Es sind 4 Messungen, da man dann keine Divisionsroutine benötigt, sondern nur zweimal rechts schieben muss.
Den Rest solltest Du selbst zusammenbringen.
Code:.include "m8def.inc" .equ chan = 0 ; adc-channel .cseg .org 0 rjmp start reti .org 0x13 start: ldi r16, high(RAMEND) out SPH, r16 ldi r16, low(RAMEND) out SPL, r16 rcall adc_init mainloop: rcall get_adc ; do something rjmp mainloop get_adc: ; returns averaged result out of 4 samples clr r18 ; result in r18/r19 clr r19 ldi r17, 4 ; count of samples in r16, ADMUX andi r16, ~(1<<MUX3)|(1<<MUX2)|(1<<MUX1)|(1<<MUX0) ori r16, chan out ADMUX, r16 get_sample: sbi ADCSRA, ADSC ; start conversion wait_adc: sbic ADCSRA, ADSC rjmp wait_adc ; wait for conversion ready in r16, ADCL ; get result low byte add r18, r16 ; add in r16, ADCH ; get high byte adc r19, r16 ; add with carry dec r17 ; decrease sample counter brne get_sample lsr r19 ; shift result right = divide by 2 ror r18 lsr r19 ; same again, now divided by 4 ror r18 ret adc_init: ldi r16, (1<<ADEN)|(1<<ADPS2)|(1<<ADPS0) ; enable adc, adc-prescaler 32 out ADCSRA, r16 ldi r16, (1<<REFS0) ; ref is AVCC out ADMUX, r16 ret
Zitieren
