tut mir leid ich habs ned verstanden, kanste des ned für ein AT90s2313
modifizieren?
hab dir hier mal mein multiplex code:Schon mal danke für dein bemühen!!Code:$regfile = "2313def.dat" $crystal = 10000000 Config Portb = Output Config Portd = Output Dim A As Byte Dim S As String * 5 Dim X As Byte Dim Pos As Byte Dim Z As String * 1 Dim L As Byte Dim W As Word Do S = Str(w) L = Len(s) For A = 0 To 10 For X = 1 To L S = Str(w) Pos = L - X Pos = Pos + 1 Z = Mid(s , Pos , 1) If Z = "0" Then Portb = 63 If Z = "1" Then Portb = 34 If Z = "2" Then Portb = 94 If Z = "3" Then Portb = 118 If Z = "4" Then Portb = 99 If Z = "5" Then Portb = 117 If Z = "6" Then Portb = 125 If Z = "7" Then Portb = 38 If Z = "8" Then Portb = 127 If Z = "9" Then Portb = 119 If X = 1 Then Portd = 1 If X = 2 Then Portd = 2 If X = 3 Then Portd = 4 If X = 4 Then Portd = 8 If X = 5 Then Portd = 16 If L = 1 Then Waitus 9996 If L = 2 Then Waitus 4996 If L = 3 Then Waitus 3327 If L = 4 Then Waitus 2496 If L = 5 Then Waitus 1996 Next X Next A W = W + 1 Loop
Grüßle
Zitieren
