Ergebnis 1 bis 10 von 16
Thema: Make All geht nicht
Baum-Darstellung
    So ok hier einmal das Makefile:
    # Target file name (without extension).
    # This is the name of your main C source file! Do NOT append the ".c"!
    # Example: Let's assume your main source file is "RP6Base_MyProgram.c", then
    # you would write: TARGET = RP6Base_MyProgram
    TARGET = RP6Control_10_Move2_fast
    # Specify relative path to RP6 library files here.
    # This is "../../RP6Lib" or "../RP6Lib" usually.
    RP6_LIB_PATH=../../RP6Lib
    RP6_LIB_PATH_OTHERS= $(RP6_LIB_PATH)/RP6control $(RP6_LIB_PATH)/RP6common
    # Main Source file is _automatically_ added here:
    SRC = $(TARGET).c
    # DO NOT EDIT THIS!
    # If there is more than one source file, append them here separated by spaces.
    # Usually you have to add the Library files here! (ONLY add c files "*.c" here,
    # NO header files "*.h"!)
    # Don't forget to add relative paths!
    SRC += $(RP6_LIB_PATH)/RP6control/RP6ControlLib.c
    SRC += $(RP6_LIB_PATH)/RP6common/RP6uart.c
    # This is the File that we added to this example to make it easier to understand:
    SRC += RP6Control_I2CMasterLib.c
    #SRC += $(RP6_LIB_PATH)/RP6common/RP6I2CslaveTWI.c
    SRC += $(RP6_LIB_PATH)/RP6common/RP6I2CmasterTWI.c
    # You can also wrap lines by appending a backslash to the end of the line
    # like this:
    #SRC += xyz.c \
    #abc.c \
    #asdf.c
    # Optimization level, can be [0, 1, 2, 3, s]. 0 turns off optimization.
    # (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
    OPT = s
    ###### DO NOT EDIT ANYTHING BELOW IF YOU DO NOT KNOW WHAT YOU ARE DOING! ######
    # MCU name - atmega32 for RP6 Base and Processor Expansion
    MCU = atmega32
    # Output format. (can be srec, ihex, binary)
    FORMAT = ihex
    # List Assembler source files here.
    #     Make them always end in a capital .S.  Files ending in a lowercase .s
    #     will not be considered source files but generated files (assembler
    #     output from the compiler), and will be deleted upon "make clean"!
    #     Even though the DOS/Win* filesystem matches both .s and .S the same,
    #     it will preserve the spelling of the filenames, and GCC itself does
    #     care about how the name is spelled on its command-line.
    ASRC =
    # Debugging format.
    #     Native formats for AVR-GCC's -g are dwarf-2 [default] or stabs.
    #     AVR Studio 4.10 requires dwarf-2.
    #     AVR [Extended] COFF format requires stabs, plus an avr-objcopy run.
    DEBUG = dwarf-2
    # List any extra directories to look for include files here.
    #     Each directory must be seperated by a space.
    #     Use forward slashes for directory separators.
    #     For a directory that has spaces, enclose it in quotes.
    EXTRAINCDIRS = $(RP6_LIB_PATH) $(RP6_LIB_PATH_OTHERS)
    # Compiler flag to set the C Standard level.
    #     c89   = "ANSI" C
    #     gnu89 = c89 plus GCC extensions
    #     c99   = ISO C99 standard (not yet fully implemented)
    #     gnu99 = c99 plus GCC extensions
    CSTANDARD = -std=gnu99
    # DO NOT USE THIS FOR RP6 PROJECTS!
    # Processor frequency.
    #     This will define a symbol, F_CPU, in all source code files equal to the
    #     processor frequency. You can then use this symbol in your source code to
    #     calculate timings. Do NOT tack on a 'UL' at the end, this will be done
    #     automatically to create a 32-bit value in your source code.
    # F_CPU = 8000000
    # Place -D or -U options here
    CDEFS =
    # -DF_CPU=$(F_CPU)UL
    # Place -I options here
    CINCS =
    #---------------- Compiler Options ----------------
    #  -g*:          generate debugging information
    #  -O*:          optimization level
    #  -f...:        tuning, see GCC manual and avr-libc documentation
    #  -Wall...:     warning level
    #  -Wa,...:      tell GCC to pass this to the assembler.
    #    -adhlns...: create assembler listing
    CFLAGS = -g$(DEBUG)
    CFLAGS += $(CDEFS) $(CINCS)
    CFLAGS += -O$(OPT)
    CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
    CFLAGS += -Wall -Wstrict-prototypes
    CFLAGS += -Wa,-adhlns=$(<:.c=.lst)
    CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
    CFLAGS += $(CSTANDARD)
    #---------------- Assembler Options ----------------
    #  -ahlms:    create listing
    #  -gstabs:   have the assembler create line number information; note that
    #             for use in COFF files, additional information about filenames
    #             and function names needs to be present in the assembler source
    #             files -- see avr-libc docs [FIXME: not yet described there]
    #  -listing-cont-lines: Sets the maximum number of continuation lines of hex
    #       dump that will be displayed for a given single line of source input.
    ASFLAGS = -Wa,-adhlns=$(<:.S=.lst),-gstabs,--listing-cont-lines=100
    #---------------- Library Options ----------------
    # Minimalistic printf version
    PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
    # Floating point printf version (requires MATH_LIB = -lm below)
    PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
    # If this is left blank, then it will use the Standard printf version.
    PRINTF_LIB =
    #PRINTF_LIB = $(PRINTF_LIB_MIN)
    #PRINTF_LIB = $(PRINTF_LIB_FLOAT)
    # Minimalistic scanf version
    SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
    # Floating point + %[ scanf version (requires MATH_LIB = -lm below)
    SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
    # If this is left blank, then it will use the Standard scanf version.
    SCANF_LIB =
    #SCANF_LIB = $(SCANF_LIB_MIN)
    #SCANF_LIB = $(SCANF_LIB_FLOAT)
    MATH_LIB = -lm
    #---------------- External Memory Options ----------------
    # 64 KB of external RAM, starting after internal RAM (ATmega128!),
    # used for variables (.data/.bss) and heap (malloc()).
    #EXTMEMOPTS = -Wl,--section-start,.data=0x801100,--defsym=__heap_end=0x80ffff
    # only used for heap (malloc()).
    #EXTMEMOPTS = -Wl,--defsym=__heap_start=0x801100,--defsym=__heap_end=0x80ffff
    EXTMEMOPTS =
    #---------------- Linker Options ----------------
    #  -Wl,...:     tell GCC to pass this to linker.
    #    -Map:      create map file
    #    --cref:    add cross reference to  map file
    LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
    LDFLAGS += $(EXTMEMOPTS)
    LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
    #---------------- Programming Options (avrdude) ----------------
    # Programming hardware: alf AVR910 avrisp Bascom bsd
    # dt006 pavr picoweb pony-stk200 sp12 stk200 stk500
    # Type: avrdude -c ?
    # to get a full listing.
    AVRDUDE_PROGRAMMER = stk500
    # com1 = serial port. Use lpt1 to connect to parallel port.
    AVRDUDE_PORT = com1    # Programmer connected to serial device
    AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
    #AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
    # Uncomment the following if you want avrdude's erase cycle counter.
    # Note that this counter needs to be initialized first using -Yn,
    # see avrdude manual.
    #AVRDUDE_ERASE_COUNTER = -y
    # Uncomment the following if you do /not/ wish a verification to be
    # performed after programming the device.
    #AVRDUDE_NO_VERIFY = -V
    # Increase verbosity level.  Please use this when submitting bug
    # reports about avrdude. See <http://savannah.nongnu.org/projects/avrdude>
    # to submit bug reports.
    #AVRDUDE_VERBOSE = -v -v
    AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
    AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
    AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
    AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
    #---------------- Debugging Options ----------------
    # For simulavr only - target MCU frequency.
    DEBUG_MFREQ = $(F_CPU)
    # Set the DEBUG_UI to either gdb or insight.
    # DEBUG_UI = gdb
    DEBUG_UI = insight
    # Set the debugging back-end to either avarice, simulavr.
    DEBUG_BACKEND = avarice
    #DEBUG_BACKEND = simulavr
    # GDB Init Filename.
    GDBINIT_FILE = __avr_gdbinit
    # When using avarice settings for the JTAG
    JTAG_DEV = /dev/com1
    # Debugging port used to communicate between GDB / avarice / simulavr.
    DEBUG_PORT = 4242
    # Debugging host used to communicate between GDB / avarice / simulavr, normally
    #     just set to localhost unless doing some sort of crazy debugging when
    #     avarice is running on a different computer.
    DEBUG_HOST = localhost
    # Define programs and commands.
    SHELL = sh
    CC = avr-gcc
    OBJCOPY = avr-objcopy
    OBJDUMP = avr-objdump
    SIZE = avr-size
    NM = avr-nm
    AVRDUDE = avrdude
    REMOVE = rm -f
    REMOVEDIR = rmdir
    COPY = cp
    WINSHELL = cmd
    # Define Messages
    # English
    MSG_ERRORS_NONE = Errors: none
    MSG_BEGIN = -------- begin --------
    MSG_END = --------  end  --------
    MSG_SIZE_BEFORE = Size before:
    MSG_SIZE_AFTER = Size after:
    MSG_COFF = Converting to AVR COFF:
    MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
    MSG_FLASH = Creating load file for Flash:
    MSG_EEPROM = Creating load file for EEPROM:
    MSG_EXTENDED_LISTING = Creating Extended Listing:
    MSG_SYMBOL_TABLE = Creating Symbol Table:
    MSG_LINKING = Linking:
    MSG_COMPILING = Compiling:
    MSG_ASSEMBLING = Assembling:
    MSG_CLEANING = Cleaning project:
    # Define all object files.
    OBJ = $(SRC:.c=.o) $(ASRC:.S=.o)
    # Define all listing files.
    LST = $(SRC:.c=.lst) $(ASRC:.S=.lst)
    # Compiler flags to generate dependency files.
    GENDEPFLAGS = -MD -MP -MF .dep/$(@F).d
    # Combine all necessary flags and optional flags.
    # Add target processor to flags.
    ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
    ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
    # Default target.
    all: begin gccversion sizebefore build sizeafter end
    build: elf hex lss sym
    #eep
    # EEPROM File will not be build!
    elf: $(TARGET).elf
    hex: $(TARGET).hex
    #eep: $(TARGET).eep
    lss: $(TARGET).lss
    sym: $(TARGET).sym
    # Eye candy.
    # AVR Studio 3.x does not check make's exit code but relies on
    # the following magic strings to be generated by the compile job.
    begin:
    	@echo
    	@echo $(MSG_BEGIN)
    end:
    	@echo $(MSG_END)
    	@echo
    # Display size of file.
    HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
    ELFSIZE = $(SIZE) --format=avr --mcu=$(MCU) $(TARGET).elf
    sizebefore:
    	@if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \
    	2>/dev/null; echo; fi
    sizeafter:
    	@if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \
    # Display compiler version information.
    gccversion :
    	@$(CC) --version
    # Program the device.
    program: $(TARGET).hex $(TARGET).eep
    	$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
    # Generate avr-gdb config/init file which does the following:
    #     define the reset signal, load the target file, connect to target, and set
    #     a breakpoint at main().
    gdb-config:
    	@$(REMOVE) $(GDBINIT_FILE)
    	@echo define reset >> $(GDBINIT_FILE)
    	@echo SIGNAL SIGHUP >> $(GDBINIT_FILE)
    	@echo end >> $(GDBINIT_FILE)
    	@echo file $(TARGET).elf >> $(GDBINIT_FILE)
    	@echo target remote $(DEBUG_HOST):$(DEBUG_PORT)  >> $(GDBINIT_FILE)
    ifeq ($(DEBUG_BACKEND),simulavr)
    	@echo load  >> $(GDBINIT_FILE)
    endif
    	@echo break main >> $(GDBINIT_FILE)
    debug: gdb-config $(TARGET).elf
    ifeq ($(DEBUG_BACKEND), avarice)
    	@echo Starting AVaRICE - Press enter when "waiting to connect" message displays.
    	@$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \
    	$(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT)
    	@$(WINSHELL) /c pause
    else
    	@$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \
    	$(DEBUG_MFREQ) --port $(DEBUG_PORT)
    endif
    	@$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE)
    # Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
    COFFCONVERT=$(OBJCOPY) --debugging \
    --change-section-address .data-0x800000 \
    --change-section-address .bss-0x800000 \
    --change-section-address .noinit-0x800000 \
    --change-section-address .eeprom-0x810000
    coff: $(TARGET).elf
    	@echo
    	@echo $(MSG_COFF) $(TARGET).cof
    	$(COFFCONVERT) -O coff-avr $< $(TARGET).cof
    extcoff: $(TARGET).elf
    	@echo
    	@echo $(MSG_EXTENDED_COFF) $(TARGET).cof
    	$(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
    # Create final output files (.hex, .eep) from ELF output file.
    %.hex: %.elf
    	@echo
    	@echo $(MSG_FLASH) $@
    	$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
    #%.eep: %.elf
    #	@echo
    #	@echo $(MSG_EEPROM) $@
    #	-$(OBJCOPY) -j .eeprom --set-section-flags .eeprom=alloc,load \
    #	--change-section-lma .eeprom=0 -O $(FORMAT) $< $@
    # Create extended listing file from ELF output file.
    %.lss: %.elf
    	@echo
    	@echo $(MSG_EXTENDED_LISTING) $@
    	$(OBJDUMP) -h -S $< > $@
    # Create a symbol table from ELF output file.
    %.sym: %.elf
    	@echo
    	@echo $(MSG_SYMBOL_TABLE) $@
    	$(NM) -n $< > $@
    # Link: create ELF output file from object files.
    .SECONDARY : $(TARGET).elf
    .PRECIOUS : $(OBJ)
    %.elf: $(OBJ)
    	@echo
    	@echo $(MSG_LINKING) $@
    	$(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS)
    # Compile: create object files from C source files.
    %.o : %.c
    	@echo
    	@echo $(MSG_COMPILING) $<
    	$(CC) -c $(ALL_CFLAGS) $< -o $@
    # Compile: create assembler files from C source files.
    %.s : %.c
    	$(CC) -S $(ALL_CFLAGS) $< -o $@
    # Assemble: create object files from assembler source files.
    %.o : %.S
    	@echo
    	@echo $(MSG_ASSEMBLING) $<
    	$(CC) -c $(ALL_ASFLAGS) $< -o $@
    # Create preprocessed source for use in sending a bug report.
    %.i : %.c
    	$(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@
    # Target: clean project.
    clean: begin clean_list end
    clean_list :
    	@echo
    	@echo $(MSG_CLEANING)
    # We want to keep the generated hexfiles:
    #	$(REMOVE) $(TARGET).hex
    #	$(REMOVE) $(TARGET).eep
    	$(REMOVE) $(TARGET).cof
    	$(REMOVE) $(TARGET).elf
    	$(REMOVE) $(TARGET).map
    	$(REMOVE) $(TARGET).sym
    	$(REMOVE) $(TARGET).lss
    	$(REMOVE) $(OBJ)
    	$(REMOVE) $(LST)
    	$(REMOVE) $(SRC:.c=.s)
    	$(REMOVE) $(SRC:.c=.d)
    	$(REMOVE) $(SRC:.c=.i)
    	$(REMOVE) .dep/*
    	$(REMOVEDIR) .dep
    # Include the dependency files.
    include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
    # Listing of phony targets.
    .PHONY : all begin finish end sizebefore sizeafter gccversion \
    build elf hex lss sym coff extcoff \
    clean clean_list program debug gdb-config
    # Based on WinAVR Sample makefile written by Eric B. Weddington,
    # Jörg Wunsch, et al.
    # Released to the Public Domain.
    # Please read the "make" user manual!
    # On command line:
    # make all = Make software.
    # make clean = Clean out built project files.
    # make coff = Convert ELF to AVR COFF.
    # make extcoff = Convert ELF to AVR Extended COFF.
    # make program = Download the hex file to the device, using avrdude.
    #                Please customize the avrdude settings first!
    # make debug = Start either simulavr or avarice as specified for debugging,
    #              with avr-gdb or avr-insight as the front end for debugging.
    # make filename.s = Just compile filename.c into the assembler code only.
    # make filename.i = Create a preprocessed source file for use in submitting
    #                   bug reports to the GCC project.
    # To rebuild project do "make clean" then "make all".
    Hier der fehler:
    > "C:\Users\Stephan\Desktop\RP6\RP6EigeneProgramme\EigneProgramme\M32ControlProgramme\Move_geändert2\\make_all.bat"
    C:\Users\Stephan\Desktop\RP6\RP6EigeneProgramme\EigneProgramme\M32ControlProgramme\Move_ge„ndert2>set LANG=C
    C:\Users\Stephan\Desktop\RP6\RP6EigeneProgramme\EigneProgramme\M32ControlProgramme\Move_ge„ndert2>make all
    avr-gcc (WinAVR 20100110) 4.3.3
    Copyright (C) 2008 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    make: *** No rule to make target `RP6Control_10_Move2_fast.elf', needed by `elf'.  Stop.
    > Prozess beendet. Code:2
    > Dauer:00:01
    Geändert von StGla90 (27.09.2014 um 15:40 Uhr)
  1. Make geht gar nicht mehr
    Von asurer im Forum Asuro
    Letzter Beitrag: 27.07.2014, 17:50
  2. Antworten: 3
    Letzter Beitrag: 23.07.2013, 08:28
  3. RP6: Linux make geht nicht
    Von TedRobby im Forum Robby RP6
    Antworten: 7
    Letzter Beitrag: 12.08.2007, 18:50
  4. make all funktioniert nicht.....
    Von blabla im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 22.06.2007, 08:33
  5. make-tool funktioniert nicht
    Von upaucc im Forum Asuro
    Antworten: 15
    Letzter Beitrag: 27.11.2006, 20:37
