ich habe mir einen Bascom Code zurechtgelegt, der die LEDs, das Display und die Motoren bedient:
Läuft soweit ganz gut, bei den Liniensensoren komme ich nicht weiter.Code:'======================================= '==== 3PI goes Bascom '==== December 2012, pinsel120866 '======================================= $regfile = "m328pdef.dat" ' Set the chip as a Mega 328p $crystal = 20000000 ' Clock speed 20 MHZ '=== Generic Port Setup === Config Portb = Output Config Portc = Output Config Portd = Output re_led Alias Portd.7 ' Green User LED li_led Alias Portd.1 ' Red User LED '=== LCD SETUP === Config Lcdpin = Pin , Db4 = Portb.1 , Db5 = Portb.4 , Db6 = Portb.5 , Db7 = Portd.7 , E = Portd.4 , Rs = Portd.2 Config Lcd = 16 * 2 ' Actually 8x2 but that is not recognized by BASCOM. Rw Alias Portb.0 : Rw = 0 ' Set to Zero to write to the LCD Cursor = Off '=== PWM SETUP === Config Timer0 = Pwm , Prescale = 1 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down Config Timer2 = Pwm , Prescale = 1 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down '------------------------------------------------------------------------------------------------------------------------------ ' Pin Configurations ' Portb.0 - LCD Function R/W ' Portb.1 - LCD Data DB4 ( Switch A ) ' Portb.2 - Buzzer ' Portb.3 - Motor 2 Control Line ' Portb.4 - LCD Data DB5 ( Switch B ) ' Portb.5 - LCD Data DB6 ( Switch C ) ' Portb.6 - ' Portb.7 - ' Portc.0 - IR Sensor #1 ( Left ) ' Portc.1 - IR Sensor #2 ' Portc.2 - IR Sensor #3 ( Center ) ' Portc.3 - IR Sensor #4 ' Portc.4 - IR Sensor #5 ( Right ) ' Portc.5 - ADC5 ' Portc.6 - Motor Controller Not Standby ' Portc.7 - ' Portd.0 - RXD ' Portd.1 - TXD (RED LED) ' Portd.2 - LCD Function RS ' Portd.3 - Motor 2 Control Line ' Portd.4 - LCD Function E ' Portd.5 - Motor 1 Control Line ' Portd.6 - Motor 1 Control Line ' Portd.7 - LCD Data DB7 (GRN LED) ' ADC6 - Battery Power Indicator ' ADC7 - User Trim Pot on underside '------------------------------------------------------------------------------------------------------------------------------ '======================================= ' Program Start Here '======================================= Dim X As Word ' Set up a simple variable Cls Lcd "START" Locate 2 , 1 For X = 1 To 5 Lcd "*" Wait 1 re_led = 1 li_led = 1 Next X Cls Lcd "Gerade" X=60 re_led = 0 li_led = 0 Gosub Robot_forward Waitms 1000 Cls Lcd "Rechts" X=100 re_led = 1 li_led = 0 Gosub Robot_right Waitms 1000 cls lcd "Zurück" x=60 re_led = 0 li_led = 0 gosub ROBOT_REVERSE waitms 1000 cls lcd"Links" x=100 re_led = 0 li_led = 1 gosub ROBOT_LEFT waitms 1000 re_led = 0 li_led = 0 Cls Lcd "Fertig" Gosub Robot_stop waitms 1000 '======================================= Do ' Just waste time at the end Loop End 'end program '======================================= ' Subroutines Here '======================================= Robot_forward: Pwm0a = X : Pwm0b = 0 : Pwm2a = X : Pwm2b = 0 Return Robot_stop: Pwm0a = 0 : Pwm0b = 0 : Pwm2a = 0 : Pwm2b = 0 Return Robot_reverse: Pwm0a = 0 : Pwm0b = X : Pwm2a = 0 : Pwm2b = X Return Robot_right: Pwm0a = 0 : Pwm0b = X : Pwm2a = X : Pwm2b = 0 Return Robot_left: Pwm0a = X : Pwm0b = 0 : Pwm2a = 0 : Pwm2b = X Return
Kann mich bitte jemand dabei unterstützen?
Wäre nett...
Zitieren
