Hi, Ich versuche gerade mit der eclipse IDE für java, die Kommunikation zu meinen Arduino aufzubauen...
http://playground.arduino.cc/Interfacing/Java
Das klappt auch, aber wie lese ich nun Daten von einem Sensor auf den Analog-Port A0 aus?Code:import java.io.BufferedReader; import java.io.InputStreamReader; import java.io.OutputStream; import gnu.io.CommPortIdentifier; import gnu.io.SerialPort; import gnu.io.SerialPortEvent; import gnu.io.SerialPortEventListener; import java.util.Enumeration; public class SerialTest implements SerialPortEventListener { SerialPort serialPort; /** The port we're normally going to use. */ private static final String PORT_NAMES[] = { "/dev/tty.usbserial-A9007UX1", // Mac OS X "/dev/ttyUSB0", // Linux "COM3", // Windows }; /** * A BufferedReader which will be fed by a InputStreamReader * converting the bytes into characters * making the displayed results codepage independent */ private BufferedReader input; /** The output stream to the port */ private OutputStream output; /** Milliseconds to block while waiting for port open */ private static final int TIME_OUT = 2000; /** Default bits per second for COM port. */ private static final int DATA_RATE = 9600; public void initialize() { CommPortIdentifier portId = null; Enumeration portEnum = CommPortIdentifier.getPortIdentifiers(); //First, Find an instance of serial port as set in PORT_NAMES. while (portEnum.hasMoreElements()) { CommPortIdentifier currPortId = (CommPortIdentifier) portEnum.nextElement(); for (String portName : PORT_NAMES) { if (currPortId.getName().equals(portName)) { portId = currPortId; break; } } } if (portId == null) { System.out.println("Could not find COM port."); return; } try { // open serial port, and use class name for the appName. serialPort = (SerialPort) portId.open(this.getClass().getName(), TIME_OUT); // set port parameters serialPort.setSerialPortParams(DATA_RATE, SerialPort.DATABITS_8, SerialPort.STOPBITS_1, SerialPort.PARITY_NONE); // open the streams input = new BufferedReader(new InputStreamReader(serialPort.getInputStream())); output = serialPort.getOutputStream(); // add event listeners serialPort.addEventListener(this); serialPort.notifyOnDataAvailable(true); } catch (Exception e) { System.err.println(e.toString()); } } /** * This should be called when you stop using the port. * This will prevent port locking on platforms like Linux. */ public synchronized void close() { if (serialPort != null) { serialPort.removeEventListener(); serialPort.close(); } } /** * Handle an event on the serial port. Read the data and print it. */ public synchronized void serialEvent(SerialPortEvent oEvent) { if (oEvent.getEventType() == SerialPortEvent.DATA_AVAILABLE) { try { String inputLine=input.readLine(); System.out.println(inputLine); } catch (Exception e) { System.err.println(e.toString()); } } // Ignore all the other eventTypes, but you should consider the other ones. } public static void main(String[] args) throws Exception { SerialTest main = new SerialTest(); main.initialize(); Thread t=new Thread() { public void run() { //the following line will keep this app alive for 1000 seconds, //waiting for events to occur and responding to them (printing incoming messages to console). try {Thread.sleep(1000000);} catch (InterruptedException ie) {} } }; t.start(); System.out.println("Started"); } }
Und wie verwende ich eine der beispiel-libarys?
Wenn ich den Artikel richtig verstanden habe (mein Englisch ist nicht das beste) muss ich zuerst den Arduino Programmieren (mit der mitgelieferten Software) und kann dann die Sensordaten auslesen, stimmt das?
Gruß aloC-acoC
Zitieren
