da ich bereits ein paar Module gekauft habe, frage ich mich ob man einen RSSI_output auch nachträglich hinzufügen kann. Denn soweit ich weiss haben meine Module keinen solchen Ausgang.
New 433Mhz RF transmitter module and receiver link kit for Arduino/ARM/MCU WL
TX Technical Specifications:
1. Working voltage: 3V~12V
2. Working current: max≤40mA (12V), min≤9mA(3V)
3. Resonance mode: sound wave resonance (SAW)
4. Modulation mode: ASK /OOK
5. Working frequency: 315MHz-433.92MHz, customized frequency is available.
6. Transmission power: 25mW (315MHz at 12V)
7. Frequency error: +150kHz (max)
8. Velocity: ≤10Kbps
9. Self-owned codes: negative
RX Technical Specifications:
1. Working voltage: 5.0VDC +0.5V
2. Working current:≤5.5mA (5.0VDC)
3. Working principle: single chip superregeneration receiving
4. Working method: OOK/ASK
6. Bandwidth: 2MHz (315MHz, having result from testing at lowing the sensitivity 3dBm)
7. Sensitivity: excel –100dBm (50ω)
8. Transmitting velocity: <9.6Kbps (at 315MHz and -95dBm)
