Seite 5 von 5 ErsteErste ... 345
Ergebnis 41 bis 43 von 43
Thema: strukturen, ein- und ausstieg
  1. #41
    nahe Dresden
    hallo,
    eine lösung für den rücksprung aus dem jeweiligen zweig der programmstruktur - was ja der ursprung des threads war - habe ich nun für mich gefunden:
    #include "RP6ControlLib.h"
    #include "RP6I2CmasterTWI.h"
    #include "RP6Control_MultiIOLib.h"
    #include "RP6Control_I2CMasterLib.h"
    #include "RP6ControlServoLib.h"
    #include "RP6Control_OrientationLib.h"
    #define I2C_RP6_BASE_ADR 10
    // Variables:
    uint8_t ch;
    char item[12];
    char dir[3];
     * Returns a 2 character string for the eighth
     * parts of the direction calculated from the
     * heading value.
     * Input: heading -> Heading value [0..359]
    void calculateDir(char *dir, uint16_t heading)
        dir[1] = ' ';
        dir[2] = '\0';
        if ((heading <= 22) || (heading >=338)) dir[0] = 'N';
        if ((heading >= 23) && (heading <= 67)) {dir[0] = 'N'; dir[1] = 'E';}
        if ((heading >= 68) && (heading <= 112)) dir[0] = 'E';
        if ((heading >= 113) && (heading <= 157)) {dir[0] = 'S'; dir[1] = 'E';}
        if ((heading >= 158) && (heading <= 202)) dir[0] = 'S';
        if ((heading >= 203) && (heading <= 247)) {dir[0] = 'S'; dir[1] = 'W';}
        if ((heading >= 248) && (heading <= 292)) dir[0] = 'W';
        if ((heading >= 293) && (heading <= 337)) {dir[0] = 'N'; dir[1] = 'W';}
    /******************Write a floating point number to the LCD and terminal***********************/
     * Example:
     *            // Write a floating point number to the LCD (no exponent):
     *            writeDoubleLCD(1234567.890, 11, 3);
     * The value of prec (precision) defines the number of decimal places.
     * For 32 bit floating point variables (float, double ...) 6 is
     * the max. value for prec (7 relevant digits).
     * The value of width defines the overall number of characters in the
     * floating point number including the decimal point. The number of
     * pre-decimal positions is: (width - prec - 1).
    void writeDoubleLCD(double number, uint8_t width, uint8_t prec)
    {char buffer[width + 1];
        dtostrf(number, width, prec, &buffer[0]);
        writeStringLCD(&buffer[0]);
    void writeDouble(double number, uint8_t width, uint8_t prec)
        writeString(&buffer[0]);
    /*********************I2C-fehlermeldungen******************/
    void I2C_transmissionError(uint8_t errorState) //gibt I2C fehlermeldungen über LCD aus
        clearLCD();
        writeStringLCD_P("I2C ERROR -->");
        setCursorPosLCD(1, 0);        // line 2
        writeStringLCD_P("TWI STATE: 0x");
        writeIntegerLCD(errorState, HEX);
    /*****************gyroscope***************/
    void gyroscope(void) //  L3GD20 gyroscope
        mSleep(1000);
        task_I2CTWI();
        readL3GD20();                        // Get sensor values
    //    normalizeL3GD20();
        task_I2CTWI();
        clearLCD();
        setCursorPosLCD(0, 0);        // line 1
        writeStringLCD_P("X");
        writeIntegerLCD(x_axisg, DEC);
        setCursorPosLCD(0, 6);        // line 1 pos 6
        writeStringLCD_P("Y");
        writeIntegerLCD(y_axisg, DEC);
        setCursorPosLCD(0, 12);        // line1 pos 12
        writeStringLCD_P("Z");
        writeIntegerLCD(z_axisg, DEC);
    //    setCursorPosLCD(1, 0);        // line 2
    //    writeStringLCD_P("X");
        writeString_P("x: ");
        writeDouble(xg, 1, 1);
        writeString_P("\n");
    /*    setCursorPosLCD(1, 6);        // line 2 pos 6
        writeIntegerLCD(yg, DEC);
        setCursorPosLCD(1, 12);        // line 2 pos 12
        writeIntegerLCD(zg, DEC);*/
    /*        setServoPower(1);
            initSERVO(SERVO1);
            setServo(1, SERVO1_LT);
            mSleep(50);
            setServo(1, SERVO1_RT);
            mSleep(100);
            setServoPower(0);
            task_SERVO();
    #ifdef GET_TEMP
        temperatureg = calcTempL3GD20(temperatureg) + 5;
        temperatureg += OFFSET_TEMP;
        setCursorPosLCD(1, 8);        // line 2 pos 9
        writeStringLCD_P("T");
        writeIntegerLCD(temperatureg, DEC);
        writeStringLCD_P("    ");
    #endif
        mSleep(2000);//3 sec
        clearLCD();
        task_I2CTWI();
    /************accelerometer****************/
       void accelerometer(void) //  LSM303DLHC accelerometer
        mSleep(1000);
        task_I2CTWI();
        readLSM303DLHC_A();                    // Get sensor values
    //    normalizeLSM303DLHC_A();
        task_I2CTWI();
        writeIntegerLCD(x_axisa, DEC);
        setCursorPosLCD(0, 5);        // line 1 pos 6
        writeIntegerLCD(y_axisa, DEC);
        setCursorPosLCD(0, 10);        // line 1 pos 11
        writeIntegerLCD(z_axisa, DEC);
    //    normalizeLSM303DLHC_A();            // Normalize data
        positionLSM303DLHC_A();                // Calculate position
        writeStringLCD_P("P");
        writeDoubleLCD(pitch, 6, 1);
        writeStringLCD_P("R");
        writeDoubleLCD(roll, 6, 1);
        mSleep(2000);
        clearLCD();
        task_I2CTWI();
    /*****************magnetometer************/
    void magnetometer(void) //  LSM303DLHC magnetometer
        mSleep(1000);
        task_I2CTWI();
        readLSM303DLHC_M();                    // Get sensor values
    //    normalizeLSM303DLHC_M();
        task_I2CTWI();
        writeIntegerLCD(x_axism, DEC);
        writeIntegerLCD(y_axism, DEC);
    #ifndef GET_TEMP_M
        writeStringLCD_P(" Z");
        writeIntegerLCD(z_axism, DEC);
    #else
        temperature_imu = (double) temperaturem / 8.0 + OFFSET_TEMP_M;
        writeDoubleLCD(temperature_imu, 5, 1);
    #endif
    //    normalizeLSM303DLHC_M();            // Normalize data
        headingm = headingLSM303DLHC_M();    // Calculate heading
        calculateDir(dir, headingm);
        writeStringLCD_P("H");
        writeIntegerLengthLCD(headingm, DEC, 3);
        writeStringLCD(dir);
        headingtc = headingLSM303DLHC_TC();    // Calculate TILT COMPENSATED
        calculateDir(dir, headingtc);        // heading
        writeStringLCD_P(" C");
        writeIntegerLengthLCD(headingtc, DEC, 3);
        mSleep(1000);
    //    clearLCD();
        task_I2CTWI();
    /*************** hauptprogramm ***********/
    int main(void)
    initRP6Control();
    multiio_init();
    initLCD();
    //orientation_init();
    setLEDs(0b1111);
    mSleep(500);
    setLEDs(0b0000);
    I2CTWI_initMaster(100);
    I2CTWI_setTransmissionErrorHandler(I2C_transmissionError); //aktiviert I2C fehlermeldungen
    showScreenLCD(" RP6Control M32", " calibrate_imu");
    mSleep(2500);
    clearLCD();
    orientation_init();
    while(true)
    /*****************anzeige gedrückter buttons****************/
        clearLCD();
        pressedMultiIOButtonNumber = getMultiIOPressedButtonNumber();
        writeStringLCD("Button: ");
        writeIntegerLCD(pressedMultiIOButtonNumber, DEC);
        mSleep(500);
        uint8_t key = getMultiIOPressedButtonNumber();
    /********************funktion der buttons*********************/
        if(key)
        switch(key)
        case 1://
        setLEDs(0b0001);
        while(true)
        setLEDs(0b0001);
        gyroscope();
        mSleep(500);
        clearLCD();
        uint8_t key_1 = getMultiIOPressedButtonNumber();
        if(key_1 != 0)
        break;
        break;
        case 2://
        setLEDs(0b0010);
        while(true)
        setLEDs(0b0010);
        accelerometer();
        mSleep(500);
        clearLCD();
        if(key_1 != 0)
        break;
        break;
        case 3://
        setLEDs(0b0100);
        while(true)
        magnetometer();
        mSleep(50);
        clearLCD();
        if(key_1 != 0)
        break;
        break;
        case 4://
        setLEDs(0b1000);
        while(true)
        setLEDs(0b1000);
        gyroscope();
        mSleep(50);
        clearLCD();
        accelerometer();
        mSleep(50);
        clearLCD();
        magnetometer();
        mSleep(50);
        clearLCD();
        if(key_1 != 0)
        break;
        break;
        return 0;
    damit kann ich jetzt z.b. den 3D-gyro (und seine einzelnen komponenten) testen und werte überprüfen ohne unnütz warten zu müssen bis nun die erwünschte einzelfunktion wiederkommt...
    nochmals dank an alle die mir hierbei geholfen haben...
    gruß inka
  2. #42
    DE
    Zur Lösung willst du keine 3 Wörter schreiben, aber jetzt schreibst du doch auf einmal nen halben Roman
    Besser du machst es das nächste mal gleich am Anfang mit der Lösung, dann können wir uns ein paar Seiten sparen Bild
    Und was soll jetzt der Grundkurs in C?? Hab ich alles schon 100x gehört und wer es nicht weis, kann es auch schnell selbst googlen. Das ist keine Kunst, es ist eher eine Schande wenn man es als C-Programmierer nicht weiß.
    Da für mich die STL zu C gehört, gehört auch uint8_t für mich dazu! Wie der implementiert ist, ist für mich relativ egal.
    Dies gilt scheinbar nur bei dem verwendeten Compiler und den, bzw. die verwendeten Bibliotheken, kenne ich (noch) nicht, da ich bisher nicht mit dem AVR gearbeitet habe.
    Ähm nein?! stdint.h gibts bei eigentlich jedem Compiler. Wenn man portablen Sourcecode erstellen will, sollte man sogar stdint verwenden, da ein integer je nach System anders ist.
  3. #43
    nahe Dresden
    so jetzt machen wir hier schluss
    gruß inka
  1. Antworten: 2
    Letzter Beitrag: 23.03.2012, 22:36
  2. Probleme feine Strukturen zu drucken für Platine
    Von Hellmut im Forum Konstruktion/CAD/3D-Druck/Sketchup und Platinenlayout Eagle & Fritzing u.a.
    Antworten: 12
    Letzter Beitrag: 20.12.2010, 13:35
  3. Antworten: 11
    Letzter Beitrag: 07.09.2008, 16:56
  4. Probleme bei Strukturen (Projekt Funkuhr)
    Von Wasserkäfer im Forum C - Programmierung (GCC u.a.)
    Antworten: 9
    Letzter Beitrag: 19.07.2008, 15:10
  5. Ein Quarz für ein ATMEGA8 und ein ATMEGA16
    Von boeseTURBO-CT im Forum AVR Hardwarethemen
    Letzter Beitrag: 14.06.2004, 16:07
