Thema: MCP9700 Temperaturabfrage
    St.Pölten
    4 MCP9700 werden abgefragt und sollen in Grad Celsius Wert anzeigen.
    zwei C++ Codes bringen 2x denselben Fehler.
    Wert wird in Millivolt und nicht in Grad ausgegeben und ich finde den Fehler nicht.
    Bitte um Hilfe
    Code 1
    #include <LiquidCrystal.h>
    // Arduino pins used for LCD
    LiquidCrystal lcd(8,9,4,5,6,7);// Pins Keypadshield
    //Variablen
    int ADC0,ADC1,ADC2,ADC3;
    float temp0,temp1,temp2,temp3;
    //Konstanten Offset setzen
    int MCPoffset = 500;
    int LM35offset = 0;
    //Sensor Kalibration
    int calibration0 = 0;
    int calibration1 = 0;
    int calibration2 = 0;
    int calibration3 = 0;
    void setup(){
    Serial.begin(9600);
    lcd.begin(16, 2);
    void loop (){
    getADC();
    calcLoop();
    serialPrint();
    lcdPrint();
    delay(1000);
    void getADC(){
    ADC0 = analogRead(A Bild  ;
    ADC1 = analogRead(A9);
    ADC2 = analogRead(A10);
    ADC3 = analogRead(A11);
    void calcLoop(){
    temp0 =calcTemp(ADC0, MCPoffset, calibration0);
    temp1 =calcTemp(ADC1, MCPoffset, calibration1);
    temp2 =calcTemp(ADC2, MCPoffset, calibration2);
    temp3 =calcTemp(ADC3, MCPoffset, calibration3);
    float calcTemp (int val, int offset, int cal){
    return(((val * 4.882 Bild   - offset) / 10) + cal;
    void serialPrint(){
    Serial.print(temp0,2);
    Serial.print(" ");
    Serial.print(temp1,2);
    Serial.print(" ");
    Serial.print(temp2,2);
    Serial.print(" ");
    Serial.print(temp3,2);
    Serial.print(" ");
    Serial.print(" ");
    delay(10);
    void lcdPrint(){
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print(temp0, 1);
    lcd.print(" A ");
    lcd.setCursor(9, 0);
    lcd.print(temp1, 1);
    lcd.print(" B ");
    lcd.setCursor(0, 2);
    lcd.print(temp2, 1);
    lcd.print(" C ");
    lcd.setCursor(9, 2);
    lcd.print(temp3, 1);
    lcd.print(" D ");
    Code 2----------------------------
    void setup() {
    // initialize the LCD display
    lcd.begin(16, 2);
    Serial.begin(9600);
    pinMode (50, OUTPUT); //Ausgang definiert
    void loop() {
    // digitalWrite (50,LOW); // Ausgang ausgeschalten
    //---- Messung T1 ----
    float tempT1 = 0.0; // Berechnete Temperatur speichern
    int sampleT1; // counts through ADC samples
    float ten_samplesT1 = 0.0; // Speichern 10 Messungen
    // 10 samples from the MCP9700 T1
    for (sampleT1 = 0; sampleT1 < 10; sampleT1++) {
    tempT1 = ((float)analogRead(A Bild   * 5.0 / 1024.0) - 0.5;// convert A8 value to temperature
    tempT1 = tempT1 / 0.01;
    delay(10);
    ten_samplesT1 = ten_samplesT1 + tempT1; //Summe aller samplesT1
    //----Messung T2 ----
    float tempT2 = 0.0; // Berechnete Temperatur speichern
    int sampleT2; // counts durch ADC
    float ten_samplesT2 = 0.0; // Speichern 10 Messungen
    // 10 samples from the MCP9700 T2
    for (sampleT2 = 0; sampleT2 < 10; sampleT2++) {
    tempT2 = ((float)analogRead(A9) * 5.0 / 1024.0) - 0.5;// convert A9 value to temperature
    tempT2 = tempT2 / 0.01;
    delay(10);
    ten_samplesT2 = ten_samplesT2 + tempT2; //Summe aller samplesT2
    //---- Messung T3 ----
    float tempT3 = 0.0; // Berechnete Temperatur speichern
    int sampleT3; // counts through ADC samples
    float ten_samplesT3 = 0.0; // Speichern 10 Messungen
    // take 10 samples from the MCP9700
    for (sampleT3 = 0; sampleT3 < 10; sampleT3++) {
    tempT3 = ((float)analogRead(A10) * 5.0 / 1024.0) - 0.5;// convert A10 value to temperature
    tempT3 = tempT3 / 0.01;
    delay(10);
    ten_samplesT3 = ten_samplesT3 + tempT3;//Summe aller samplesT3
    //----Messung T4 ----
    float tempT4 = 0.0; // Berechnete Temperatur speichern
    int sampleT4; // counts through ADC samples
    float ten_samplesT4 = 0.0; // Speichern 10 Messungen
    for (sampleT4 = 0; sampleT4 < 10; sampleT4++) {
    tempT4 = ((float)analogRead(A11) * 5.0 / 1024.0) - 0.5; // convert A11 value to temperature
    tempT4 = tempT4 / 0.01;
    // sample every 0.1 sec0onds
    delay(100);
    ten_samplesT4 = ten_samplesT4 + tempT4;//Summe aller samplesT4
    //-----------Temp-Vergleich-------------
    if (tempT1 == tempT2);
    digitalWrite (50,HIGH);
    Serial.println(tempT1);
    //Gesamttemperatur berechnen
    float tempGesamt = 0.0;
    tempGesamt = (float (tempT1 + tempT2 + tempT3 + tempT4));
    //----Ausgabe auf LCD----
    tempT1 = ten_samplesT1 / 10.0;
    tempT2 = ten_samplesT2 / 10.0;
    tempT3 = ten_samplesT3 / 10.0;
    tempT4 = ten_samplesT4 / 10.0;
    tempGesamt = tempGesamt/4;
    lcd.print(tempT1 );
    lcd.print(" A ");
    lcd.print(tempT2);
    lcd.print(" B ");
    lcd.setCursor(0, 1);
    lcd.print(tempT3);
    lcd.print(" C ");
    lcd.print(tempT4);
    lcd.print(" D ");
    delay(5000);
    lcd.clear();
    lcd.print(tempGesamt);
    lcd.print(" < Grad C >");
    Serial.println(A Bild  ;
    delay(1000);
    St.Pölten
    Fehler gefunden!
    Sensoren hatten anderes Massepotential als Arduino.Trotz Mehrmaligen Aufbaus.
    Nobody is perfect.
