simulated AVR frequency you can take a look at the config.lua file in the src/lua/robot (and src/lua/m32) directories, but I don't expect that high values are really possible due the non-realtime operating systems we use Bild
    Erfahrener Benutzer Fleißiges Mitglied Avatar von basteluwe
    Is it of any use for the combination RP6-M256WiFi as well?
    Hi Rick,
    I'm wondering if your simulator can be used for the combination of RP6-Base and M256-WiFi extension module?
    If not so, do you plan for an upgrade?
    Regards Uwe
  1. Taster-Pressed,Held und Release
    Von Wsk8 im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 19.07.2009, 16:12
  2. neue Asuro Lib V2.70 (Release Candidate 3)
    Von m.a.r.v.i.n im Forum Asuro
    Antworten: 112
    Letzter Beitrag: 15.09.2008, 17:18
  3. Basic++ 2006 offizielles Release ist da....
    Von Dierk im Forum Controller- und Roboterboards von Conrad.de
    Letzter Beitrag: 20.04.2006, 13:44
  4. Neues WINAVR Release ...
    Von zackzack im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 22.01.2006, 10:27
  5. Neues WorkBench++ Release
    Letzter Beitrag: 28.10.2005, 17:52
