Hallo Leute,
versuche mich gerade daran das Signal eines DCF77-Moduls von Reichelt auszuwerten und die aktuelle Zeit per serielle Schnittstelle an einen Computer zu senden. Am PC empfange ich auch etwas, nur leider nicht die aktuelle Zeit. Er zählt einfach die Sekunden hoch und zeigt mir den aktuellen Stand an. Hier mal die main-Datei und die Dtaei in welcher das Signal ausgewertet wird:
Code:/* * main.c * * Created: 27.02.2014 13:27:29 * Author: Jens * * This program receives the DCF77 signal from a DCF77-Module from Reichelt and evaluates the * received data. The calculated time will be transmitted to a computer via UART. The program * is written for an ATmega32 device * */ #include "global.h" #include "uart.h" #include "DCF77.h" #include <avr/io.h> #include <avr/interrupt.h> #include <util/delay.h> #include <stdio.h> #include <string.h> int main(void) { char msgBuffer[100]; // Initialize the UART-Interface with 4800 baud init_UART(4800); strcpy(msgBuffer, "*********** DCF77-Clock **************\n"); uart_write_msg(msgBuffer,strlen(msgBuffer)); // Enable global interrupts sei(); // Start DCF77 clock strcpy(msgBuffer, "Starting clock..."); uart_write_msg(msgBuffer,strlen(msgBuffer)); Start_Clock(); strcpy(msgBuffer, "Done\n"); uart_write_msg(msgBuffer,strlen(msgBuffer)); while(1) { // Transmit actual time to the computer sprintf(msgBuffer, "Time: %i:%i:%i \n", hh, mm, ss); uart_write_msg(msgBuffer,strlen(msgBuffer)); // Wait _delay_ms(1000); } return 0; }Und der Header zur Signalauswertung:Code:/* * main.c * * Created: 27.02.2014 00:10:17 * Author: Jens * * This file includes control functions for the use of a DCF77 module from Reichelt * */ #include "DCF77.h" #include "global.h" #include <avr/io.h> #include <avr/interrupt.h> volatile unsigned char ss = 0; // Seconds volatile unsigned char mm = 0; // Minutes volatile unsigned char hh = 0; // Hours // Bit-counter for RX bit volatile unsigned char rx_bit_counter = 0; // 64 Bit, for DCF77 used 59 Bits volatile unsigned long long dcf_rx_buffer = 0; // Help-counter for seconds volatile unsigned int h_ss = 0; // Help-variable for hour-change volatile unsigned int h_hh = 0; // Timer1 overflow Interrupt, triggered by 59. second or no received DCF77 signal ISR(TIMER1_OVF_vect) { struct DCF77_Bits *rx_buffer; rx_buffer = (struct DCF77_Bits*)(char*)&dcf_rx_buffer; // Reset timer TCNT1 = 65535 - (F_CPU / 1024); // If all 59 Bits and the parity's are correctly received, set clock to DCF77 signal if ((rx_bit_counter == 59) && (flags.parity_P1 == rx_buffer->P1) && (flags.parity_P2 == rx_buffer->P2) && (flags.parity_P3 == rx_buffer->P3)) { // Calculate minutes BCD to HEX mm = rx_buffer->Min - ((rx_buffer->Min / 16) * 6); if(mm != 0) { mm--; } else { mm = 59; h_hh = 1; } // Calculate hours BCD to HEX hh = rx_buffer->Hour - ((rx_buffer->Hour / 16) * 6); if(h_hh) { hh--; h_hh = 0; } // Reset seconds to zero ss = 59; flags.dcf_sync = 1; } else { // Manually set the clock Add_one_Second(); flags.dcf_sync = 0; } // Reset the RX Bit-Counter rx_bit_counter = 0; // Clear the RX buffer dcf_rx_buffer = 0; } // Interrupt on INT0, DCF77 Module receives time information ISR(INT0_vect) { // Evaluate pulse width if(INT0_CONTROL == INT0_RISING_EDGE) { flags.dcf_rx ^= 1; // Calculate second help-counter h_ss = h_ss + TCNT1 - (65535 - (F_CPU / 1024)); // Reset timer TCNT1 = 65535 - (F_CPU / 1024); // Check if a second is over if(h_ss > (F_CPU / 1024 / 100 * 90)) //90% from 1 second { Add_one_Second(); // Reset second help-counter h_ss = 0; } // Next interrupt with falling edge INT0_CONTROL = INT0_FALLING_EDGE; } else { // Read pulse width from rising edge to falling edge unsigned int pulse_wide = TCNT1; // Reset timer TCNT1 = 65535 - (F_CPU / 1024); // Calculate second help-counter h_ss = h_ss + pulse_wide - (65535 - (F_CPU / 1024)); //Safe parity: // Begin area P1/P2/P3 if((rx_bit_counter == 21) || (rx_bit_counter == 29) || (rx_bit_counter == 36)) { flags.parity_err = 0; } // Safe P1 if(rx_bit_counter == 28) { flags.parity_P1 = flags.parity_err; } //Safe P2 if(rx_bit_counter == 35) { flags.parity_P2 = flags.parity_err; } //Safe P3 if(rx_bit_counter == 58) { flags.parity_P3 = flags.parity_err; } // Check if a 0 or 1 is received //0 = 100 ms //1 = 200 ms // > 150ms (15% from 1 second -> 150ms) if(pulse_wide > (65535 - (F_CPU / 1024) / 100 * 85)) { // Write a 1 into the dcf_rx_buffer at position rx_bit_counter dcf_rx_buffer = dcf_rx_buffer | ((unsigned long long) 1 << rx_bit_counter); //Toggle Help-Parity flags.parity_err = flags.parity_err ^ 1; } // Next interrupt with rising edge INT0_CONTROL = INT0_RISING_EDGE; // Inkrement RX Bit-Counter rx_bit_counter++; } } // Function to add a second to the actual time value void Add_one_Second (void) { ss++; // Check if a minute is done if (ss == 60) { ss = 0; mm++; // Check if a hour is done if (mm == 60) { mm = 0; hh++; // Check if the day is finished if (hh == 24) { hh = 0; } } } }; // Function to initialize and start the timer void Start_Clock (void) { // Enable interrupt on DCF77 with rising edge DCF77_INT_ENABLE(); INT0_CONTROL = INT0_RISING_EDGE; // Interrupt overflow enable TIMSK1 |= (1 << TOIE1); // Set prescaler to 1024 TCCR1B |= (1<<CS10 | 0<<CS11 | 1<<CS12); TCNT1 = 65535 - (F_CPU / 1024); }
Ich hoffe ihr könnt mir weiterhelfenCode:/* * DCF77.h * * Created: 27.02.2014 10:20:46 * Author: Jens */ #ifndef DCF77_H_ #define DCF77_H_ volatile unsigned char ss; // Seconds volatile unsigned char mm; // Minutes volatile unsigned char hh; // Hours extern void Start_Clock (void); // Function to start the DCF77-Clock extern void Add_one_Second (void); // Function to add one second to the actual time // 64 Bit, for DCF77 used 59 Bits volatile unsigned long long dcf_rx_buffer; // RX Pointer (Counter) volatile extern unsigned char rx_bit_counter; // Help-Counter for seconds volatile unsigned int h_ss; // INT0 Interrupt definitions #define DCF77_INT_ENABLE() GICR |= (1<<INT0); #define INT0_CONTROL MCUCR #define INT0_FALLING_EDGE 0x02 #define INT0_RISING_EDGE 0x03 #define TIMSK1 TIMSK //Structure of the dcf_rx_buffer struct DCF77_Bits { unsigned char M :1 ; unsigned char O1 :1 ; unsigned char O2 :1 ; unsigned char O3 :1 ; unsigned char O4 :1 ; unsigned char O5 :1 ; unsigned char O6 :1 ; unsigned char O7 :1 ; unsigned char O8 :1 ; unsigned char O9 :1 ; unsigned char O10 :1 ; unsigned char O11 :1 ; unsigned char O12 :1 ; unsigned char O13 :1 ; unsigned char O14 :1 ; unsigned char R :1 ; unsigned char A1 :1 ; unsigned char Z1 :1 ; unsigned char Z2 :1 ; unsigned char A2 :1 ; unsigned char S :1 ; unsigned char Min :7 ;// 7 Bits for minutes unsigned char P1 :1 ;// Parity minutes unsigned char Hour :6 ;// 6 Bits for hours unsigned char P2 :1 ;// Parity hours unsigned char P3 :1 ;// Parity from P2 }; struct { volatile char parity_err :1 ;// Help Parity volatile char parity_P1 :1 ;// Calculated Parity P1 volatile char parity_P2 :1 ;// Calculated Parity P2 volatile char parity_P3 :1 ;// Calculated Parity P3 volatile char dcf_rx :1 ;// A impulse is received volatile char dcf_sync :1 ;// The clock was synchronized in the last minute }flags; #endif /* DCF77_H_ */![]()
Mister232
Zitieren
