Ergebnis 1 bis 10 von 19
Thema: DIY Servo
    Dresden
    Leider hab ich keine Seite und bei Youtube hab ich schon ewig nix hochgeladen. An sich wär das aber was, was ich mal gebrauchen könnte. Aber erstmal egal.
    Hmm, wenn du mit dem Code was anfangen kannst ... ist in Bascom geschrieben Bild
    $regfile = "m32def.dat"
    $framesize = 32
    $swstack = 32
    $hwstack = 32
    $crystal = 16000000
    $baud = 9600
    Declare Sub Serial0charmatch()
    Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 1 , Clockrate = 128
    Config Adc = Single , Prescaler = Auto , Reference = Avcc
    Config Timer1 = Pwm , Pwm = 10 , Compare A Pwm = Clear Up , Compare B Pwm = Clear Up , Prescale = 1
    Config Timer0 = Timer , Prescale = 1024
    On Timer0 Isr0
    Config Lcdpin = Pin , Db4 = Portc.3 , Db5 = Portc.2 , Db6 = Portc.1 , _
       Db7 = Portc.0 , E = Portc.4 , Rs = Portc.5
    Config Lcd = 20 * 4
    Cursor Off
    Cls
    Config Porta.0 = Input
    Config Porta.1 = Output
    Config Porta.2 = Output
    Config Portb.3 = Output
    Portb.3 = 1
    Spiinit
    Config Serialin = Buffered , Size = 30 , Bytematch = 13
    Dim Incoming_str As String * 4
    Dim Angle As Integer
    Dim Angle_vor As Integer
    Dim Angle_low As Byte At Angle Overlay
    Dim Angle_high As Byte At Angle + 1 Overlay
    Dim Anglereg(2) As Byte
    Dim Errorreg(2) As Byte
    Dim Adcwert As Long
    Dim Tast As Integer
    Dim Temp As Long
    Dim E As Long
    Dim E_vor As Long
    Dim E_int As Long
    Dim De As Long
    Dim Count As Byte
    Dim Pos As Long
    Dim Turns As Integer
    Turns = 0
    E_vor = 0
    E_int = 0
    De = 0
    Count = 0
    Anglereg(1) = &HFF
    Anglereg(2) = &HFF
    Errorreg(1) = &H40
    Errorreg(2) = &H01
    Wait 1
    Porta.1 = 1
    Porta.2 = 1
    Portb.3 = 0
    Waitus 10
    'Angle_high = Spimove(errorreg(1) , 1)
    'Angle_low = Spimove(errorreg(2) , 1)
    'Waitus 10
    Angle_high = Spimove(anglereg(1) , 1)
    Angle_low = Spimove(anglereg(2) , 1)
    Waitus 10
    Portb.3 = 1
    Angle_high = Angle_high And &B00111111
    Adcwert = Angle
    Enable Interrupts
    Enable Timer0
    Waitms 500
    Do
       Count = Count + 1
       If Count = 20 Then
          Count = 0
          If Adcwert = 1000 Then
             Adcwert = 17384
          Else
             Adcwert = 1000
          End If
       End If
       Cls
       Locate 1 , 1
       Lcd Angle                                                'anzeigen Istwinkel
       Locate 2 , 1
       Lcd Adcwert                                              'anzeigen Sollwinkel
       Locate 2 , 10
       Lcd E
       Locate 1 , 10
       Lcd E_int
       Locate 3 , 1
       Lcd Tast                                                 'anzeigen PWM-Wert
       Locate 4 , 10
       Lcd Pos
       Locate 4 , 1
       Lcd Turns
       Waitms 100
    Loop
       Input Incoming_str Noecho
       Print Angle
    End Sub
    Isr0:
       Load Timer0 , 30
       Portb.3 = 0
       Waitus 5
       Waitus 5
       Portb.3 = 1
       Temp = Angle - Angle_vor
       If Temp < -8192 Then
          Turns = Turns + 1
       Elseif Temp > 8192 Then
          Turns = Turns - 1
       End If
       Pos = 16384 * Turns
       Pos = Pos + Angle
       Angle_vor = Angle
    '   Start Adc
    '   Adcwert = Getadc(0)
    '   Adcwert = Adcwert * 16
       E = Adcwert - Pos
       De = E - E_vor
       If De > 400 Then
          De = 400
       Elseif De < -400 Then
          De = -400
       End If
       E_vor = E
       Tast = E * 2
          Temp = E_int / 128
          Tast = Tast + Temp
       Temp = De * 40
       Tast = Tast + Temp
       If Tast > 0 Then
          Porta.1 = 1
          Porta.2 = 0
          Else
          Porta.1 = 0
          Porta.2 = 1
       End If
       Tast = Abs(tast)
       Tast = Tast + 400
       If Tast > 1023 Then
          Tast = 1023
       Else
          E_int = E_int + E
       End If
       Compare1a = Tast
    Return
    Die Probleme, die ich da derzeit habe, hat mit der Größe der Zahlen zu tun. Der Sensor gibt wie gesagt 14 Bit aus, mit Integer kann ich also gerade einmal 4 Umdrehungen abdecken (wobei das je nach Anwendung auch schon reichen kann). Nagut, wöllte ich die Auflösung nicht nutzen, könnte ich ganz leicht mittels Bitshift auf weniger Bit runterskalieren, aber ich wills ja gerne so präzise wie möglich. Jedenfalls hab ich damit erst recht Probleme beim Integrator, da dieser ja in jedem Reglertakt die Abweichung aufaddiert. Bei einem relativ großen Sprung kommt da wirklich viel zusammen und wenn man dann versucht, mit diesem riesigen Wert weiterzurechnen, bekommt man erst recht Probleme. Da verschwinden dann gerne mal Bits und der Regler dreht durch. Hatte zwischendurch schon paar Mal Versionen gehabt, da hat der Motor nicht aufgehört zu drehen. Jedenfalls ist mein nächster Schritt, mal eine vernünftige Kommunikation mit dem Rechner dazu zu basteln, um dann mal den Motor ordentlich modellieren und simulieren zu können. Ich arbeite bei Regelungstechnik doch lieber mit Übertragungsfunktionen, als nur herum zu probieren. Bei meinem letzten Experiment hatte die Verwendung einer Vorsteuerung schon eine enorme Verbesserung gebracht. Die sorgt nämlich dafür, dass der Motor hauptsächlich den Sollwerten entsprechend so angesteuert wird, dass er schon ohne Regelung etwa die Sollbahn abfahren würde. Dann braucht der Regler nur noch die dabei auftretende Abweichung ausregeln.
    AI - Artificial Idiocy
    So, ich bin es mal wieder. Hatte leider die Tage doch keine Zeit. Also jetzt:
    Erstmal vielen Dank an dich Geistesblitz Bild   Jetzt kann mein Servo endlich 360° ohne Probleme drehen ....
    Nur die Regelung muss ich noch ein bisschen verbessern, aber erstmal egal.
    Also Bascom benutze ich normalerweise auch, doch steige ich durch dein Programm trotzdem nicht durch (im Thema Software bin ich eben noch ein Einsteiger Bild   ).
    Ist das Programm komplett mit Regelung, oder fehlt da noch was ?
    Also möchtest du eher ein endlos Servo bauen (vgl. mit Schrittmotor...) ?
    Mein Servo soll übrigens eher eine Art Eigenbau eines Dynamixels sein. Aber das nimmt sich ja nicht so viel.
    Wie genau soll das mit einer Vorsteuerung funktionieren ?
    Dresden
    Naja, man kann die Dynamik eines Elektromotors mittels Differentialgleichungen beschreiben, und wenn man die passend umstellt, kann man aus dem Zeitverlauf von Sollposition, -geschwindigkeit und -beschleunigung den Spannungsverlauf berechnen, der genau zur gewünschten Motorbewegung führt. Die Regelung ist dann nur noch zum Ausgleichen von Modellabweichungen und Störungen da. Bringt allerdings nur etwas, wenn sich die Sollposition nicht nur sprunghaft ändert, sondern einen halbwegs glatten Verlauf zeigt. Wenn man nämlich einen Sprung versucht zu differenzieren, bekommt man nur einen kurzen Puls. Da geht der Motor durch die Regelung eh in die Begrenzung. Der Sollwertverlauf sollte also so geschaffen werden, dass der Motor da auch hinterherkommt, ich möchte eben eine gute Folgeregelung erzielen. Für das Anfahren von diskreten Positionen reicht der Regler an sich aus.
    Ja, der Regler befindet sich in der ISR. Da wird im Prinzip nur der Winkel (Angle) mittels SPI vom Sensor eingelesen, die Position (Pos) für eben mehrere Umdrehungen berechnet und mit dem Sollwert (Adcwert) verglichen. Aus dem Vergleich resultiert die Abweichung (E), von der dann Differenz (De) und Integral (E_int) gebildet werden, jeweils mit einer Verstärkung multipliziert und in der Stellgröße (Tast) gespeichert. Anschließend noch ein wenig Anpassung wegen der Begrenzung, da Tast eben größer werden kann als die maximalen 1023 für die PWM.
    Das Programm ist zugegebenermaßen nicht wirklich übersichtlich und es hat sich seit ich es hier reingestellt hab auch schon wieder an vielen Stellen verändert. Wahrscheinlich schreib ich es nochmal neu, wenn alles weitestgehend passt. Die Vorsteuerung hab ich zwar schon versucht zu implementieren, allerdings bekomm ich das Modell des Motors nicht zufriedenstellend aufgestellt.
    Hi
    Pünktlich zum Jahresbeginn gibt es von mir ein Update Bild
    Ich habe es in den Ferien endlich mal wieder geschafft, etwas für mein Hobby zu tun....
    Dabei herausgekommen ist ein neues und auch viel stärkeres Servo. :
    Wer sich für den Code interessiert, der jetzt auch schon ganz gut funktioniert (für Arduino):
    const int ledPin = 13; //LED connected to digital pin 13
    const int clockPin = 7; //output to clock
    const int CSnPin = 6; //output to chip select
    const int inputPin = 2; //read AS5040
    int inputstream = 0; //one bit read from pin
    long packeddata = 0; //two bytes concatenated from inputstream
    long angle = 0; //holds processed angle value
    long anglemask = 65472; //0x1111111111000000: mask to obtain first 10 digits with position info
    long statusmask = 63; //0x000000000111111; mask to obtain last 6 digits containing status info
    long statusbits; //holds status/error information
    int DECn; //bit holding decreasing magnet field error data
    int INCn; //bit holding increasing magnet field error data
    int OCF; //bit holding startup-valid bit
    int COF; //bit holding cordic DSP processing error data
    int LIN; //bit holding magnet field displacement error data
    int debug = 1; //SET THIS TO 0 TO DISABLE PRINTING OF ERROR CODES
    int shortdelay = 80; // this is the microseconds of delay in the data clock
    int longdelay = 8; // this is the milliseconds between readings
    int pwm_pin = 3;  //Motor pwm
    int in_1 = 4;   //Motor Richtung
    int in_2 = 5;   //Motor Richtung
    String msg;
    char a;
    int soll_wert;
    int ist_wert;
    int e;
    int Winkel;
    int Winkel_alt;
    int Winkel_abweichung;
    int Um;
    int esum;
    int ealt;
    int yaus;
    int y_max = 128;
    int y_min = 0;
    int esum_max = 700;
    float y;
    float i;
    float d;
    float Kp = 2.0;  //P
    float Ki = 3.0;  //I
    float Kd = 0.5;  //D
    float Ta = 0.02;  //Abtast
    void setup()
    Serial.begin(9600);
    pinMode(ledPin, OUTPUT); // visual signal of I/O to chip
    pinMode(clockPin, OUTPUT); // SCK
    pinMode(CSnPin, OUTPUT); // CSn -- has to toggle high and low to signal chip to start data transfer
    pinMode(inputPin, INPUT); // SDA
    pinMode(in_1, OUTPUT);
      pinMode(in_2, OUTPUT);
      pinMode(pwm_pin, OUTPUT);
      digitalWrite(in_1, HIGH);
      digitalWrite(in_2, LOW);
      analogWrite(pwm_pin, 0);
      // CSn needs to cycle from high to low to initiate transfer. Then clock cycles. As it goes high
    // again, data will appear on sda
    digitalWrite(CSnPin, HIGH); // CSn high
    digitalWrite(clockPin, HIGH); // CLK high
    delay(longdelay);
    digitalWrite(ledPin, HIGH); // signal start of transfer with LED
    digitalWrite(CSnPin, LOW); // CSn low: start of transfer
    delayMicroseconds(shortdelay);  // delay for chip -- 1000x as long as it needs to be
    digitalWrite(clockPin, LOW); // CLK goes low: start clocking
    delayMicroseconds(shortdelay);  // hold low for 10 ms
    for (int x=0; x <16; x++) // clock signal, 16 transitions, output to clock pin
    digitalWrite(clockPin, HIGH); //clock goes high
    delayMicroseconds(shortdelay); // wait 10ms
    inputstream =digitalRead(inputPin); // read one bit of data from pin
    //Serial.print(inputstream, DEC);
    packeddata = ((packeddata << 1) + inputstream);// left-shift summing variable, add pin value
    delayMicroseconds(shortdelay); // end of one clock cycle
    // end of entire clock cycle
    //Serial.println(" ");
    digitalWrite(ledPin, LOW); // signal end of transmission
    // lots of diagnostics for verifying bitwise operations
    //Serial.print("packed:");
    //Serial.println(packeddata,DEC);
    //Serial.print("pack bin: ");
    // Serial.println(packeddata,BIN);
    angle = packeddata & anglemask; // mask rightmost 6 digits of packeddata to zero, into angle.
    //Serial.print("mask: ");
    //Serial.println(anglemask, BIN);
    //Serial.print("bin angle:");
    //Serial.println(angle, BIN);
    //Serial.print("angle: ");
    //Serial.println(angle, DEC);
    angle = (angle >> 6); // shift 16-digit angle right 6 digits to form 10-digit value
    //Serial.print("angleshft:");
    //Serial.print("angledec: ");
    angle = angle * 0.3515; // angle * (360/1024) == actual degrees
    //Serial.print("angle: "); // and, finally, print it.
    Winkel_alt = int(angle);
    //Serial.println("--------------------");
    //Serial.print("raw: "); // this was the prefix for the bit-by-bit diag output inside the loop.
    if (debug)
    statusbits = packeddata & statusmask;
    DECn = statusbits & 2; // goes high if magnet moved away from IC
    INCn = statusbits & 4; // goes high if magnet moved towards IC
    LIN = statusbits & 8; // goes high for linearity alarm
    COF = statusbits & 16; // goes high for cordic overflow: data invalid
    OCF = statusbits & 32; // this is 1 when the chip startup is finished.
    if (DECn && INCn) { Serial.println("magnet moved out of range"); }
    else
    if (DECn) { Serial.println("magnet moved away from chip"); }
    if (INCn) { Serial.println("magnet moved towards chip"); }
    if (LIN) { Serial.println("linearity alarm: magnet misaligned? Data questionable."); }
    if (COF) { Serial.println("cordic overflow: magnet misaligned? Data invalid."); }
    packeddata = 0; // reset both variables to zero so they don't just accumulate
    angle = 0;
    void loop()
    //unsigned long startmicros=micros();
      if(Serial.available() > 0)
        msg = "";
        while(Serial.available() > 0){
          a = Serial.read();
          msg = msg + String(a);
          delay(250);
        soll_wert = msg.toInt();
        Serial.println(soll_wert);
    delay(longdelay);
    Winkel = int(angle);
    if (debug)
    else
    angle = 0;
    regler();
    //unsigned long endmicros=micros();
    //Serial.println(endmicros-startmicros,DEC);
    void regler()  {
    Winkel_abweichung = Winkel_alt - Winkel;
    if(Winkel_abweichung > 180)  {
      Um = Um + 1;
    if(Winkel_abweichung < -180)  {
      Um = Um - 1;
    ist_wert = 360 * Um;
    ist_wert = Winkel + ist_wert;
    Winkel_alt = Winkel;
    Serial.println(ist_wert);
          e = soll_wert - ist_wert;
          e = abs(e);
          esum = esum + e;
          if(esum > esum_max)  {
            esum = esum_max;
          i = float(esum) * Ta;
          i = i * Ki;
          d = float(e) - float(ealt);
          d = d / Ta;
          d = d * Kd;
          y = Kp * e;
          y = y + i;
          y = y + d;
          yaus = int(y);
          //Serial.println(y);
          ealt = e;
          if(yaus > y_max)  {
            yaus = y_max;
          if(yaus < y_min)  {
            yaus = y_min;
          if(ist_wert > soll_wert)  {
            analogWrite(pwm_pin, yaus);
          if(ist_wert < soll_wert)  {
            digitalWrite(in_1, LOW);
            digitalWrite(in_2, HIGH);
          if(ist_wert == soll_wert)  {
            esum = 0;
            ealt = 0;
  1. DIY Funktionsgenerator
    Von Schachmann im Forum Vorstellungen+Bilder von fertigen Projekten/Bots
    Letzter Beitrag: 21.07.2015, 19:11
  2. Platinenlayout UV-Belichter - Kaufen oder DIY?
    Von Cysign im Forum Konstruktion/CAD/3D-Druck/Sketchup und Platinenlayout Eagle & Fritzing u.a.
    Letzter Beitrag: 17.10.2014, 05:46
  3. RoboMow RL-Serie DIY
    Von Bernd_Stein im Forum Staubsaugerroboter / Reinigungs- und Rasenmähroboter
    Letzter Beitrag: 09.02.2013, 18:48
  4. DIY Alu-Schweissgerät
    Von hagbart06 im Forum Elektronik
    Letzter Beitrag: 20.02.2012, 21:12
  5. DIY Logikanalysator
    Von nietzsche im Forum Suche bestimmtes Bauteil bzw. Empfehlung
    Antworten: 11
    Letzter Beitrag: 15.05.2009, 15:12
