Ergebnis 1 bis 10 von 24
Thema: RP6 Ultraschallsensor SRF08
Baum-Darstellung
  1. #4
    ach ja und außerdem möchte ich gerne noch wissen wie das programm aussieht wenn ich die Ultrschallsensoren an das Atmega 32 anschließen will?
    Der Rp6 läuft im Slave modus.
    Ich habe das beispielpgrogramm von der base für das Atmega 32 umgeschrieben aber irgenwie funktioniert das nicht.
    Danke Marian Otte
    Das sähe dann bei mir so aus:
    #include "RP6ControlLib.h"
    #include "RP6I2CmasterTWI.h"
    #include "RP6Control_I2CMasterLib.h"
    #define SRF_ADR  0xE6
    void changeSRFAddr(uint8_t old_addr, uint8_t new_addr)
    	I2CTWI_transmit2Bytes(old_addr, 0, 0xA0);
    	I2CTWI_transmit2Bytes(old_addr, 0, 0xAA);
    	I2CTWI_transmit2Bytes(old_addr, 0, 0xA5);
    	I2CTWI_transmit2Bytes(old_addr, 0, new_addr);
    #define MEASURE_US_LOW 	0
    #define MEASURE_US_HIGH 1
    uint16_t distance;
    void I2C_requestedDataReady(uint8_t dataRequestID)
    	uint8_t messageBuf[8];
    	static uint8_t dist_tmp;
    	switch(dataRequestID)
    		case MEASURE_US_HIGH:
    			I2CTWI_getReceivedData(messageBuf, 2);
    			dist_tmp = (messageBuf[0]);
    			I2CTWI_transmitByte(SRF_ADR, 3);
    			I2CTWI_requestDataFromDevice(SRF_ADR, MEASURE_US_LOW, 1);
    		break;
    		case MEASURE_US_LOW:
    			distance = messageBuf[0] + (dist_tmp << 8);
    			writeString_P("Distance: ");
    			writeInteger(distance, DEC);
    			writeString_P(" cm | ");
    			uint16_t dist_count;
    			for(dist_count = distance; dist_count > 4; dist_count-=2)
    				writeChar('#');
    			writeChar('\n');
    		break;
    void I2C_transmissionError(uint8_t errorState)
    	writeString_P("\nI2C ERROR --> TWI STATE IS: 0x");
    	writeInteger(errorState, HEX);
    	writeChar('\n');
    void task_SRF(void)
    	static uint8_t measureInProgress = false;
    	if(!measureInProgress)
    		if(TWI_operation == I2CTWI_NO_OPERATION)
    			I2CTWI_transmit2Bytes(SRF_ADR, 0, 81);
    			measureInProgress = true;
    			setStopwatch1(0);
    	else if(getStopwatch1() > 70)
    		I2CTWI_transmitByte(SRF_ADR, 2);
    		I2CTWI_requestDataFromDevice(SRF_ADR, MEASURE_US_HIGH, 1);
    		setStopwatch1(0);
    int main(void)
    	I2CTWI_initMaster(100);
    	I2CTWI_setRequestedDataReadyHandler(I2C_requestedDataReady);
    	I2CTWI_setTransmissionErrorHandler(I2C_transmissionError);
    	setLEDs(0b111111);
    	mSleep(500);
    	setLEDs(0b000000);
    	startStopwatch1();
    	while(true)
    		task_SRF();
    		task_I2CTWI();
    	return 0;
    ich bekomme das mit dem Code einfügen einfach nicht hin
    Geändert von Marian Otte (16.03.2013 um 20:03 Uhr)
  1. RP6 Ultraschallsensor an Erweiterungsplatine
    Von Berghuhn im Forum Robby RP6
    Antworten: 10
    Letzter Beitrag: 15.12.2010, 21:54
  2. UltraschallSensor SRF08 - günstig kaufen
    Von boeser_bube im Forum Sensoren / Sensorik
    Letzter Beitrag: 19.11.2008, 21:36
  3. Ultraschallsensor SRF08
    Von AR@HTL im Forum Sensoren / Sensorik
    Letzter Beitrag: 16.04.2007, 15:46
  4. Einfallswinkel Ultraschallsensor SRF08 / SRF10 Stufen
    Von Phil54 im Forum Sensoren / Sensorik
    Antworten: 7
    Letzter Beitrag: 12.05.2005, 20:40
  5. srf08 ultraschallsensor setzt aus.
    Von pebisoft im Forum Sensoren / Sensorik
    Letzter Beitrag: 25.11.2004, 17:45
