Der TSL45315 ist ein Lichtsensor der über I2C die Werte (16Bit) direkt in Lux ausgibt .
Ein Breakout ist bei Watterott erhältlich : http://www.watterott.com/de/TSL45315-Breakout
Das Datenblatt z.B. hier : http://media.digikey.com/pdf/Data%20...Fs/TSL4531.pdf
Code:'------------------------------------------------------------------------------ 'Demo TSL 45315 (DIGITAL AMBIENT LIGHT SENSOR) 'Watterott Breakout > http://www.watterott.com/de/TSL45315-Breakout 'ATMega88 '------------------------------------------------------------------------------ $regfile = "m88def.dat" $crystal = 8000000 $baud = 19200 Config Sda = Portc.4 ' I2C Data Config Scl = Portc.5 ' I2C Clock I2Cinit '********************************************************************** Config Lcdpin = Pin , Db4 = Portd.4 , Db5 = Portd.5 , Db6 = Portd.6 , Db7 = Portd.7 , E = Portb.5 , Rs = Portb.4 Config Lcd = 16 * 2 Initlcd Cls Dim adress_w As Byte adress_w = &H52 'Write Adress Dim adress_r As Byte adress_r = &H53 'Read Adress Dim Lux As Long Dim Rohdaten As Word Dim Lsb As Byte at Rohdaten overlay Dim Msb As Byte at Rohdaten + 1 overlay Dim Temp$ As String * 32 '______________________________________________________________________________ I2cstart 'Initialisieren I2cwbyte adress_w I2cwbyte &H80 'Command Adresse 0 = Control I2cwbyte &H03 'Control= &H11 = Normal Operation I2cstart I2cwbyte adress_w I2cwbyte &H81 'Command Adresse 1 = Configuration Register I2cwbyte &H01 'Configuration Register= &H01 = Multiplier x2 I2cstop Waitms 500 'Multiplier x1=480ms / x2=240ms / x4=120ms '______________________________________________________________________________ Do I2cstart I2cwbyte adress_w 'Daten holen I2cwbyte &H84 'Command Adresse 4 = Data LOW Register I2cstart I2cwbyte adress_r I2crbyte Lsb , Ack 'LSB und acknowledge I2crbyte Msb , Ack 'MSB und acknowledge I2cstop upperline Lux = Rohdaten * 2 Temp$ = str(Lux) lcd Temp$ ; " Lux " lowerline Temp$ = str(Rohdaten) + " " lcd Temp$ Waitms 500 'Multiplier x1=480ms / x2=240ms / x4=120ms Loop '______________________________________________________________________________ End
Zitieren
