Ergebnis 1 bis 5 von 5
Thema: Neuer RP6 V2 Self Test rechte Kette dreht nicht
Baum-Darstellung
    Hallo erstmal.
    Hab heute meinen neuen RP6 V2 bekommen.
    Hab nach der Anleitung den Self Test gestartet(neuester RobotLoader, neueste Test Programme),
    beim Motorentest bleibt der rechte Motor einfach stehen.
    Hab versucht die Encoder einzustellen, ohne erfolg.
    Der rechte motor bleibt ruhig.
    Die Akkus hatten eine Spannung von 8,10 Volt.
    PHP-Code:
    T000 |VL000 |VR000 |PL000 |PR000 |IL003 |IR004 |UB08.03V
    T
    000 |VL000 |VR001 |PL000 |PR000 |IL003 |IR004 |UB08.03V
    T
    T
    000 |VL000 |VR000 |PL000 |PR000 |IL004 |IR004 |UB08.03V
    T
    000 |VL000 |VR000 |PL000 |PR000 |IL002 |IR004 |UB08.03V
    T
    T
    T
    T
    T
    T
    000 |VL000 |VR000 |PL000 |PR000 |IL001 |IR004 |UB08.03V
    T
    T
    T
    T
    T
    T
    Speed Left
    OK
    Speed Right
    OK
    T
    020 |VL000 |VR000 |PL000 |PR000 |IL004 |IR004 |UB08.03V
    T
    020 |VL000 |VR000 |PL000 |PR000 |IL001 |IR004 |UB08.02V
    T
    T
    020 |VL000 |VR000 |PL000 |PR000 |IL001 |IR004 |UB08.03V
    T
    020 |VL000 |VR000 |PL010 |PR010 |IL003 |IR004 |UB08.02V
    T
    020 |VL000 |VR000 |PL020 |PR020 |IL008 |IR004 |UB08.02V
    T
    020 |VL000 |VR000 |PL030 |PR030 |IL012 |IR004 |UB08.02V
    T
    020 |VL002 |VR000 |PL039 |PR040 |IL018 |IR004 |UB08.01V
    T
    020 |VL000 |VR000 |PL049 |PR050 |IL025 |IR004 |UB08.01V
    T
    020 |VL013 |VR000 |PL062 |PR070 |IL049 |IR004 |UB07.98V
    T
    020 |VL033 |VR000 |PL056 |PR080 |IL052 |IR004 |UB08.00V
    T
    020 |VL025 |VR000 |PL053 |PR090 |IL050 |IR004 |UB07.99V
    <%(16,51,0,1,0,1,500,74,500,1,0,84,0,1,500,101,500,1,0,110,0,1,500,106,500,1,0,135,0,1,500,115,500,1,0,82,0,1,500,73,500,1,0,81,0,1,500,92,500,1,0,119,0,1,500,115,500,1,0,108,0,1,500,144,500,1,0,114,0,1,500,69,500,1,0,77,0,1,500,82,500,1,0,93,0,1,500,122,500,1,0,120,0,1,500,114,500,1,0,164,0,1,500,113,x)%>
    T020 |VL022 |VR000 |PL052 |PR100 |IL052 |IR004 |UB07.99V
    T
    020 |VL020 |VR000 |PL051 |PR118 |IL048 |IR004 |UB07.98V
    T
    020 |VL023 |VR000 |PL050 |PR130 |IL047 |IR004 |UB07.99V
    T
    020 |VL022 |VR000 |PL049 |PR140 |IL046 |IR004 |UB08.00V
    Speed Left
    OK
    ####### ERROR Right #######
    ####### !!!  WARNING WARNING WARNING  !!! #######
    ####### !!! TEST FINISHED WITH ERRORS !!! #######
    #### Please check motor and encoder assembly! ###
    #### And also check Sensors for defects!      ###
    Achja die Getriebe sind freigängig.
    Hab ich vl iwas falsch gemacht?
    Wenn ich am Poti für den linken Antrieb drehe und dann den rechten bekomme ich beim Test c zwar Digital Werte jedoch bewegt sich der Motor trotzdem nicht.
    SPEED RIGHT IS TOO LOW!!!!
    P: 050 |VL: 059 |VR: 003 |IL: 043 |IR: 003 |DCL: 48:51 |DCR: 72:27 |UB: 08.53V
    P: 050 |VL: 057 |VR: 050 |IL: 042 |IR: 004 |DCL: 49:50 |DCR: 83:16 |UB: 08.52V
    P: 050 |VL: 054 |VR: 063 |IL: 042 |IR: 004 |DCL: 50:50 |DCR: 64:35 |UB: 08.52V
    P: 050 |VL: 054 |VR: 050 |IL: 042 |IR: 004 |DCL: 49:50 |DCR: 76:23 |UB: 08.52V
    P: 050 |VL: 054 |VR: 050 |IL: 045 |IR: 004 |DCL: 50:50 |DCR: 76:23 |UB: 08.52V
    P: 050 |VL: 055 |VR: 037 |IL: 045 |IR: 004 |DCL: 49:50 |DCR: 76:23 |UB: 08.51V
    P: 050 |VL: 055 |VR: 031 |IL: 044 |IR: 004 |DCL: 49:50 |DCR: 88:11 |UB: 08.52V
    P: 050 |VL: 055 |VR: 031 |IL: 040 |IR: 004 |DCL: 50:50 |DCR: 88:11 |UB: 08.56V
    P: 050 |VL: 059 |VR: 035 |IL: 040 |IR: 004 |DCL: 50:50 |DCR: 78:21 |UB: 08.56V
    P: 050 |VL: 061 |VR: 038 |IL: 039 |IR: 003 |DCL: 49:50 |DCR: 78:21 |UB: 08.56V
    P: 050 |VL: 061 |VR: 038 |IL: 035 |IR: 004 |DCL: 49:50 |DCR: 81:18 |UB: 08.58V
    P: 050 |VL: 070 |VR: 038 |IL: 032 |IR: 003 |DCL: 50:50 |DCR: 81:18 |UB: 08.58V
    P: 050 |VL: 072 |VR: 038 |IL: 032 |IR: 003 |DCL: 50:50 |DCR: 75:24 |UB: 08.58V
    P: 050 |VL: 072 |VR: 038 |IL: 029 |IR: 004 |DCL: 50:50 |DCR: 80:19 |UB: 08.61V
    P: 050 |VL: 072 |VR: 039 |IL: 029 |IR: 004 |DCL: 48:51 |DCR: 80:19 |UB: 08.61V
    P: 050 |VL: 071 |VR: 035 |IL: 029 |IR: 004 |DCL: 50:50 |DCR: 87:12 |UB: 08.59V
    P: 050 |VL: 059 |VR: 043 |IL: 038 |IR: 003 |DCL: 49:50 |DCR: 74:25 |UB: 08.59V
    P: 050 |VL: 056 |VR: 035 |IL: 044 |IR: 004 |DCL: 49:50 |DCR: 81:18 |UB: 08.51V
    P: 050 |VL: 056 |VR: 035 |IL: 045 |IR: 004 |DCL: 48:51 |DCR: 81:18 |UB: 08.49V
    P: 050 |VL: 054 |VR: 042 |IL: 045 |IR: 003 |DCL: 48:51 |DCR: 78:21 |UB: 08.49V
    P: 050 |VL: 054 |VR: 059 |IL: 045 |IR: 003 |DCL: 50:50 |DCR: 68:31 |UB: 08.49V
    P: 050 |VL: 056 |VR: 047 |IL: 044 |IR: 004 |DCL: 50:50 |DCR: 77:22 |UB: 08.51V
    P: 050 |VL: 057 |VR: 056 |IL: 044 |IR: 004 |DCL: 49:50 |DCR: 71:29 |UB: 08.51V
    P: 050 |VL: 060 |VR: 054 |IL: 044 |IR: 004 |DCL: 49:50 |DCR: 72:27 |UB: 08.51V
    P: 050 |VL: 060 |VR: 058 |IL: 044 |IR: 004 |DCL: 49:50 |DCR: 61:38 |UB: 08.51V
    P: 050 |VL: 060 |VR: 042 |IL: 044 |IR: 004 |DCL: 49:50 |DCR: 71:28 |UB: 08.55V
    P: 050 |VL: 060 |VR: 042 |IL: 039 |IR: 003 |DCL: 50:50 |DCR: 71:28 |UB: 08.55V
    P: 050 |VL: 066 |VR: 032 |IL: 035 |IR: 004 |DCL: 50:50 |DCR: 84:15 |UB: 08.59V
    P: 050 |VL: 066 |VR: 032 |IL: 032 |IR: 004 |DCL: 49:50 |DCR: 84:15 |UB: 08.59V
    P: 050 |VL: 071 |VR: 047 |IL: 032 |IR: 004 |DCL: 49:50 |DCR: 70:29 |UB: 08.61V
    P: 050 |VL: 069 |VR: 061 |IL: 031 |IR: 004 |DCL: 50:50 |DCR: 68:31 |UB: 08.61V
    P: 050 |VL: 063 |VR: 054 |IL: 031 |IR: 003 |DCL: 50:50 |DCR: 76:23 |UB: 08.61V
    P: 050 |VL: 063 |VR: 054 |IL: 042 |IR: 004 |DCL: 49:50 |DCR: 76:23 |UB: 08.54V
    P: 050 |VL: 058 |VR: 039 |IL: 042 |IR: 004 |DCL: 49:50 |DCR: 83:16 |UB: 08.54V
    P: 050 |VL: 058 |VR: 038 |IL: 041 |IR: 004 |DCL: 49:50 |DCR: 83:16 |UB: 08.56V
    P: 050 |VL: 058 |VR: 038 |IL: 041 |IR: 004 |DCL: 49:50 |DCR: 76:23 |UB: 08.56V
    P: 050 |VL: 057 |VR: 028 |IL: 042 |IR: 004 |DCL: 49:50 |DCR: 83:16 |UB: 08.54V
    P: 050 |VL: 057 |VR: 028 |IL: 042 |IR: 003 |DCL: 49:50 |DCR: 83:16 |UB: 08.54V
    P: 050 |VL: 057 |VR: 028 |IL: 043 |IR: 004 |DCL: 49:50 |DCR: 89:10 |UB: 08.55V
    P: 050 |VL: 057 |VR: 018 |IL: 042 |IR: 003 |DCL: 49:50 |DCR: 89:10 |UB: 08.55V
    P: 050 |VL: 058 |VR: 028 |IL: 043 |IR: 004 |DCL: 48:51 |DCR: 88:11 |UB: 08.53V
    P: 050 |VL: 058 |VR: 028 |IL: 042 |IR: 003 |DCL: 49:50 |DCR: 88:11 |UB: 08.55V
    P: 050 |VL: 058 |VR: 027 |IL: 041 |IR: 004 |DCL: 49:50 |DCR: 82:17 |UB: 08.55V
    P: 050 |VL: 060 |VR: 029 |IL: 041 |IR: 003 |DCL: 49:50 |DCR: 82:17 |UB: 08.57V
    P: 050 |VL: 060 |VR: 029 |IL: 036 |IR: 004 |DCL: 49:50 |DCR: 77:22 |UB: 08.59V
    P: 050 |VL: 068 |VR: 034 |IL: 032 |IR: 003 |DCL: 49:50 |DCR: 77:22 |UB: 08.59V
    P: 050 |VL: 069 |VR: 034 |IL: 032 |IR: 004 |DCL: 48:51 |DCR: 80:19 |UB: 08.61V
    P: 050 |VL: 072 |VR: 036 |IL: 029 |IR: 003 |DCL: 48:51 |DCR: 80:19 |UB: 08.61V
    P: 050 |VL: 072 |VR: 036 |IL: 029 |IR: 004 |DCL: 50:50 |DCR: 80:19 |UB: 08.59V
    P: 050 |VL: 071 |VR: 036 |IL: 030 |IR: 004 |DCL: 48:51 |DCR: 80:19 |UB: 08.56V
    P: 050 |VL: 060 |VR: 027 |IL: 041 |IR: 004 |DCL: 49:50 |DCR: 86:13 |UB: 08.54V
    P: 050 |VL: 058 |VR: 026 |IL: 043 |IR: 004 |DCL: 49:50 |DCR: 86:13 |UB: 08.55V
    P: 050 |VL: 056 |VR: 028 |IL: 044 |IR: 004 |DCL: 49:50 |DCR: 86:13 |UB: 08.51V
    P: 050 |VL: 056 |VR: 028 |IL: 044 |IR: 004 |DCL: 48:51 |DCR: 86:13 |UB: 08.54V
    P: 050 |VL: 057 |VR: 023 |IL: 044 |IR: 004 |DCL: 48:51 |DCR: 90:09 |UB: 08.54V
    P: 050 |VL: 054 |VR: 022 |IL: 045 |IR: 004 |DCL: 48:51 |DCR: 90:09 |UB: 08.52V
    P: 050 |VL: 055 |VR: 018 |IL: 045 |IR: 004 |DCL: 48:51 |DCR: 89:10 |UB: 08.51V
    P: 050 |VL: 056 |VR: 026 |IL: 044 |IR: 003 |DCL: 49:50 |DCR: 89:10 |UB: 08.51V
    P: 050 |VL: 056 |VR: 023 |IL: 043 |IR: 004 |DCL: 48:51 |DCR: 89:10 |UB: 08.52V
    P: 050 |VL: 060 |VR: 032 |IL: 043 |IR: 004 |DCL: 50:50 |DCR: 89:10 |UB: 08.58V
    P: 050 |VL: 060 |VR: 032 |IL: 036 |IR: 004 |DCL: 50:50 |DCR: 82:17 |UB: 08.57V
    P: 050 |VL: 068 |VR: 033 |IL: 030 |IR: 004 |DCL: 48:51 |DCR: 82:17 |UB: 08.60V
    P: 050 |VL: 072 |VR: 036 |IL: 030 |IR: 003 |DCL: 48:51 |DCR: 79:20 |UB: 08.60V
    P: 050 |VL: 073 |VR: 036 |IL: 028 |IR: 003 |DCL: 48:51 |DCR: 78:21 |UB: 08.62V
    P: 050 |VL: 073 |VR: 036 |IL: 029 |IR: 004 |DCL: 49:50 |DCR: 78:21 |UB: 08.62V
    P: 050 |VL: 072 |VR: 037 |IL: 030 |IR: 004 |DCL: 49:50 |DCR: 74:25 |UB: 08.61V
    Was mir noch aufgefallen ist, dass der Speed am linken antrieb um ca. teilweise 20 schwankt.
    bei test c 50 eingestellt Wert lt. anzeige zwischen 50 und 70.
    am rechten zwischen 30 und 50.
    Bin ich zu doof für den rp6?
    Lg Wesze
    Geändert von Wesze (29.10.2014 um 21:13 Uhr)
    Sorry für die Groß - Kleinschreibung.
    Bin nicht Case sensitive.
  1. Antworten: 14
    Letzter Beitrag: 19.12.2013, 10:22
  2. Neuer Renault Twizy im Test - Kleines Elektroauto mit großem Flirtfaktor
    Letzter Beitrag: 17.07.2012, 12:50
  3. rechte Led geht nicht richtig
    Von jancrombach im Forum Asuro
    Antworten: 14
    Letzter Beitrag: 04.04.2010, 18:30
  4. Rechte Kette bewegt sich nicht
    Von HerrWerWolf im Forum Robby RP6
    Antworten: 12
    Letzter Beitrag: 31.12.2009, 16:54
  5. RP6 dreht nicht genau auf 180 Grad
    Von benx im Forum Robby RP6
    Antworten: 7
    Letzter Beitrag: 06.01.2009, 13:34
