Ergebnis 1 bis 7 von 7
Thema: RTC per Arduino einstellen
    Oderberg
    Diese Lib ist für den RTC Baustein mit DS1307, also Zeit, Datum, Tag lesen oder setzen...
    Aachen
    Hast du ne Projektseite zu der Lib? Und n Anwendungsbeispiel?
    Und ist sie auch mit DS3231 kompatibel?
    Erfahrener Benutzer Roboter-Spezialist Avatar von schorsch_76
    Kurz vor Neuschwanstein
    Hier hab ich meine RTC Funktionen bzw die Statemachine.
    // RTC
    #include "rtc.h"
    #include "util.h"
    #include "project.h"
    #include "i2c.h"
    extern avr::project sys;
    extern avr::i2c twi;
    extern bool check_twi(unsigned char& state);
    namespace rtc {
    unsigned char state = 0;
    avr::util::timeout rtc_timeout;
    bool
    handle()
        using namespace avr::util;
        switch (state)
        // step 0 to 9 are init. >= 10 are regular stuff
        case 0:
           // try to read from the rtc
           twi.read_from_slave(avr::rtc_address,nullptr,0, 1);
           state++;
           return false;
        case 1:
            if (check_twi(state))
                unsigned char i = 0;
                while (twi.rx_size() > 0)
                    twi >> g_buffer[i];
                    ++i;
                // is the Clock Halt bit active?
                if (g_buffer[0] & 0x80)
                    // bit is set. We need to enable the clock
                    sys.LED_141.toggle();
                else
                    // bis is cleared. Clock is running
                    state = 4;
                return true;
            return false;
        case 2:
            // enable the clock
            g_buffer[0] = 0x00;
            g_buffer[1] = to_bcd(sys.dt.sec);
            g_buffer[2] = to_bcd(sys.dt.min);
            g_buffer[3] = to_bcd(sys.dt.hour);
            g_buffer[4] = sys.dt.dow;
            g_buffer[5] = to_bcd(sys.dt.day);
            g_buffer[6] = to_bcd(sys.dt.month);
            g_buffer[7] = to_bcd(sys.dt.year);
            g_buffer[8] = 0;
            twi.write_to_slave(avr::rtc_address, g_buffer, 8);
            state++;
            return false;
        case 3:
            return check_twi(state);
        case 4:
            // clock is running. poll it only every second
            rtc_timeout.start(1000);
            state++;
            return true;
        case 5:
            if (rtc_timeout.elapsed())
                if (sys.rtc_change_in_progress)
                    state = 10;
                else
                    state++;
            return true;
        case 6:
           g_buffer[0] = 0x00;
           twi.read_from_slave(avr::rtc_address,g_buffer,1, 8);
           state++;
           return false;
        case 7:
                    twi >> g_buffer[i];
                    ++i;
                if (i == 8)
                sys.LED_142.toggle();
                // update the sys variables from the RTC values
                sys.dt.sec   = from_bcd(g_buffer[0] & 0x7F);
                sys.dt.min   = from_bcd(g_buffer[1] & 0x7F);
                sys.dt.hour  = from_bcd(g_buffer[2] & 0x3F);
                sys.dt.dow   = g_buffer[3] & 0x07;
                sys.dt.day   = from_bcd(g_buffer[4] & 0x7F);
                sys.dt.month = from_bcd(g_buffer[5] & 0x1F);
                sys.dt.year  = from_bcd(g_buffer[6] & 0xFF);
                // jump back to timeout
                state = 4;
                return true;
            break;
        case 10:
            // wait unti user is done
            if (!sys.rtc_change_in_progress)
                state = 2;
            return true;
        default:
            break;
        return true;
    }; // namespace rtc
    Das ist die Komplette Schrittkette.
    0-> Init und Check ob die Uhr passt
    2->5 Ist das setzen der Uhr
    6-10: Ist das pollen der Uhr
    Das ganze wird Zyklisch aus einem Scheduler aufgerufen.
    EDIT: In meinem Fall läuft das alles in einem Timer IRQ. Damit kann ich Laufzeiten wie bei einer SPS garantieren. Ich darf mir aber keine Zeitscheibenverletzungen erlauben Bild   Auch habe ich hier ganz klar den Schwerpunkt auf Trennung der Anwendungslogik von der TWI logik getrennt. Wiederverwendung und Wartbarkeit!
    Geändert von schorsch_76 (05.06.2015 um 21:36 Uhr)
    Osterzgebirge
    Keine Lib nötig, diesen Code hat User Jurs mal im Arduino-Forum veröffentlicht. Alles da, was man _wirklich_ braucht.
    #include <Wire.h>
    // I2C Adresse der RTC ist 0x68 für DS1307 und DS3231
    #define RTC_I2C_ADDRESS 0x68
    int jahre,monate,tage,stunden,minuten,sekunden;
    // wochentag bleibt in diesem Test-Sketch unberücksichtigt
    void rtcReadTime(int &jahre, int &monate, int &tage, int &stunden, int &minuten, int &sekunden)
    // aktuelle Zeit aus RTC auslesen
    // Reset the register pointer
      Wire.beginTransmission(RTC_I2C_ADDRESS);
      Wire.write(0);
      Wire.endTransmission();
      Wire.requestFrom(RTC_I2C_ADDRESS, 7);
      // A few of these need masks because certain bits are control bits
      sekunden    = bcdToDec(Wire.read() & 0x7f);
      minuten     = bcdToDec(Wire.read());
      stunden     = bcdToDec(Wire.read() & 0x3f);  // Need to change this if 12 hour am/pm
      /*wochentag   = */bcdToDec(Wire.read());
      tage        = bcdToDec(Wire.read());
      monate      = bcdToDec(Wire.read());
      jahre       = bcdToDec(Wire.read())+2000;
    void rtcWriteTime(int jahre, int monate, int tage, int stunden, int minuten, int sekunden)
    // aktuelle Zeit in der RTC speichern
      Wire.write(0);
      Wire.write(decToBcd(sekunden));    // 0 to bit 7 starts the clock
      Wire.write(decToBcd(minuten));
      Wire.write(decToBcd(stunden));      // If you want 12 hour am/pm you need to set
                                       // bit 6 (also need to change readDateDs1307)
      Wire.write(decToBcd(0)); // Wochentag unberücksichtigt
      Wire.write(decToBcd(tage));
      Wire.write(decToBcd(monate));
      Wire.write(decToBcd(jahre-2000));
    byte decToBcd(byte val) // Hilfsfunktion zum Lesen/Schreiben der RTC
    // Convert decimal number to binary coded decimal
    // Hilfsfunktion für die Echtzeituhr
      return ( (val/10*16) + (val%10) );
    byte bcdToDec(byte val)  // Hilfsfunktion zum Lesen/Schreiben der RTC
    // Convert binary coded decimal to decimal number
      return ( (val/16*10) + (val%16) );
    int getIntFromString (char *stringWithInt, byte num)
    // input: pointer to a char array
    // returns an integer number from the string (positive numbers only!)
    // num=1, returns 1st number from the string
    // num=2, returns 2nd number from the string, and so on
      char *tail;
      while (num>0)
        num--;
        // skip non-digits
        while ((!isdigit (*stringWithInt))&&(*stringWithInt!=0)) stringWithInt++;
        tail=stringWithInt;
        // find digits
        while ((isdigit(*tail))&&(*tail!=0)) tail++;
        if (num>0) stringWithInt=tail; // new search string is the string after that number
      return(strtol(stringWithInt, &tail, 0));
    void setup()
      Wire.begin();       // initialisiert die Wire-Library
      Serial.begin(9600); // Serielle Kommunikation starten
      while (!Serial);    // wait for serial port to connect. Needed for Leonardo only
      Serial.println("\r\nRTC Demo Sketch by jurs for German Arduino Forum");
      Serial.println("Dieser Sketch zeigt die aktuelle Zeit alle 10 Sekunden im 'Serial Monitor'.");
      Serial.println("Du kannst die Zeit mit einem 'set' Befehl im 'Serial Monitor' neu setzen.");
      Serial.println("\r\nBeispiel:");
      Serial.println("set 28.08.2013 10:54\r\n");
    void machsAlle10Sekunden(){
      static unsigned long prevMillis=-20000;
      char linebuf[30];
      if (millis()-prevMillis<10000) return; // Zeit noch nicht erreicht, Funktion abbrechen
      prevMillis=millis();
      // RTC Uhr auslesen
      rtcReadTime(jahre,monate,tage,stunden,minuten,sekunden);
      // Zeit für Ausgabe formatieren
      snprintf(linebuf,sizeof(linebuf),"%02d.%02d.%04d %02d:%02d:%02d Uhr",tage,monate,jahre,stunden,minuten,sekunden);
      // Zeit auf serieller Schnittstelle ausgeben
      Serial.println(linebuf);
    void behandleSerielleBefehle()
      char linebuf[30];
      byte counter;
      if (Serial.available())
        delay(100); // Warte auf das Eintreffen aller Zeichen vom seriellen Monitor
        memset(linebuf,0,sizeof(linebuf)); // Zeilenpuffer löschen
        counter=0; // Zähler auf Null
        while (Serial.available())
          linebuf[counter]=Serial.read(); // Zeichen in den Zeilenpuffer einfügen
          if (counter<sizeof(linebuf)-1) counter++; // Zeichenzähler erhöhen
        // Ab hier ist die Zeile eingelesen
        if (strstr(linebuf,"set")==linebuf) // Prüfe auf Befehl "set" zum Setzen der Zeit
        { // Alle übermittelten Zahlen im String auslesen
          tage=getIntFromString (linebuf,1);
          monate=getIntFromString (linebuf,2);
          jahre=getIntFromString (linebuf,3);
          stunden=getIntFromString (linebuf,4);
          minuten=getIntFromString (linebuf,5);
          sekunden=getIntFromString (linebuf,6);
        else
          Serial.println("Befehl unbekannt.");
          return;
        // Ausgelesene Werte einer groben Plausibilitätsprüfung unterziehen:
        if (jahre<2000 || monate<1 || monate>12 || tage<1 || tage>31 || (stunden+minuten)==0)
          Serial.println("\r\nFehlerhafte Zeitangabe im 'set' Befehl");
          return;
        rtcWriteTime(jahre, monate, tage, stunden, minuten, sekunden);
        Serial.println("Zeit und Datum wurden auf neue Werte gesetzt.");
    void loop()
      machsAlle10Sekunden();
      behandleSerielleBefehle();
    Grüssle, Sly
  1. Arduino vs. Arduino: Kampf um die Arduino IDE
    Letzter Beitrag: 04.04.2015, 17:21
  2. Rtc ds3231
    Von simonelein im Forum C - Programmierung (GCC u.a.)
    Antworten: 10
    Letzter Beitrag: 15.08.2012, 17:27
  3. [ERLEDIGT] [ARDUINO] 2 Motoren + Servo mit dem Arduino Uno steuern
    Von Torrentula im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 31.08.2011, 16:31
  4. RTC
    Von Kampi im Forum Basic-Programmierung (Bascom-Compiler)
    Letzter Beitrag: 21.01.2010, 22:04
  5. RTC für CCRP5
    Von solo im Forum Robby CCRP5
    Letzter Beitrag: 07.04.2006, 06:40
