Ergebnis 1 bis 10 von 14
Thema: Ansteuerung LCD des Butterfly AVR mit BASCOM Demo 1.11.7.7
Baum-Darstellung
  1. #7
    Bocholt
    Hier erst einmal das dazugehörige Bas-File (incl. Tastaturabfrage und Tastenquittungston):
    '                       (c) 2004, MCS Electronics
    '               M169_LCD.BAS demonstrates LCD butterfly driver
    $regfile = "m169def.dat"
    $crystal = 8000000
    $baud = 9600
    $lib "lcd_butterfly.lbx"
    'you need to dim this byte
    Dim _butterfly_digit As Byte
    Dim S As String * 6
    Dim I As Byte
    Dim Taster_nummer As Byte
    Dim Pulses As Word , Periods As Word
    Pulses = 256 : Periods = 100                                'set variables
    Speaker Alias Portb.5                                       'define port pin
    Declare Sub Taster_1_routine
    Declare Sub Taster_2_routine
    Declare Sub Taster_3_routine
    Declare Sub Taster_4_routine
    Declare Sub Taster_5_routine
    Config Pinb.4 = Input
     Portb.4 = 1
    Config Pinb.6 = Input
     Portb.6 = 1
    Config Pinb.7 = Input
     Portb.7 = 1
    Config Pine.2 = Input
     Porte.2 = 1
    Config Pine.3 = Input
     Porte.3 = 1
    'Config Serialin = Buffered , Size = 12
    Restart:
    Cls
    S = "AVR"
    Cls : Lcd "BASCOM" : Wait 2
    Cls : Lcd S : Wait 1
    Do
       For I = 1 To 5
          Taster_nummer = I
          Select Case Taster_nummer
          Case 1 : Debounce Pinb.6 , 0 , Taster_1_routine , Sub
          Case 2 : Debounce Pinb.7 , 0 , Taster_2_routine , Sub
          Case 3 : Debounce Pinb.4 , 0 , Taster_3_routine , Sub
          Case 4 : Debounce Pine.2 , 0 , Taster_4_routine , Sub
          Case 5 : Debounce Pine.3 , 0 , Taster_5_routine , Sub
          End Select
       Next
    Loop
    End
          Gosub Tastenquittung
       Cls : Lcd "NORD"
       Print "NORD"
    End Sub
       Cls : Lcd "SUED"
       Print "SUED"
    End Sub
       Cls : Lcd "SELECT";
    End Sub
       Cls : Lcd "WEST";
       Print "WEST"
    End Sub
       Cls : Lcd "OST"
       Print "OST"
    End Sub
    Tastenquittung:
       Sound Speaker , Pulses , Periods                         'make some noise
    Return
    Lcd_butterfly_data:
    Data 0%                                                     ' space
    Data 0%                                                     ' !
    Data 0%                                                     '""
    Data 0%                                                     ' #
    Data 0%                                                     '$
    Data 0%                                                     '  %
    Data 0%                                                     ' &
    Data 0%                                                     '  '
    Data 0%                                                     '  (
    Data 0%                                                     '  )
    Data 0%                                                     ' *
    Data 0%                                                     ' +
    Data 0%                                                     ' ,
    Data 0%                                                     ' -
    Data 0%                                                     ' .
    Data 0%                                                     '/
    Data &H5559%                                                ' 0
    Data &H0118%                                                '1
    Data &H1E11%                                                ' 2
    Data &H1B11%                                                ' 3
    Data &H0B50%                                                ' 4
    Data &H1B41%                                                ' 5
    Data &H1F41%                                                '6
    Data &H0111%                                                ' 7
    Data &H1F51%                                                ' 8
    Data &H1B51%                                                '9
    Data 0%                                                     ':
    Data 0%                                                     ';
    Data 0%                                                     '<
    Data 0%                                                     '=
    Data 0%                                                     '>
    Data 0%                                                     '?
    Data 0%                                                     '@
    Data &H0F51%                                                ' A
    Data &H3991% , &H1441% , &H3191% , &H1E41% , &H0E41% , &H1D41% , &H0F50% , &H2080% , &H1510% , &H8648% , &H1440% , &H0578%
    Data &H8570% , &H1551% , &H0E51% , &H9551% , &H8E51% , &H9021% , &H2081% , &H1550% , &H4448% , &HC550% , &HC028% , &H2028% , &H5009%
    hier das Hex-File dazu:
