Sooo nun bin ich wieder erwacht :-P
Hier mal mein aktueller Quellcode. Ich mache mit großer Sicherheit irgendwas ganz gravierendes falsch...
Code:#define F_CPU 16000000 #define RC5_HALF_BIT_TIME 8 // 8 * 111µs = 888µs #define RC5_SEND_ON PORTD |= (1<<PD1) #define RC5_SEND_OFF PORTD &= ~(1<<PD1) #include <avr/io.h> #include <avr/interrupt.h> #include <util/delay.h> #include <stdbool.h> void rc5_send_command(uint16_t command); void rc5_send_one(void); void rc5_send_zero(void); void delay_880(void); volatile static uint8_t modulation, rc5_half_bit_cnt, rc5_state; uint16_t rc5_byte = 0x00; int main(void) { DDRB |= (1<<PB7); DDRD |= (1<<PD1); TCCR0A = (1<<WGM01); // CTC TCCR0B = (1<<CS01); // 8 ( ca. 111µs @ 8 MHz ) TCCR1B = (1<<CS10); // 1 ( ca. 36 kHz @ 8 MHz ) TCCR1B |= (1<<WGM12); // CTC TIMSK0 = (1<<OCIE0A); // OutputCompare0A TIMSK1 = (1<<OCIE1A); // OutputCompare1A OCR0A = (0x6E); OCR1A = (0x00DD); sei(); while(1) { rc5_send_command(0b11000000001100); } } /* send a 14 bit command to the IR - Receiver */ void rc5_send_command(uint16_t command) { uint16_t send_byte = command; for (uint16_t x = 0 ; x < 14 ; x++) { if (send_byte & 0x8000) { rc5_send_one(); } else { rc5_send_zero(); } send_byte <<= 0x0001; } } /* send a logical one to the Receiver ( 1 --> 0 ) */ void rc5_send_one(void) { rc5_state &= ~(0x40); delay_880(); rc5_state |= (0x40); delay_880(); } /* send a logical zero to the Receiver ( 0 --> 1 ) */ void rc5_send_zero(void) { rc5_state |= (0x40); // led on delay_880(); rc5_state &= ~(0x40); // led off delay_880(); } void delay_880(void) { while(1) { if ((rc5_state & 0x01) == 0x01) { rc5_half_bit_cnt = 0x00; rc5_state = 0x00; break; } } } /* called every 111 µs */ ISR(TIMER0_COMPA_vect) { rc5_half_bit_cnt++; if (rc5_half_bit_cnt >= RC5_HALF_BIT_TIME) { rc5_half_bit_cnt = 0x00; rc5_state |= 0x01; } } /* called every 0,0278 ms */ ISR(TIMER1_COMPA_vect) { if ((rc5_state & 0x40) == 0x40) { RC5_SEND_ON; } else { RC5_SEND_OFF; } }
Zitieren
