es sieht nicht so gut aus. Anbei meine aktuellen Testcodes, wo 240 Bytes hin und zurück geschickt und verglichen werden.
MEGA:
Raspi HW:Code:// Wire Slave Receiver // by Nicholas Zambetti <http://www.zambetti.com> // Demonstrates use of the Wire library // Receives data as an I2C/TWI slave device // Refer to the "Wire Master Writer" example for use with this // Created 29 March 2006 // This example code is in the public domain. #include <Wire.h> #define REGSIZE 240 byte rspeicher[REGSIZE]; byte wspeicher[REGSIZE]; byte puffer[32]; byte Register=1; byte rdblock=0; byte wrblock=0; byte pos=0; byte fertig=0; long dg=0; long timeout=0; void setup() { Wire.begin(4); // join I2C bus with address #8 Wire.onReceive(receiveEvent); // register event Wire.onRequest(requestEvent); // register event Serial.begin(57600); // start serial for output Serial.println(); Serial.println("Starte I2C-Test"); } void loop() { byte i=0; delay(100); timeout++; if (timeout==90){ timeout=0; Wire.begin(4); Serial.println("TimeOut!"); dg=0; } if (fertig !=0){ fertig=0; timeout=0; dg++; Serial.println(dg); for (i=0;i<REGSIZE;i++){ wspeicher[i]=rspeicher[i]; /* Serial.print(rspeicher[i]); Serial.print (" ");*/ } // Serial.println(); } } // function that executes whenever data is received from master // this function is registered as an event, see setup() void receiveEvent(int howMany) { byte x=0; if(howMany == 2){ rdblock = Wire.read(); if (rdblock<=240){ rspeicher[rdblock]=Wire.read(); } if (rdblock==REGSIZE-1){ fertig=1; } }else{ if (howMany == 1){ x=Wire.read(); if (x >=10 && x <=250){ wrblock=x-10; /* Serial.print("Lesebyte: "); Serial.println(wrblock);*/ } }else{ Serial.print ("Anzahl Daten: "); Serial.println(howMany); while (0 < Wire.available()) { //überflüssiges lesen x=Wire.read(); } } } } // function that executes whenever data is requested by master // this function is registered as an event, see setup() void requestEvent() { //Wire.write(speicher[Register],1); puffer[0]=wrblock; puffer[1]=wspeicher[puffer[0]]; Wire.write(puffer,2); /* Serial.print("Sendebyte: "); Serial.println(puffer[0]); /* Serial.print(", Wert: "); Serial.println(puffer[1]);*/ }
Raspi BitBang:Code:// GCC -Wall -pthread -o /var/scripte/i2cmaster01 /var/scripte/i2cmaster01.c -lpigpio -lrt // /var/scripte/i2cmaster01 //I2C mit pipgio //peterfido //V0.0.2 #include <signal.h> #include <stdio.h> #include <stdlib.h> #include <string.h> #include <unistd.h> #include <pigpio.h> #define ADDRESS 0x04 #define MSGSIZE 240 char empfdata[MSGSIZE]; // char senddata[MSGSIZE]; char commando[32]; int handle=0; int handles=-1; unsigned int laenge=0; volatile sig_atomic_t done = 0; void term(int signum) { done = 1; /* int res=0; int dl=0; if (handles >= 0){ for (dl=0;dl<handles;dl++){ res=i2cClose(dl); printf("%d geschlossen: %d\n",dl, res); } } gpioTerminate(); printf( "\nSIGINT wurde augeloest - Programm wird beendet\n" ); exit( 1 );*/ } void schreiben() { int res=0; // int i=0; int wrblock=0; int Fehler=0; for (wrblock=0;wrblock<MSGSIZE;wrblock++){ commando[0]=wrblock; commando[1]=senddata[wrblock]; res=i2cWriteDevice(handle,commando,2); if (res!=0){ printf("S I2C-Fehler: %d, Block: %d\n", res,wrblock); Fehler++; /* wrblock--; usleep(15000); if (Fehler==10){ break; }*/ break; } usleep(15000); } /* printf("Gesendet:\n"); for(i=0;i<MSGSIZE;i++){ printf("%d ",senddata[i]); } printf("\n"); */ } void lesen() { int res=0; // int i=0; int rdblock=0; int Fehler=0; for (rdblock=0;rdblock<MSGSIZE;rdblock++){ commando[0]=rdblock+10; res=i2cWriteDevice(handle,commando,1); if (res==0){ usleep(1000); res=i2cReadDevice(handle,commando,2); if (res==2){ // printf("Empfangene Daten: %d, Block: %d\n",res,rdblock); if (rdblock==commando[0]){ empfdata[rdblock]=commando[1]; } }else{ printf("E Fehler beim Blockeinlesen: %d, Block: %d\n", res,rdblock); Fehler++; rdblock--; usleep(15000); if (Fehler==10){ break; } break; } }else{ printf("E Fehler beim Leseblock schreiben %d, Block: %d\n", res,rdblock); break; } } /* printf("Empfangen:\n"); for(i=0;i<MSGSIZE;i++){ printf("%d ",empfdata[i]); } printf("\n"); */ } int vergleichen() { unsigned int i=0; int ret=0; for (i=0;i<MSGSIZE;i++){ if (empfdata[i]!=senddata[i]){ ret=-1; break; } } return ret; } int main(int argc, char **argv) { int res=0; int i=0; long dg=1; long maxdg=0; unsigned int Fehler=0; struct sigaction action; memset(&action, 0, sizeof(struct sigaction)); action.sa_handler = term; sigaction(SIGINT, &action, NULL); sigaction(SIGTERM, &action, NULL); if (gpioInitialise() < 0) { printf("Fehler beim Initialisieren von gpio!"); gpioTerminate(); }else{ handle=i2cOpen(1,ADDRESS,0); if(handle>=0){ handles ++; printf("\n\n\nStarte I2C-Test (%d)\n\n",handle); while (!done) { srand(time(NULL)); for(i=0;i<MSGSIZE;i++){ senddata[i]=rand() % 255; } schreiben(); usleep(100000); lesen(); usleep(100000); if (vergleichen()==0){ printf("Daten OK %ld (%ld)\n",dg,maxdg); Fehler=0; dg++; }else{ printf("***************************** Daten fehlerhaft %ld *****************************\n",dg); Fehler++; dg=0; if (dg>maxdg){ maxdg=dg; } sleep(1); if (Fehler==100){ break; } } } }else{ printf("E Fehler beim Oeffnen: %d\n", handle); } } res=i2cClose(handle); if (res!=0){ printf("E Fehler beim Schliessen: %d\n", res); }else{ handles--; printf("E Schliessen OK %d\n",handle); } gpioTerminate(); return 0; }
Mein Fazit:Code:// GCC -Wall -pthread -o /var/scripte/bbi2cmaster /var/scripte/bbi2cmaster.c -lpigpio -lrt // /var/scripte/bbi2cmaster //I2C mit pipgio //peterfido //V0.0.2 #include <signal.h> #include <stdio.h> #include <stdlib.h> #include <string.h> #include <unistd.h> #include <pigpio.h> #define SDA 2 #define SCL 3 #define TAKT 100000 #define PAUSEN 5000 #define ADDRESS 0x04 #define MSGSIZE 240 char empfdata[MSGSIZE]; // char senddata[MSGSIZE]; char commando[64]; char puffer[12]; unsigned int laenge=0; volatile sig_atomic_t done = 0; void term(int signum) { done = 1; } int I2CResetBus(void) { char i; int res=0; if(gpioRead(SDA) && gpioRead(SCL)) { return 0; } gpioSetMode(SCL, PI_INPUT); gpioSetMode(SDA, PI_INPUT); gpioSetPullUpDown(SDA, PI_PUD_UP); // Sets SDA pull-up. gpioSetPullUpDown(SCL, PI_PUD_UP); // Sets SDA pull-up. usleep(50); if(!gpioRead(SCL)) { return -1; /* SCL wird extern auf Low gehalten, nix zu machen */ } for(i = 0; i<9; i++) { gpioSetMode(SCL, PI_OUTPUT); gpioWrite(SCL, 0); usleep(50); gpioSetMode(SCL, PI_INPUT); gpioSetPullUpDown(SCL, PI_PUD_UP); // Sets SDA pull-up. usleep(50); if(gpioRead(SDA)) { break; /* SDA ist high STOP */ } } /* for */ if(!gpioRead(SDA)) { return -1; } commando[0]= 3; //stop commando[1]= 0; // Fertig res=bbI2CZip(SDA,commando,2,NULL,0); if (res!=0){ printf("Fehler beim Reset!\n"); } if(gpioRead(SDA) && gpioRead(SCL)){ return 0; }else{ return -1; } } void schreiben() { int res=0; // int i=0; int wrblock=0; int Fehler=0; for (wrblock=0;wrblock<MSGSIZE;wrblock++){ commando[0]= 4; //'Adresse setzen ankündigen commando[1]= ADDRESS; //'Adresse übergeben commando[2]= 2; //start commando[3]= 7; //'Bytes senden commando[4]= 2; //'Anzahl commando[5]= wrblock; //Block commando[6]= senddata[wrblock]; //Wert commando[7]= 3; //stop commando[8]= 0; //keine weiteren Parameter res=I2CResetBus(); res=bbI2CZip(SDA,commando,9,NULL,0); res=I2CResetBus(); if (res!=0){ printf("S I2C-Fehler: %d, Block: %d\n", res,wrblock); Fehler++; wrblock--; usleep(PAUSEN*3); if (Fehler==10){ break; } } usleep(PAUSEN); } /* printf("Gesendet:\n"); for(i=0;i<MSGSIZE;i++){ printf("%d ",senddata[i]); } printf("\n"); */ } void lesen() { int res=0; // int i=0; int rdblock=0; int Fehler=0; for (rdblock=0;rdblock<MSGSIZE;rdblock++){ commando[0]= 4; //'Adresse setzen ankündigen commando[1]= 4; //'Adresse übergeben commando[2]= 2; //start commando[3]= 7; //'Bytes senden commando[4]= 1; //'Anzahl commando[5]= rdblock+10; //Byte commando[6]= 2; //start commando[7]= 6; //Bytes lesen commando[8]= 2; //Anzahl commando[9]= 3; //stop commando[10]= 0; //keine weiteren Parameter res=I2CResetBus(); res=bbI2CZip(SDA,commando,11,puffer,12); res=I2CResetBus(); if (res==0){ if (puffer[0]==rdblock){ empfdata[rdblock]=puffer[1]; Fehler=0; }else{ printf("E Falsche Blocknummer. Erwartet: %d, bekommen: %d, Wert: %d\n",rdblock,puffer[0],puffer[1]); Fehler++; rdblock--; if (Fehler==10){ break; } } }else{ printf("E Fehler beim Blockeinlesen. Block: %d\n",rdblock); Fehler++; rdblock--; if (Fehler==10){ break; } } usleep(PAUSEN); } printf("Empfangen:\n"); /* for(i=0;i<MSGSIZE;i++){ printf("%d ",empfdata[i]); } printf("\n"); */ } int vergleichen() { unsigned int i=0; int ret=0; for (i=0;i<MSGSIZE;i++){ if (empfdata[i]!=senddata[i]){ ret=-1; break; } } return ret; } int main(int argc, char **argv) { int res=0; int i=0; long dg=1; long maxdg=0; unsigned int Fehler=0; struct sigaction action; memset(&action, 0, sizeof(struct sigaction)); action.sa_handler = term; sigaction(SIGINT, &action, NULL); sigaction(SIGTERM, &action, NULL); if (gpioInitialise() < 0) { printf("Fehler beim Initialisieren von gpio!"); gpioTerminate(); }else{ res=bbI2COpen(SDA,SCL,TAKT); res=res+gpioSetMode(SDA, PI_INPUT); // Set SDA as input. res=res+gpioSetMode(SCL, PI_INPUT); // Set SDA as input. res=res+gpioSetPullUpDown(SDA, PI_PUD_UP); // Sets SDA pull-up. res=res+gpioSetPullUpDown(SCL, PI_PUD_UP); // Sets SDA pull-up. if(res==0){ printf("\n\n\nStarte I2C-Test\n\n"); while (!done) { srand(time(NULL)); for(i=0;i<MSGSIZE;i++){ senddata[i]=rand() % 255; } schreiben(); usleep(5000); lesen(); usleep(5000); if (vergleichen()==0){ printf("Daten OK %ld (%ld)\n",dg,maxdg); Fehler=0; dg++; }else{ printf("***************************** Daten fehlerhaft %ld *****************************\n",dg); Fehler++; dg=0; if (dg>maxdg){ maxdg=dg; } sleep(1); if (Fehler==100){ break; } } } }else{ printf("E Fehler beim Oeffnen\n"); } } res=bbI2CClose(SDA); if (res!=0){ printf("E Fehler beim Schliessen: %d\n", res); }else{ printf("E Schliessen OK\n"); } gpioTerminate(); return 0; }
Ich bleibe bei UART.
Zitieren
