Seite 5 von 22 ErsteErste ... 3456715 ... LetzteLetzte
Ergebnis 41 bis 50 von 211
Thema: Software-Fragen zur Multi-IO
  1. #41
    nahe Dresden
    hallo,
    ich habe jetzt die platine vom fabqu bekommen, angeschlossen, das ergebnis verstehe ich in zweierlei punkten nicht:
    Terminal cleared!
    [RP6BOOT]
    [READY]
    RP6Control Multi IO Selftest 1!
    Writing 128 to EEPROM address 5:
    Done!
    Reading EEPROM address 5:
    I2C ERROR --> TWI STATE IS: 0x20
    I2C ERROR --> TWI STATE IS: 0x48
    Done!
    EEPROM address 5 content: 17
    3V3 Voltage:  2.6V
    ADC 3V3: 532
    TOUCHED!!!
    ADC Touch: 537
    Temperature:  23.4°
    RTC: 12:00:00  10.01.2013
    Temperature:  20.8°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.3V
    ADC 3V3: 472
    NOT touched.
    ADC Touch: 423
    Temperature:  23.3°
    Temperature:  21.8°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.2V
    ADC 3V3: 448
    NOT touched.
    ADC Touch: 392
    Temperature:  23.3°
    Temperature:  22.1°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 439
    NOT touched.
    ADC Touch: 382
    Temperature:  23.3°
    Temperature:  23.7°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 437
    NOT touched.
    ADC Touch: 381
    Temperature:  23.3°
    Temperature:  23.0°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 436
    NOT touched.
    ADC Touch: 380
    Temperature:  23.3°
    Temperature:  21.2°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 435
    NOT touched.
    ADC Touch: 379
    Temperature:  23.3°
    Temperature:  22.6°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 435
    NOT touched.
    ADC Touch: 379
    Temperature:  23.3°
    Temperature:  22.8°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 435
    NOT touched.
    ADC Touch: 379
    Temperature:  23.3°
    Temperature:  21.3°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 435
    NOT touched.
    ADC Touch: 379
    Temperature:  23.3°
    Temperature:  21.8°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 436
    NOT touched.
    ADC Touch: 380
    Temperature:  23.3°
    Temperature:  22.1°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 435
    NOT touched.
    ADC Touch: 379
    Temperature:  23.3°
    Temperature:  21.4°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 435
    NOT touched.
    ADC Touch: 379
    Temperature:  23.3°
    Temperature:  22.1°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 435
    NOT touched.
    ADC Touch: 379
    Temperature:  23.3°
    Temperature:  23.4°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 435
    NOT touched.
    ADC Touch: 379
    Temperature:  23.3°
    Temperature:  22.6°
    BAT Current:    0.0mA
    BAT Voltage:  7.4V
    SERVO Volt.:  5.0V
    VCC Voltage:  5.1V
    3V3 Voltage:  2.1V
    ADC 3V3: 435
    NOT touched.
    ADC Touch: 379
    Temperature:  23.3°
    [RP6BOOT]
    [READY]
    das verhalten der 3.3 V - sinkt von 2,6 auch 2,1V
    das nichtreagieren des berührungssensors, auch beim berühren nicht (antennen wie auch beuteil direkt reagieren nicht)
    Fabqu hat gemeint ich soll den ausdruck ins forum stellen, evtl. ein softwareproblem?
    gruß inka
  2. #42
    Hast du denn schon gemessen, ob der Output des NE555 nach Berühren schaltet?
    Dort (messe z.B. am Jumper, wo "NE5" steht) sollten normalerweise 0V anliegen, und nach Berühren der Antenne für einige Sekunden knappe 5V.
  3. #43
    Erfahrener Benutzer Fleißiges Mitglied Avatar von Thorben W
    Niedersachsen
    Hallo bei mir ist die Ausgabe so:
    3V3 Voltage: 1.5V
    ADC 3V3: 300
    NOT touched.
    ADC Touch: 300
    TNC75_Temperature: 26.4°
    Temperature: 0.0°
    BAT Current: 0.0mA
    BAT Voltage: 0.0V
    SERVO Volt.: 0.0V
    VCC Voltage: 2.5V
    Mich wundert das der LTC 2990 nichts anzeigt oder wie wird die Spannung VCC Voltage gemessen?
    Wenn ich das DCF77 Modul (Conrad 641138 ) anschließe bekomme ich bei dem Beispielprogramm von Dirk keine Werte.
    Muss ich noch einen Pull-up anschließen an Port 3?
  4. #44
    nahe Dresden
    beim messen zwischen GND (kompass-pin-leiste) und dem NE5-pin, so wie du es beschreibst, 0V / 4.6V
    gruß inka
  5. #45
    @Inka. wie mit eMail besprochen.
    @Thorben:
    DU hast scheinbar dasselbe Problem wie Inka mal hatte, dein LTC macht gar nix. Bei Inka war hier einfach nur ein einziger Pin (der GND-Pin) ohne Kontakt zum Board, könnte mein Fehler gewesen sein, könnte durch den Transport bei Minusgraden passiert sein, wenns vorher schon nicht so super war.
    Am besten mal mit dem Lötkolben vorsichtig jedes Beinchen einzeln kurz andrücken (vorher natürlich Batterie abziehen. ohne weiteren Lötzinn, da sonst die Gefahr von Kurzschlüssen groß wird). Hast du ein Multimeter? Dann bitte danach testen, ob kurzschlüsse zwischen den Beinchen entstanden sind.
    Dann nochmal alles anstecken und sehen, was nun für Werte kommen.
  6. #46
    Niedersachsen
    @fabqu:
    Danke Problem ist behoben
    Den Spannungsteiler kann ich jetzt einlöten?
    Thorben
  7. #47
    Ja! Welche Widerstände nimmst du? 36kOhm an den beiden Beinchen des Reglers und 22kOhm anstelle des C12 funktionieren gut.
  8. #48
    Niedersachsen
    Dann diese beiden!
    Thorben
  9. #49
    nahe Dresden
    diese beiden widerstände habe untereinander kontakt an einem der beinchen des reglers, ja? Ich frage wegen dem nachlöten, da kann ich also etwas lötzinn hinzufügen?
    gruß inka
  10. #50
    Ja, dort darf ein Kontakt sein. Muss nicht, darf!
  1. Anfängerfrage zur Software PWM
    Von Daaniel im Forum C - Programmierung (GCC u.a.)
    Letzter Beitrag: 04.04.2012, 21:33
  2. Rasenmähroboter fragen zur lenkung und mehr fragen :-)
    Von andiwalter im Forum Staubsaugerroboter / Reinigungs- und Rasenmähroboter
    Antworten: 11
    Letzter Beitrag: 11.05.2009, 18:25
  3. Software zur Fehlersuche in Schaltungen
    Von konservator im Forum Software, Algorithmen und KI
    Letzter Beitrag: 21.01.2007, 10:08
  4. PDA-Software zur Camerabildauswertung?
    Von gpsklaus im Forum PC-, Pocket PC, Tablet PC, Smartphone oder Notebook
    Letzter Beitrag: 08.12.2005, 16:13
  5. [ERLEDIGT] Software zur Kartenerstellung
    Von im Forum Vorstellungen+Bilder von fertigen Projekten/Bots
    Antworten: 38
    Letzter Beitrag: 12.11.2004, 09:46
