Ergebnis 1 bis 10 von 11
Thema: Lernen aus Erfahrung?
Baum-Darstellung
  1. #10
    HaWe
    Backpropagation Netz / net
    optimiert für Arduino Due
    Version JON 0060
    (C) HaWe 2015
    to do:
    - save memory to SD file
    - plug real physical sensors
    - pre-emptive Multitasking (currently not possible for Due)
    #include <SPI.h>
    #include <SD.h>
    #include <UTFT.h>
    #include <ardustdio.h>
    #include <malloc.h>
    #include <DueTimer.h>
    // neural net size
    #define  NMAXIN    108       // max number of inputs (sensors)
    #define  NMAXHID    20       // max number hidden layer neurons
    #define  NMAXOUT    20       // max number output layer neurons
    #define  NMAXPAT    70       // <<< max number of possibly trained patterns;
    // neural net: neurons and patterns
    float    WeightLIn[NMAXIN+1][NMAXHID+1];
    float    WeightLOut[NMAXHID+1][NMAXOUT+1];
    float    Input[NMAXPAT+1][NMAXIN+1];
    float    Target[NMAXPAT+1][NMAXOUT+1];
    float    Output[NMAXPAT+1][NMAXOUT+1];
    //float    Contxt[NMAXOUT+1];    // Jordan-net: neuron-number == output-number
    float    currIn[NMAXIN+1],     // currently polled inputs
             inbuf[NMAXIN+1];      // intermediate stored inputs for editing
    float    currOut[NMAXOUT+1],   // currently computed net outputs
             outbuf[NMAXOUT+1];    // intermediate stored outputs
    int16_t  NumInput = NMAXIN, NumHidden = NMAXHID, NumOutput = NMAXOUT;
    int16_t  NumPattern = 0;       // <<< number of actually trained patterns;
    int32_t  epoch;                // training measures
    uint32_t BPTime;
    float    Error;
    // TFT LCD
    //UTFT   myGLCD(Model, SDA=MISO, SCL, CS, RESET, RS)
    //UTFT   myGLCD(QD220A,   A2,    A1,  A5,  A4,   A3);   // adjust model parameter and pins !
      UTFT   myGLCD(QD220A,   50,    49,  52,   0,   51);   // A0->Vc (LED), A4->BoardReset
    extern   uint8_t SmallFont[];
    #define  LCDWhiteBlack()  {myGLCD.setColor(255, 255, 255); myGLCD.setBackColor(  0,   0,   0);}
    #define  LCDNormal()      {myGLCD.setColor(255, 255, 255); myGLCD.setBackColor(  0,   0,   0);}
    #define  LCDInvers()      {myGLCD.setColor(  0,   0,   0); myGLCD.setBackColor(255, 255, 255);}
    #define  LCDWhiteRed()    {myGLCD.setColor(255, 255, 255); myGLCD.setBackColor(255,   0,   0);}
    #define  LCDRedBlack()    {myGLCD.setColor(255,   0,   0); myGLCD.setBackColor(  0,   0,   0);}
    #define  LCDYellowBlue()  {myGLCD.setColor(255, 255,   0); myGLCD.setBackColor( 64,  64,  64);}
    uint8_t  fontwi= 8;
    uint8_t  fonthi=10;
    int16_t  LCDmaxX , LCDmaxY ;                // display size
    int16_t  _curx_, _cury_,                    // last x,y cursor pos on TFT screen
             _maxx_, _maxy_;                    // max. x,y cursor pos on TFT screen
    char     wspace[50];                        // line of white space
    void lcdcls()  { myGLCD.clrScr();  _curx_ =0;  _cury_ =0; }
    void curlf()   { _curx_=0; if( _cury_ <=(LCDmaxY-10) ) _cury_+=10; else _cury_=0; }
    void lcdprintxy(int16_t x, int16_t y, char * str) {
       myGLCD.print(str, x, y);
       _curx_ = x + strlen(str)*fontwi;
       _cury_ = y;  // check for line overflow!
    void curxy(int16_t x, int16_t y) {_curx_ = x;_cury_ = y;}
    void lcdprint(char * str) {
       myGLCD.print(str, _curx_, _cury_);
       _curx_ = _curx_ + strlen(str)*fontwi;
       //_cury_ = _cury_;  // check for line overflow!
    // SD Card
    #define  SD_CSpin  53
    File     myFile;
    char     fname[64];
    // misc
    #define  TimerMS()    millis()
    #define  LRAND_MAX    32767
    #define  srand(seed)  randomSeed(seed)
    #define  rand()       random(LRAND_MAX)
    #define  rando()      ((float)rand()/(LRAND_MAX+1))
    int32_t  RSeed;
    #define  pswitchon(pin)   (!digitalRead(pin))    // btn press for pinMode(pin, INPUT_PULLUP)
    #define  pswitchoff(pin)  ( digitalRead(pin))    // btn press for pinMode(pin, INPUT_PULLUP)
    #define  pbtn(pin)        (!digitalRead(pin))    // alias
    // user interface:  button pad control pins
    #define  PIN_ESC    13
    #define  PIN_UP     12
    #define  PIN_OK     11
    #define  PIN_DN      4 // instead opt.: 6
    #define  PIN_LE      3 // instead opt.: 5
    #define  PIN_RI      2
    // pins 10,9,8,7 : motor
    // pins 22 - 37 :  motor
    // pins 49 - 51 :  LCD TFT
    // pin  53:        SD CS
    // available: 5+6, 38-48 for digital touch pins
    int16_t  btnpressed() {
       return ( pbtn(PIN_ESC)||pbtn(PIN_UP)||pbtn(PIN_OK)||pbtn(PIN_DN)||pbtn(PIN_LE)||pbtn(PIN_RI) );
    int16_t   getbtn() {
       int16_t  choice= -1;
       while (!  btnpressed() );  // wait until button pad pressed
       if( pbtn(PIN_ESC) ) choice = PIN_ESC;
       if( pbtn(PIN_UP) )  choice = PIN_UP;
       if( pbtn(PIN_OK) )  choice = PIN_OK;
       if( pbtn(PIN_DN) )  choice = PIN_DN;
       if( pbtn(PIN_LE) )  choice = PIN_LE;
       if( pbtn(PIN_RI) )  choice = PIN_RI;
       while (  btnpressed() );   // wait until button pad released
       return choice;
    // misc. tools
    int16_t  toggleup(int16_t lo, int16_t hi, int16_t val ) {
      if ( val < hi )  val++;
      else val = lo;
      return val;
    int16_t  toggledn(int16_t lo, int16_t hi, int16_t val ) {
      if ( val > lo )  val--;
      else val = hi;
      return val;
    // motor control
    #define MAXMOTORS   4  // max number of encoder motors at Arduino Uno=2 // Due=6 // Mega=8
    // motor 0
    #define pinenc0A   22  // enc0A yellow
    #define pinenc0B   23  // enc0B blue
    #define pinmot0d1  24  // dir0-1   <<
    #define pinmot0d2  25  // dir0-2
    #define pinmot0pwm 10  // pwm enable0
    // motor 1
    #define pinenc1A   26  // enc1A yellow
    #define pinenc1B   27  // enc1B blue
    #define pinmot1d1  28  // dir1-1   <<
    #define pinmot1d2  29  // dir1-2
    #define pinmot1pwm  9  // pwm enable1
    // motor 2
    #define pinenc2A   30  // enc2A yellow
    #define pinenc2B   31  // enc2B blue
    #define pinmot2d1  32  // dir2-1   <<
    #define pinmot2d2  33  // dir2-2
    #define pinmot2pwm  8  // pwm enable2
    // motor 3
    #define pinenc3A   34  // enc3A yellow
    #define pinenc3B   35  // enc3B blue
    #define pinmot3d1  36  // dir3-1   <<
    #define pinmot3d2  37  // dir3-2
    #define pinmot3pwm  7  // pwm enable3
    // motor bit patterns
    const char COAST[]={0,0,0};
    const char BREAK[]={0,0,1};
    const char FWSLOW[]={0,1,0};
    const char RVSLOW[]={0,1,1};
    const char FWMED[]={1,0,0};
    const char RVMED[]={1,0,1};
    const char FWFAST[]={1,1,0};
    const char RVFAST[]={1,1,1};
    #define    fwslow   20
    #define    rvslow  -20
    #define    fwmed    60
    #define    rvslow  -60
    #define    fwfast  100
    #define    rvfast -100
    // SETUP ()
    void setup() {
       char     sbuf[128];  // output string
       Serial.begin(115200);
       pinMode(PIN_ESC,INPUT_PULLUP);
       pinMode(PIN_UP, INPUT_PULLUP);
       pinMode(PIN_OK, INPUT_PULLUP);
       pinMode(PIN_DN, INPUT_PULLUP);
       pinMode(PIN_LE, INPUT_PULLUP);
       pinMode(PIN_RI, INPUT_PULLUP);
       myGLCD.InitLCD();
       LCDmaxX=myGLCD.getDisplayXSize();
       LCDmaxY=myGLCD.getDisplayYSize();
       myGLCD.setFont(SmallFont);
       _maxx_ = LCDmaxX / fontwi;
       _maxy_ = LCDmaxX / fonthi;
       memset(wspace, ' ', _maxx_);
       wspace[_maxx_]='\0';
       lcdcls();
       sprintf(sbuf, "Serial ok, GLCD=%dx%d",LCDmaxX,LCDmaxY);
       Serial.println(sbuf);
       myGLCD.print  (sbuf, 0, 0);
       ResetNet();
       RSeed = ( ((analogRead(A8)+1017)%100) * (TimerMS()% LRAND_MAX ) % LRAND_MAX );
       srand(RSeed);
       // # DEBUG
       sprintf(sbuf, "Seed= %ld", RSeed);
       myGLCD.print  (sbuf, 0,10);
       sprintf(sbuf, "Rand= %ld", rand() );
       myGLCD.print  (sbuf, 100,10);
       // # DEBUG
       memtest(20, "memtest: setup");
       SetNetDefaultPatterns();
       RefreshInputs();             // polls inputs and stores values to currIn[] array
          // debug: test different input sets
           currIn[1]=1; //currIn[2]=0; currIn[3]=1; //currIn[4]=0; currIn[5]=0; currIn[6]=0; currIn[7]=0;
        ComputeMatrix();         // applies inputs to net and computes outputs to currOut[] array
        TrainNet();              // basic training
    // analog range bit patterns
    // returns 6 bits for ranges -32768...0...32767 or out of bounds (VOID==[32])
    float Ana[64][8]={
         {0,0,0,0,0,0,0,0},  // 0
         {0,1,0,0,0,0,0,1},  // 0...1
         {1,2,0,0,0,0,1,0},  // 1...2
         {2,3,0,0,0,0,1,1},
         {3,4,0,0,0,1,0,0},
         {4,5,0,0,0,1,0,1},
         {5,6,0,0,0,1,1,0},
         {6,8,0,0,0,1,1,1},
         {8,10,0,0,1,0,0,0},
         {10,13,0,0,1,0,0,1},
         {13,16,0,0,1,0,1,0},
         {16,20,0,0,1,0,1,1},
         {20,26,0,0,1,1,0,0},
         {26,32,0,0,1,1,0,1},
         {32,40,0,0,1,1,1,0},
         {40,48,0,0,1,1,1,1},
         {48,56,0,1,0,0,0,0},
         {56,64,0,1,0,0,0,1},
         {64,74,0,1,0,0,1,0},
         {74,85,0,1,0,0,1,1},
         {85,97,0,1,0,1,0,0},
         {97,110,0,1,0,1,0,1},
         {110,128,0,1,0,1,1,0},
         {128,192,0,1,0,1,1,1},
         {192,256,0,1,1,0,0,0},
         {256,420,0,1,1,0,0,1},
         {420,512,0,1,1,0,1,0},
         {512,650,0,1,1,0,1,1},
         {650,800,0,1,1,1,0,0},
         {800,1024,0,1,1,1,0,1},
         {1024,2048,0,1,1,1,1,0},
         {2048,32767,0,1,1,1,1,1},   // <= SHORTMAX
         {0,0,1,0,0,0,0,0},     // #32: VOID !
         {0,-1,1,0,0,0,0,1},    // 0... -1
         {-1,-2,1,0,0,0,1,0},   // -1...-2
         {-2,-3,1,0,0,0,1,1},
         {-3,-4,1,0,0,1,0,0},
         {-4,-5,1,0,0,1,0,1},
         {-5,-6,1,0,0,1,1,0},
         {-6,-8,1,0,0,1,1,1},
         {-8,-10,1,0,1,0,0,0},
         {-10,-13,1,0,1,0,0,1},
         {-13,-16,1,0,1,0,1,0},
         {-16,-20,1,0,1,0,1,1},
         {-20,-26,1,0,1,1,0,0},
         {-26,-32,1,0,1,1,0,1},
         {-32,-40,1,0,1,1,1,0},
         {-40,-48,1,0,1,1,1,1},
         {-48,-56,1,1,0,0,0,0},
         {-56,-64,1,1,0,0,0,1},
         {-64,-74,1,1,0,0,1,0},
         {-74,-85,1,1,0,0,1,1},
         {-85,-97,1,1,0,1,0,0},
         {-97,-110,1,1,0,1,0,1},
         {-110,-128,1,1,0,1,1,0},
         {-128,-192,1,1,0,1,1,1},
         {-192,-256,1,1,1,0,0,0},
         {-256,-420,1,1,1,0,0,1},
         {-420,-512,1,1,1,0,1,0},
         {-512,-650,1,1,1,0,1,1},
         {-650,-800,1,1,1,1,0,0},
         {-800,-1024,1,1,1,1,0,1},
         {-1024,-2048,1,1,1,1,1,0},
         {-2048,-32768,1,1,1,1,1,1}    // >= -SHORTMAX
    int16_t  ana2bits(int16_t  aval) {         // return array index
       int16_t   i,j;
       if(aval == 0) return 0;
       else
       if( aval > 32767 ) return 32;   // VOID
       else
       if( aval < -32768 ) return 32;  // VOID
       else {
         for (i=1; i<32; ++i) {
            if ( (aval>Ana[0][i]) && (aval<=Ana[1][i]) ) return i;
         for (i=32; i<64; ++i) {
            if ( (aval<Ana[0][i]) && (aval>=Ana[1][i]) ) return i;
       return 32;
    // mem test
    extern  char _end;
    extern  "C" char *sbrk(int i);
    char    *ramstart=(char *)0x20070000;
    char    *ramend=(char *)0x20088000;
    void memtest(int ypos, char * str) {
       char *heapend=sbrk(0);
       register char * stack_ptr asm ("sp");
       struct mallinfo mi=mallinfo();
       sprintf(sbuf,str);
       Serial.println(); Serial.println(sbuf); myGLCD.print(sbuf, 0, ypos);
       sprintf(sbuf, "Dyn.RAM used: %-10ld ", mi.uordblks);
       Serial.println(sbuf); myGLCD.print(sbuf, 0, ypos+10);
       sprintf(sbuf, "Prg.stat.RAM used %-10ld ", & _end - ramstart);
       Serial.println(sbuf); myGLCD.print(sbuf, 0, ypos+20);
       sprintf(sbuf, "Stack RAM used %-10ld ", ramend - stack_ptr);
       Serial.println(sbuf); myGLCD.print(sbuf, 0, ypos+30);
       sprintf(sbuf, "Free mem: %-10ld ", stack_ptr - heapend + mi.fordblks);
       Serial.println(sbuf); myGLCD.print(sbuf, 0, ypos+40);
       myGLCD.print(wspace, 0, ypos+50);
    // net: clear, set, reset, patch
    void clrnetbuf() {
      memset(inbuf,  0, sizeof(inbuf) );
      memset(currIn, 0, sizeof(currIn) );
      memset(outbuf, 0, sizeof(outbuf) );
      memset(currOut, 0, sizeof(outbuf) );
    void ResetNet(){
       memset(Input, 0, sizeof(Input) );
       memset(Target, 0, sizeof(Target) );
       //memset(Contxt, 0, sizeof(Contxt) );
       clrnetbuf();
       NumPattern=0;
    // set input/target patterns manually
    int16_t   setIOpattern(int16_t  patt) {
       int16_t  result;
       if(patt==-1) patt = CheckTestPattern(inbuf);        // pattern number if known, if not: -1
       if( patt > 0 ) sprintf(sbuf, "  PATCH target #%-3d", patt);
       else  sprintf(sbuf, "  NEW  target #%-3d", NumPattern+1);
       result=menu_setouttargets(sbuf);
       if (result == -1) return (result);     // break by escape btn
       if (patt == -1) {                      // unknown => add new pattern!
          SetNewPattern( inbuf,  outbuf );
          result=NumPattern;
       else {                                 // override old pattern
          PatchPattern( patt,  inbuf,  outbuf);
          result=patt;
       return result;                        // return written pattern number
    // display net inputs and target outputs
    void DisplayNetTrainingIOs(int16_t code) {
        int16_t   i, o, p;
        char msg[20]="! SUCCESS !"  ;
        if (code==0) strcpy(msg,"calc.error");
        if (code==2) strcpy(msg,"user-break");
        /* print network outputs */
        Serial.println(); Serial.println();
        Serial.println(msg);
        sprintf(sbuf, "%-6ld:  Err= %9.7f", epoch, Error) ;
        Serial.print("Epoch "); Serial.println(sbuf);
        myGLCD.print(sbuf, 0, 20);
        myGLCD.print(msg, 0, 30);
        sprintf(sbuf, "NET TRAINING TIME = %ld sec \n", BPTime/1000);   Serial.println(sbuf);
        Serial.println();
        sprintf(sbuf, "Patt. ") ; Serial.print(sbuf); myGLCD.print(sbuf, 0, 40);
        for( i = 1 ; i <= NumInput ; i++ ) {
            sprintf(sbuf, "Inp%-3d ", i) ;  Serial.print(sbuf);
        for( o = 1 ; o <= NumOutput ; o++ ) {
            sprintf(sbuf, "Targ%-3d Outp%-3d ", o, o); Serial.print(sbuf);
        for(int p = 1 ; p <= NumPattern ; p++ ) {
           Serial.println();
           sprintf(sbuf, "%3d  ", p) ;  Serial.print(sbuf); myGLCD.print(sbuf, 40, 40);
                sprintf(sbuf, "%5.2f  ", Input[p][i]) ; Serial.print(sbuf);
                sprintf(sbuf, "%5.2f   %5.2f   ", Target[p][o], Output[p][o]) ;  Serial.print(sbuf);
        sprintf(sbuf, "BPtrained, returning to main()...!") ;  Serial.print(sbuf);
    void displayMatrix(int16_t patt) {
       int32_t  btn=-1;
       int16_t  i, l, o, ibuf, p, lval=1, hval=NumPattern;
       float    fbuf;
       char     msgline[30], sbuf[30];
       char     valline[30];
       p=patt;
       if(p==0) p=1;
       if(p>NumPattern) p=NumPattern;
       do {
          strcpy(msgline,"     12345678901234567890");
          sprintf(sbuf, "%-4d", p);
          strinsert(msgline, sbuf, 0);
          LCDWhiteRed();
          Serial.println(msgline); lcdprintxy(0,0,msgline); curlf();
          LCDNormal();
          for (i=1; i<=NMAXIN; ++i) {
                l=(i-1)/20;
                if (i%20==1) {
                   sprintf(sbuf, "%4d ", i-1);
                   Serial.print(sbuf);  lcdprint(sbuf);
                ibuf = round(Input[p][i]);
                sprintf(sbuf, "%1d", ibuf);
                if (i%20==0) {
                   Serial.println();
                   curlf();
          Serial.println();  curlf();
          strcpy(msgline,"TARG 12345678901234567890");
          LCDRedBlack();
          Serial.println(msgline); lcdprint(msgline); curlf();
          LCDNormal();
          for (i=1; i<=NMAXOUT; ++i) {
                l=(i-1)/20;
                if (i%20==1) {
                ibuf = round(Target[p][i]);
                if (i%20==0) {
                   Serial.println();
                   curlf();
          Serial.println();
          LCDYellowBlue();
          sprintf(msgline, "toggle patt +-1: LEFT/RIGHT");
          Serial.println(msgline);  lcdprintxy(0, LCDmaxY-20, msgline);
          sprintf(msgline, "+-10:UP/DN edit:OK quit:ESC");
          Serial.println(msgline);  lcdprintxy(0, LCDmaxY-10, msgline);
          LCDNormal();
          btn=getbtn();
          if ( (btn==PIN_RI) || (btn==PIN_LE) ) {             // browse displayed pattern
            if (btn==PIN_RI) p=toggleup(lval, hval, p);
              if (btn==PIN_LE) p=toggledn(lval, hval, p);
          if ( (btn==PIN_UP) || (btn==PIN_DN) ) {             // browse displayed pattern
            if (btn==PIN_UP) p=toggleup(lval, hval, p+9);
              if (btn==PIN_DN) p=toggledn(lval, hval, p-9);
          if ( (btn==PIN_OK) ) {                              // change displayed pattern
            setIOpattern(p);
       } while ( (btn!=PIN_ESC ) );
    int16_t RefreshInputs() {        // polls inputs and stores values to currIn[] array
       // poll digital touch values and store directly (1 Dpin = 1 input)                16 DPins  == 16
       // poll analog sensor values and store bit pattern for ranges (1 Apin = 6 inputs)  8 A10bit == 48
       // poll motor speed and store bit pattern for speed ranges (1 Apin = 6 inputs)     4 motors == 24
       // Jordan/Elman neural context neurons == feedback inputs (1...NMAXCON)           20 inputs == 20
       //        =108
       int16_t   i, cx;
       cx = NMAXIN - NMAXOUT +1;   // last NMAXCON inputs reserved for context neurons
       //for(i=cx; i<= NMAXIN; ++i) { currIn[i] = Contxt[i] ; }   //
    void  ComputeMatrix() {         // applies currIn[] inputs to net and computes outputs (outbuf[])
        int16_t  i, j, o;
        float    SumH[NMAXHID+1];
        float    SumO[NMAXOUT+1];
        float    HidOut[NMAXHID+1];
        float    SumDOW[NMAXHID+1];
        float    lambda= 0.5;      // context neuron self activation rate
        memset(SumH, 0, sizeof(SumH) );
        memset(SumO, 0, sizeof(SumO) );
        memset(HidOut, 0, sizeof(HidOut) );
        memset(SumDOW, 0, sizeof(SumDOW) );
        for( j = 1 ; j <= NumHidden ; j++ ) {                  // compute hidden unit activations
              SumH[j] = WeightLIn[0][j] ;                      // bias neuron
                  SumH[j] += currIn[i] * WeightLIn[i][j] ;
              HidOut[j] = 1.0/(1.0 + exp(-SumH[j])) ;          // Sigmoidal Outputs
        for( o = 1 ; o <= NumOutput ; o++ ) {                  // compute output unit activations and errors
              SumO[o] = WeightLOut[0][o] ;                     // bias neuron
                  SumO[o] += HidOut[j] * WeightLOut[j][o] ;
              currOut[o] = 1.0/(1.0 + exp(-SumO[o])) ;           // Sigmoidal Outputs
        //for( o = 1 ; o <= NumOutput ; o++ ) {                   // compute context neurons
        //      Contxt[o] = lambda*Contxt[o] + (1-lambda)*currOut[o];  // assign outputs*weight to context neurons
    // check for known patterns
    int16_t  CheckTestPattern(float * test) {
       int16_t  i, p;
       for( p = 1; p <= NumPattern ; ++p) {
          for( i = 1; (i <= NumInput) && ( Input[p][i] == test[i] ); ++i);
          if (i > NumInput) {return p; }
       return -1;
    // patch old pattern
    void PatchPattern(int16_t  patt,  float * _ibuf,  float * _obuf ){
       int16_t i, o;
       if ( (NumPattern <= NMAXPAT) && ( NumPattern > 0) ) {
          // # DEBUG
          //Serial.print("NumPattern="); Serial.print(NumPattern);  Serial.print("  SetNetPattern="); Serial.println(patt);
          for(i=1; i<=NMAXIN;  ++i) { Input[patt][i]  = _ibuf[i]; }
          for(o=1; o<=NMAXOUT; ++o) { Target[patt][o] = _obuf[o]; }
    // add new pattern
    void SetNewPattern(float * _ibuf,  float * _obuf ){
      int16_t i, o;
      if ( (NumPattern < NMAXPAT) && ( NumPattern >= 0) ) {
          NumPattern++;
          // # DEBUG
          for(i=1; i<=NMAXIN;  ++i) { Input[NumPattern][i]  = _ibuf[i]; }
          for(o=1; o<=NMAXOUT; ++o) { Target[NumPattern][o] = _obuf[o]; }
    // Teil 2 folgt, leider Wartezeit
    Geändert von HaWe (08.09.2018 um 16:33 Uhr)
  1. RP6 Programmieren lernen?
    Von xMichiiix im Forum Robby RP6
    Letzter Beitrag: 20.03.2014, 23:19
  2. Programieren lernen C++ oder eher Arduino eigene Sprache lernen?
    Von PsychoElvis64 im Forum Arduino -Plattform
    Letzter Beitrag: 17.12.2013, 09:34
  3. Assembler lernen
    Von Attiny im Forum Assembler-Programmierung
    Antworten: 52
    Letzter Beitrag: 09.10.2008, 06:35
  4. Roboterbau lernen
    Von grind im Forum Elektronik
    Antworten: 7
    Letzter Beitrag: 08.09.2005, 17:46
  5. bascom lernen
    Von roooy im Forum Basic-Programmierung (Bascom-Compiler)
    Antworten: 22
    Letzter Beitrag: 06.11.2004, 11:33
